HP D1660 InkJet Printer Logo
Anonymous Posted on Dec 31, 2012
D1660 manual user manual
  • Anonymous Dec 31, 2012
    Thanks very much. So simple when you get on the right track
    Thank you Donald DCruz
Level 3:
  • HP Master 17,130 Answers
  • Posted on Dec 31, 2012
HP Master
Level 3:
Answers
17130
Questions
0
Helped
3632070
Points
52372
Please check on this support link of HP.
Hp Support
1helpful
Uniden EZX290 Expansion Handset Fails Registration to Uniden D1660 Base Unit
Unfortunately, handsets are not universal for Uniden cordless phone systems. The accessory handset for the EZX290 is compatible with the DECT1500, 2000, 2100, 300 and 2900 DECT 6.0 phone systems. The accessory handset for the D1660 is here: https://www.amazon.com/Uniden-D1660-DECT6-0-Cordless-Handset/dp/B004NEUIY2 .
I wish that I had better news for you. Unfortunately, the two systems (EZX290 and D1660) don't use same handshake codes.
Need a manual for Uniden DXAI8580-2 5.8 and DCX160 6.0
This is the link for the manual for the DXAI8580
http://www.telecomuserguides.com/manuals/filesupload/Uniden/5_8GHz/DXAI8580-2om.pdf
The DCX160 is the part number for the accessory handset used with Models D1660 and D1680 and a few others models. The handset used for these series are all interchangeable and has the same keypad function. You can reference the information for the DCX160 using the handset for D1660 Following is the link for the D1660
How do I get the 7 diget code to reset up my voice mail?
There is a User Manual for this phone at : http://data.manualslib.com/pdf2/37/3700/369997-uniden/d1660.pdf?9de4fc5cef6f5cb2bfcc8fa9111d386b
By "Voice Mail" you mean the Answering Machine part of the unit, I am going to assume.
There is nothing in that manual about a "seven digit code", but it does show you how to re-register the handset with the base. That might be the ticket to success.
Your telephone number is a "seven digit code".
My deskjet came with disk d1600 series it should have had d1660
Your HP Deskjet D1660 printer belongs to the HP Deskjet D1600 printer series. That means, the disk you have is for all the printers of the D1600 family, including yours (D1660), so you will not have any problem with the software it includes.
Silent mode on uniden d1660 corless phone
Follow the instructions beginning on page 9 of the manual.
Uniden D1660-2 how to set up voicemail and message
The Uniden D1660-2 isn't an answering machine. If you have a separate answering machine connected to your phone line, please consult its documentation. If you subscribe to a voicemail system offered by your phone company, please contact them for instructions on accessing their voicemail system.
If you need a D1660-2 manual, you may download a copy here.
How do i set up voicemail?
You need to contact your telephone company for instructions on setting up and using their voicemail system. The Uniden D1660 doesn't record voicemail, though it can tell you when you have voicemail waiting.
You may download the D1660 manual here.
12helpful
How do you trn a uniden D1660 cordless phone off of silent mode
To exit the silent mode, press and hold # on the handset for about 5 seconds. In the future, when you set the silent mode with this press and hold routine, you can follow it by a number (1-9) to set a specific length of time for the handset to be silent. Otherwise it will stay on until you manually turn it off.
The manual for the D1660 is available from http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D1660-2om.pdf .
I hope this helps.
k24674
Grand Canyon Tech
Grand Canyon Tech
