Question about Hoover Washing Machines
Hoover dyn8164d washing machine, when the last load washed I went to remove the clothes and there was a 'buzzing' coming from the top right area of the machine, I turned it off as usual, and t
  • Hoover Master
  • 17,130 Answers
Possible that the main power has failed , the power supply of the unit had packed up or there is a serious fault in the controller unit. You need to open the control panel unit to trace this case specially using a multimeter, check for the AC power to the unit and check for the DC to the circuit. If not the panel is a suspect.
Posted on Dec 31, 2012
Testimonial: "Right first time with the diagnosis! Very helpful indeed."
  • Richard Wilkerson Jan 01, 2013
    Many Thanks for this. Having traced it back, it does appear that it's the black box on the RHS that is faulty. I'll get prices on a replacement part after New Year.
3 Suggested Answers
  • 33 Answers
SOURCE: Clothing stuck on agitator with top loading washing machine
Dear Whitworth,
please rate this solution if it meets ur needs, else choose fixya...
The agitator's movement back and forth is important for the cleaning of your laundry. If it doesn't function properly, your clothes won't be as clean as possible. If your agitator does not move, moves only in one direction or its movement is very weak, you will probably need to remove the agitator. Furthermore, in order to inspect the tub for leaks, the clutch assembly, the splines, or to remove the spin drum, you will have to remove the agitator.
The agitator is fastened to the agitator shaft and its movement is driven either by splines or a simple clutch assembly. The splines are usually plastic or rubber nubs on a cylinder that fits over the agitator shaft. If the nubs wear down, the shaft will not turn properly or it will turn weakly. If the agitator is moving in only one direction, the likely cause is the clutch assembly. The clutch has dogs that depress and pop up with each turn. If those dogs are worn, they will not engage properly and the agitator will turn only in one direction.
Various makes and models differ in how the agitator is removed. In some newer models, the agitator just lifts straight up and out. However, in most models you will have to do some combination of the following steps. First remove the fabric softener dispenser, if any. It should either lift or screw off. Next remove the cap. It may lift off, screw off or failing that, it may need to be pried off.
Beneath the cap some agitators are secured in place by a bolt. Use a socket wrench with an extension to remove that bolt. Some Maytags may have a screw near to the bottom of the agitator post that must be removed. Now try to lift the agitator straight up, possibly with a little back and forth rocking motion. Use caution when pulling, the agitator may come loose suddenly and hit you in the face or send you flying backward.
If the agitator is particularly stubborn, you can loop some rope under one side of the agitator at the bottom and then up over a broom handle. Now loop it again under the other side of the agitator and back up to the broom. Brace one end of the broom handle against the top of the washer and lift up on the other end. Double check that you have removed anything that may be securing the agitator in place. Do not use too much force or you may damage the washer cabinet, agitator or injure yourself.
Click here to order replacement parts.
please rate this solution if it meets ur needs, else choose fixya..Thank you.
Posted on Dec 17, 2008
jumptrout51
  • 3361 Answers
SOURCE: Kenmore 80 Series - machine won't rinse or spin
Manually move the timer to the SPIN mode and turn it on.
If nothing happens, replace the lid switch.
With a model number I could be more specific.
Posted on Feb 27, 2009
After a load of washing the clothes are left with black deposits of plastic like substance on them.
Sure all pockets were empty before the clothes went in?
Normally there can't come any plastic in the inside of a washing machine.
Jan 18, 2015 | Hoover Washing Machines
I cannot get my washing machine door to open and alos have error code e07?
On your washing machine control panel you have little icons, find the security. Icon and it should have a line going from it to another button on the control. panel. Press both buttons at dame time and hold till it enters service. Mode. This should make it so the door will open, and will probably tell you what is wrong. with. the machine
Oct 14, 2014 | Hoover DYN8164D White 600 mm Washer Front...
I cannot get the door open and have error code eo7
Unplug from the wall socket,this should unlock the door
if the door locks after plugging in again then there is a fault which needs diagnosing..
Len...
Machine won't turn on
That sounds like the pump is jammed and did not pump all the water out.
May 10, 2013 | Fisher and Paykel WA37T26G Top Load Washer
Hoover 500m top loader washing machine fails to stop at 'OFF'
timer and dont think u can get them any more
Jan 18, 2013 | Washing Machines
Samsung washer gets clothes dirty
Put a whole house water filter on the cold side of the inlet water. I bet you have well water with lime in it??? Wash your clothes only in cold water. Rub a couple of empty loads with clorox, lime away, oxy clean to remove any build up in your washer
Oct 21, 2012 | Samsung WA5471AB 27" Top-Load Washer, 4.7...
My hoover washing machine top load won't start. I have checked the power from the wire going to the timer.The door latch switch is working and still it won't start.
my hoover washing machine do not stop they show 1 min left . i was try serval time the happend is same and inside few water as well
May 26, 2011 | Hoover HTC243 Top Load Washer
Washing Machines Logo
288 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
