Question about Eureka 3276AVZ Bagless Upright Vacuum
3276AVZ stop sucking i already service it but its 0 sucking from pipe and 02 present is from down brush are out of 100.how can i fix it ?
  • Eureka Master
  • 18,387 Answers
Nilfisk gm 80 hoover has no power will start for a second and stop any idea wat could be wrong tried the plug but it was fine checked the connections they were fine so running out of ideas now
Its stopping because its trying so hard to suck that its overheating, so it cuts its own power. The airways are probably blocked. Check the bag is epty and clean, remove all hair and debris from all brushes and disconnect pipes, push a broom handle down then to clear any blockages.
Dec 15, 2013 | Vacuums
My fuller brush household canister vacuum doesn't have as much suction as usual. I've changed the bag and cleaned filter. Any other ideas?
. Test the suction without the pipes to confirm that the motor is sucking strongly, then check that there are no blockages in the pipes and fittings.
Jan 29, 2011 | Fuller Brush FBPTCAN Bagged Canister...
My wife has sucked something into vacuum and now it won't ****. Can you help?
I would suspect a blockage in the pipe , check if the brush on the base unit turns if not you may have a broken belt. If brush turns you have probably got blocked pipe or base unit I have sometimes pushed stiff wire to clear pipe of blockage.
pete
Nov 08, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
Floor level brush stopped rotating after it caught
Look at the bottom and check a thread of carpet isn't wrapped around the brush, if so try pulling it off or carefully cutting it off. You'll probably see a collection of fluff etc above the brush that's stopping it from sucking up, pull this out, or it just may be that cause the brush isn't working its not picking up.
If this helps please rate me
Jun 20, 2010 | Bissell 6594 PowerForce Bagless Upright...
My brusg stopped turning after sucking up a shoe
Hi There is a reset switch on your Dyson that needs to be pressed when something gets stuck in the brushes. The reset switch helps protect the motor that spins the brush from damaging if something gets stuck inside the brushes. There is a little red pole that sits up behind the brushes on the vacuum head, I believe it's on the left side of the floor head as if you were behind the machine vacuuming. Try pushing this reset switch first. Did this fix your problem? If no, please let me know and I'll be more then happy to do some more advanced diagnosing with you.
May 02, 2010 | Dyson DC25 All Floors Bagless Upright...
My oreck vacuum has stopped sucking up things.
It won't turn the brush because the belt is stretched or broke from the heat of sucking something too big up. If you have your service manual it should show you the location of the belt covers to replace it.
Dec 03, 2009 | Montgomery Ward Oreck XL Celoc...
Motor bogged down, smelled rubber, brushes stopped turning
This repair would require motor replacement, based upon your explanation.
Sep 18, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Steam vac will not pick up dirty water
My Hoover Steamvac problem isn't with the bruches--it's with the suction. Dirty soapy water stays in the carpet instead of being returned to one of the holding tanks.
Oct 21, 2007 | Hoover SteamVac F5914-900 SpinScrub...
No sucking
Could be that the dust cup filter is clogged, part #60958, or the inlet down by the brush roll is clogged.
Oct 01, 2007 | Eureka 402A Bagless Upright Vacuum
Eureka 3276AVZ Bagless Upright Vacuum Logo
21 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Irene Tulloch
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
