Question about Refrigerators
Hoover F5A Fridge Freezer(10 yrs old) - Freezer OK but fridge does not cool Any ideas? regards Mont
Freezer OK but fridge stopped suddenly stopped cooling - no trace of cooling at all
SOURCE: Fridge stopped cooling
We had the same problem today and it was because I had not closed the freezer completely a week ago and the evaporator coil in freezer was completely iced up. A blow dryer defrosted the coil quickly. It is best to empty the freezer first and shut fridge off. You need to defrost the coil enough so air will flow through the coil. To cool the fridge cold air is drawn from this coil by an evaporator fan located above this coil behind the removable cover at rear of freezer. IF you remove this cover and this fan is turning check for ice on coil. That is probably the problem. Evap. fan is about $100 - ouch. The other thing you can check is the fridge damper control at top rear of fridge. This failed on us 13 months after we bought fridge so no warrenty. Part was $44 plus service of $100. Now I fix this fridge myself. If you remove damper cover you can cycle thermostat and see it open and close. If it is not opening replace it. You can probably find the part cheaper that $44 at an apliance parts store.
Posted on May 19, 2007
SOURCE: kelvinator 380 fridge
called the experts....all fixed.
problem- flty sensor terminator
Posted on Sep 05, 2008
philbran
  • 242 Answers
SOURCE: Fridge on Fridge freezer not working
Ok there is a drain pan under the evap. coil under the fan that may be clogged and full of ice there is a 3/4" hole the water drains out of that needs cleared if there is a puddle of ice over it , the ice will also effect the airflow traveling down the duct to the fresh food section of the unit.
If there is no ice puddle at the bottom of the refrigerator then make sure the unit is cooling well by making sure it has been running for 10 min. or so and checking the coil in the freezer , it should have a small layer of frost on it showing its getting cold the whole way through it. Let me know how this works.
Phil
Posted on Jan 02, 2009
woodchuck789
  • 4070 Answers
SOURCE: Creda R335NW Fridge/Freezer. The fridge section
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Posted on Jul 03, 2009
woodchuck789
  • 4070 Answers
SOURCE: zanussi fridge compartment has stopped cooling but freezer is ok
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .
OR.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Posted on Aug 24, 2009
Fridge and freezer suddenly not working only 1.5 yrs old
I guess the culprit in this case is the compressor.. Do you hear a sound when you are near the refrigirator.. it will be like a fan rotating at a high speed...
Mar 07, 2008 | GE GSL25LGTBS 25.4 Cu. Ft. Side-By-Side...
Hi i have RGE 400 lpg fridge freezer its 10 yrs old on my catering trailer and used daily. Its stopped cooling the fridge and freezer compartments but the pilot light is ok. the metal tubes at the rear of...
I suggest you to check the Vents. I had a similar issue where my 12v compressor car fridge freezer stopped working and I found that I had put the Fridge Cover the other way round which accidentally covered the vents
Nov 22, 2012 | Dometic RGE400 Top Freezer Refrigerator
We have a 2door fridge freezer, the freezer side is working fine , the fridge side is v poor, appears to be only cool air comming out of the middle vents, its been very hot whwre we are, is there a filter...
john ok there is a knob with letters on it trying turning it to c . in essence what u r doing is opening a vent to allow cold air from the freeze into the ref. try different letters till u get one that u like.. ok
Feb 12, 2011 | Westinghouse Refrigerators
My Hoover Nextra fridge freezer is 9 years old in perfect condition. Fridge has stopped cooling but freezer is working ok. I have turned up temp control to super, motor is warm but silent. What could have...
Hi, I have a Hoover Nextra Fridge Freezer and last night it tripped all my electric. When I plugged it back in, it sounds like it is starting, but then after a couple of seconds clicks off again. Any ideas?
Dec 26, 2010 | Refrigerators
Phil
Jan 02, 2009 | Zanussi ZI921 / 8FF Bottom Freezer...
Fridge stopped working suddenly
Sounds like the relay (start device) on the compressor has failed.  This is a very common problem especially for models that are 3-5 yrs old.  I would replace that first.
Oct 22, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Frigidaire 7.5 cu.ft. Top Freezer the fridge part doesn't cool; freezer is fine.
It should be under warranty, retry he is probably right, run for 24hrs and it should work ok, if you ever defrost you should turn off for 24hrs and leave the door open. Regards Advisor
Aug 08, 2007 | Frigidaire GLRT83TES Top Freezer...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
