Question about PNY 4GB Secure Digital High Capacity Memory Card
Pny optima card stopped working after taking pictures all day, now will not read in any slot or cameras. we used the card for over 100 pictures in Rome and then it gave an error in the camera that card was not readable, tried it in two other cameras and two laptops...any ideas why and how I can fix this? thanks
  • PNY Master
  • 27,725 Answers
Connect it to your computer
Click start control panel Administrative tools Computer Management Disk Management right click on your drive select properties click tools you should see click check now click start two boxes Automatically fix files and scan for and attempt recovery of bad sectors place then a tick in one box then select check now start then after its finished return and tick the other box you should not do anything while the chkdsk utility is in progress any input may damage this drive. You might get best results ticking in one box the returning after it has finished then ticking the other box it might take some time depending on the of your disk but be patient. Hope it helps.
Posted on Jan 11, 2013
  • 10406 Answers
SOURCE: My 4GB PNY Optima sd card will not read
Try the 4GB card in some other reader, or your camera, to confirm that it does work.
It's possible that your card-reader will not support anything over 2GB.
Posted on Dec 10, 2009
SOURCE: PNY optima SD HC 4GB card will not read
Try putting a tiny piece of scotch tape over the lock slider. See if that works.
Posted on Jan 07, 2010
  • 193 Answers
SOURCE: I have this my pny optima sdhc 4gb and it freezes...
becoz then the autoplay of the drive will be activated and it will freez your computer......recomandation is to format the drive in computer not in the cam, or you can open the SD drive frome 3rd party software (total commander), and delete the hidden autorun files.
Posted on May 07, 2010
lock123
  • 6831 Answers
SOURCE: Have brand new PNY OPTIMA SD HC 8gb
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Sep 27, 2010
  • 13 Answers
SOURCE: PNY optima sd card "card error"
You should try some photo recovery software to rescue the files on your camera card, here are some you may rely on. Both programs can also recover videos and music.
Photo Recovery Software (for Windows)
Mac Photo Recovery Software (for Mac OS X)
Be careful: Before your pictures are recovered, do not attempt to save more files to the card in case the original files(your pictures) are overwritten.
Posted on Dec 15, 2010
PNY optima sdhchd 8gb won't read in my Kodak easy
What model Kodak EasyShare camera? Some of them only work with SD cards, not with SDHC cards. The same applies to kiosks. Make sure the slot is marked "SDHC' and not simply "SD".
Feb 05, 2012 | SanDisk Cameras
How do you see the pictures with on your computer with this memory card?
Upload to your computer with your camera or have a card reader installed on your computer or get a USB card reader you can get these at any computer store or retail store. Here is a link to one Click Here
Jan 08, 2011 | PNY Optima Pro 2GB Secure Digital Memory...
I have inserted a new PNY optima SC HC memory card and window in camera says "memory card error". Does the canon not take this card?
Correct. The A510 uses SD cards, not SDHC cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work.
Nov 02, 2010 | Canon PowerShot A510 Digital Camera
Have brand new PNY OPTIMA SD HC 8gb Have a HP camera Photosmart R927 Camera reads card is locked. How do I unlock the card?
Hello
Kind regards
Andrea
Jul 06, 2010 | PNY Optima Pro 2GB Secure Digital Memory...
I have this my pny optima sdhc 4gb and it freezes my pc when I want to get the pictures off or the videos. Works fine if I use my usb cord to the camera, but I want to know why it wont work just from the...
May 07, 2010 | PNY 4GB Secure Digital High Capacity...
My pny optima sd memory card is reading card error after i used it for 1 day. now i can't get any pictures out of it.
faulty i'm afraid, try the manufacturer for resources to get the data if any?!? good luck
Apr 06, 2010 | PNY 2GB microSD Memory Card
I have a PNY optima sd 2gb memory card and it tells me on my samsung camera card error. What does this mean?
My Sanyo camera says my sd card it full when it absolutely is not. Ive even tried uploading pictures to my computer and it tells me there is an issue. It just suddenly did this one day and I think I've lost about 150 photos from Easter and other things that I can't get back and worse I can't take any pictures with my camera now.
Mar 09, 2010 | PNY Optima Pro 2GB Secure Digital Memory...
Dec 29, 2009 | PNY 4GB Secure Digital High Capacity...
Printer will not read card
Try to use your card in a clean computer and run a virus or malware test on it. Make sure that the card has no unwanted hidden folders that may contain virus files unblocking the card from being accessed by your printer.
Dec 29, 2009 | PNY Optima High-Speed 512MB Secure Digital...
Jun 15, 2009 | PNY 4GB Secure Digital High Capacity...
PNY 4GB Secure Digital High Capacity Memory Card Logo
78 people viewed this question
Top PNY Electronics - Others Experts
john milligan
Sandy Moore
Sandy Moore
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
