Question about John Deere Muffler 1010 Diesel Tractors
JOHN DEERE 1010 DIESEL TRACTOR BLEED FUEL LINES
AIR IN FUEL LINE WILL NOT START
mattofilms
  • 110 Answers
SOURCE: 2020 john deere diesel tractor with j-d 36# loader
Sounds like you need more hydraulic oil - Or like you said the transmission screen (dirty).
Where it is ??
Posted on Jul 02, 2009
wilsodfarm
  • 986 Answers
SOURCE: 3020 carburetor ? john deere gas tractor, 3020
those carbs are real simple you will not have any problem
Posted on Jul 29, 2009
bargainbin2
  • 123 Answers
SOURCE: I have a john deere 430 garden tractor diesel.
Sounds like the fuel pump stoped working.
Posted on Aug 26, 2009
rwvanlue
  • 486 Answers
SOURCE: I have a John deere 317 tractor that does not start.
We will be testing for voltage to the points, coil, engine to tractor wiring harness, ignition switch
Tools needed:
volt meter to read 12 volts, or test light
1) with the points open: is there voltage at the connection wire at the points
If yes; adjust points to .020" and try to crank engine and check for spark
*** you may want to determine if condensor is connected to this wire also
if no
2) check point side (neg or - ) of coil for voltage
if yes, engine should start
if no
3) check for voltage at the + side of coil
If yes, coil is bad
if no
4) check wire connector from engine to frame wiring harness
if yes; engine should start
if no
5) check wiring on the back of ignition switch
if no
6) check that ignition switch RED or BATTERY supply wire has voltage
if yes; switch is bad
if no
7) check supply wire and circuit breaker connected to the battery side of the solenoid
if no; circuit breaker could be at fault or wire connector at battery supply
Posted on Nov 08, 2009
wireguy212
  • 1627 Answers
SOURCE: ELECTRICAL PROBLEM
Can't get you a diagram but i can tell you most electical problems on these tractors can be solved by replaceing the key switch/modual or cleaning corrosion from fuse holders.
Posted on Nov 10, 2009
How to bleed the air out of line on a 5975e john deere tractor
if it got run low on fuel and now the pump is air bound , carefully loosten the #1 injector line , and attempt to start machine, notice I didn't say remove , fuel there is very high pressure and you don't want that shooting around , drips is all u want to show , you will notice foam at fitting this is the air coming out of line , once foam stops , stop engine and retighten fitting , don't tighten while running too dangerous !!
Jul 27, 2016 | John Deere Garden
John Deere 5520 tractor won't start. I've replaced the fuel pump, fuel lines, bleed the air out. It turns over but won't start.
check the fuel pump timing
bleed the air out of the pump
bleed the air out of the injector lines
Oct 06, 2015 | John Deere Garden
How do I change the fuel filter on my 3020 John Deere diesel tractor
Leaving the fuel valve on the tank in the on position will allow fuel to run through the line & keep the air purged during removal. On the other side between the pump & the filter, having the new filter topped off & speedily installed will lessen the chance of air entering the line. Once the filter is installed, open the bleed screw at the top of the filter. Just my redneck way.
Oct 05, 2014 | John Deere Ar50041 Diesel Fuel Filter 3020...
2305 john deere want start replaced fuel pump still want start seems like no fire does diesle have fire
diesel work for compression ignition and have only glo plugs to help with starting in cold weather. You will need to bleed the air out of the pump and pressure lines to the injector. Crack the bleed screw on the pump until you get solid fuel then crack the injector line until it drips fuel. re tighten and it should go.
Jun 12, 2013 | John Deere Garden
Yanmar diesel fuel injector leaking
If you removed your injector lines, and then reattached them. You first off got air in the line and you will have to purge them. But, I believe that your injector gasket was probably the culprit and why it was leaking. It sounds like the injector was losing fuel pressure and the pump was unable the push enough fuel to all the cylinders when under load.
If it were me, I would go online to HoyteTractors.com they carry every part for your Yanmar tractor that you will ever need. They also have a tech department too. Since you already have air in your lines, you might as well replace the fuel filter and O-ring and injectors seals. You can also get a service manual from Hoyte for your specific tractor model. If your Yanmar (3000) is like mine, my fuel pump is on the "passenger side" of the tractor and it has a bleed valve on it. So after you replace your parts you can bleed the air out. They are very simple machines to work on. Just in case you didnt know, most Yanmar tractors are a direct cross to John Deere Tractor Models. Any John Deere tractor under 100hp is/was Mfg. by Yanmar for 30-40 yrs or so. Good Luck!!
Jun 10, 2012 | Garden
John Deere Diesel X495 garden tractor running VERY rough.
Bleed the lines while the unit is running making sure you get all the air out of the lines.
May 06, 2012 | Diesel Garden
I ran my john deere 790 out of fuel.how do i restart
With diesel, sometimes you have to bleed air out before it will run again. Typically you disconnect the fuel line going to the injector pump, manually activate the fuel pump, or turn over until fuel comes out, then release one or more of the injectors, and turn engine over again. Normally that bleeds enough to start and then the rest of the air gets pushed through.
Feb 13, 2011 | John Deere 4020 Gas & Diesel Tractor...
John Deere 115 lawn tractor - won't start. Replaced fuel filter, fuel pump, spark plug, oil filter (changed oil), but still won't start. Engine cranks, but won't run.
I have a 115 john deere tractor that runs but the engine will not run smooth I've put a new fuel cap on it a new pump and clean out the carb.
Apr 16, 2010 | John Deere Muffler 1010 Diesel Tractors
My john deere 990 wont start. it's not getting diesel to the engine
Check there is adequate fuel to supply engine. Check there is no damage to fuel lines and that the fuel filter is not plugged. Yours is a Yanmar diesel engine withe an autobleed feature which is supposed to bleed the air out of the system automatically. It may incorporate an electric fuel pump also, but some don't. You can prime the fuel system to the injection pump with the manual lift pump if it is equipped with it. After establishing fuel to the injection pump, loosen the nuts that hold the fuel lines onto the injectors approximately1 1/2 turns. Turn the engine over until you see fuel coming from the injector nuts. Tighten the nuts to 24 inch/lbs of torque, start the engine and run at 1/3 throttle untill it runs smooth.
Jan 04, 2010 | John Deere 420,1020,2010,2020,2510,2520...
750 diesel john deere tractor wont start
Hi Cassie, I can help you. Here is a brief course on bleeding a diesel engine, and the reasons why you need to bleed it.
http://extension.usu.edu/files/publications/factsheet/fm-01.pdf
Jun 19, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John Deere Muffler 1010 Diesel Tractors  Logo
82 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
