Question about Dishwashers
Dishwasher lights on
Dont start
  • 17,130 Answers
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/PUMP MOTOR/DRAIN to work when it is commanded .If this does not happen then the voltage at these points must be checked or the fault relates to no voltage/drive from the controller. This means the controller is a suspect.
Check how to remove the control panel: http://www.espares.co.uk/advice/dishwashers/a/3/1287/how-to-replace-a-hotpoint-dishwasher-fascia-p.html
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor. The water pressure must be good and the spraying must be seen to be good. If there is low pumping or pressure then the spray arms will not turn around to inject with pressure. If so the pump must be checked for clogging.
To replace check this link:
http://www.espares.co.uk/advice/dishwashers/a/3/1293/how-to-replace-the-spraying-system-on-a-dishw.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the drain valve/pump activated so as to drain off all the water.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
Posted on Dec 31, 2012
Dw60w cata dishwasher has power,turn it on power lamp does not light up, changed lamp still dont light up or work.
Ck to see if dishwasher service switch is in on position . Did the breaker trip. Do you have power to dishwasher ? Is the door lock working ?
Apr 23, 2014 | Cars & Trucks
Need an owners manuel for Sauter dishwasher clas AAA aquasafe dont know how to oprate
I have a problem. On the display appears : d07 and above a red light flashing.
The dishwasher not responding and not starting.
Any suggestions?
thanks in advance
Oct 16, 2011 | Dishwashers
Whirlpool dishwasher stops midcycle and control panel goes blank
and the controls dont advance? to the end of cycle?
Feb 26, 2009 | Dishwashers
Dishwasher will not start
You have a clean light flashing. You need to reset you control. It is activated by a number of different situations. Find the tech sheet for your dishwasher which is normally located under the bottom plate of the dishwasher. If you can not find it give me the model number and I will tell you how to activate the diagnostic test. If you do find it follow the section that says diagnostic test. Then check and makes sure you heater element is operating.
Feb 23, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher light flashes 7 times
although i dont have a lookup for your particular model number. if you remove the lower access panel you will find techsheet/troubleshooter. in it there will be section on "clen light blinking 7x" foplloe direction to put into test mode to clear the fault. belive its,,, heated dry/ sani rinse / heated dry/sani rinse. pushing htese buttons is what gets into test mode
Dec 11, 2008 | Whirlpool 24 in. ADP5962 Free-standing...
Broken dishwasher
This D/W is in need of a circuit board,and I dont advise anyone to fix this,because the problems will start getting worse
Apr 02, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint Dishwasher BF1620
ive not worked on hotpoint dishwashers,does the dishwasher drain? at the point it plays up is it supposed to be filling or washing.check the filters inlet valve etc.do you still have the manual for the dishwasher.the flashing lights are most likley a fault code but we dont get hotpoint dishwashers in australia.sorry i cant be of more help.Ian
Mar 21, 2008 | Dishwashers
Kenmore dishwasher
wont start dont get it i need more info model# is any thing lighting how old etc.
Dec 29, 2007 | Dishwashers
Ariston LL64 doesn't start
1) Ensure the dishwasher is turned off.
2) (may not apply) Turn the plastic blue lever located under the sink to the vertical position (this opens the valve, so water can go into the dishwasher)
3) Pour powder indo the dishwasher
4) Turn the dishwasher controller to the top position (the 12 o’clock position) – this is the eco-setting.
5) Press the on/power button on the dishwasher, so that it now turned on (a light will display)
6) Move the dishwasher controller to the “R” position (it’s on the very left), and leave it there a second or two.
7) Move the dishwasher controller back to the eco-setting (the 12 o’clock position).
Jun 23, 2007 | Ariston Technologies LL64WNA Built-in...
Dishwashers Logo
42 people viewed this question
Top Dishwashers Experts
