Question about Radio Communications
..Please tell me how to reduce the transmit-receive delay in Yaesu FT-6OO?
No "Delay" trim-pot...need to reduce the transmit-receive delay, it's too long...
    Prodigy:
    An expert who has answered 500 questions.
  • 607 Answers
Hi Lubomir,
There is a solution to the problem.
Join yahoo group SPECIFIC to your radio Make/Model, the technicians on that site will need as much detail as you can give them, so they can help you fix the delay issues. It's FREE to join and you can download manuals, schematics and other goodies for you radio.
I hope you find my advice helpful.
Best regards,
Peter
Posted on Mar 06, 2013
sharcnet
  • 2130 Answers
SOURCE: alinco dj-v5 HT deviation adjust
To adjust the deviation of this radio, you don't have to take it apart. If you take the battery pack off, there is a sticker on the back of the radio saying Alinco. Pull that sticker off and underneath are the variable resistors. See the service manual for more details on how to make other adjustments.
First, make sure you note the present position of this pot so you can turn it back if you have to.
If you don't have any equipment to measure deviation, make a contact on the repeater and try turning the pot in small increments and ask the person to help you set the deviation so your voice sounds good through the repeater.
Once set, if the repeater has a touch tone test, go through and make sure all your tones are being properly decoded.
Please let me know if I can be of further assistance to you.
- Jim
KA3EBX
South Hills ARC
www.sharc.net
Posted on Feb 26, 2008
robshow
  • 367 Answers
SOURCE: I need user manual for Yaesu ft-416
Click here for pdf user manual for YAESU FT-416
Hope this helps
Posted on Jan 16, 2009
  • 11 Answers
SOURCE: I need to replace the internal lithium battery on
I have a Yaesu FT-415 and the same problem. My original battery is a SONY 1220-VJ2H (solder tabs, blue insulation on the outer edge and two stick-on paper insulaters) and is soldered in to the Control PC board (mounted vertically). I'm going to get a new battery and hopefully am brave enough to get the soldering iron to the board. It looks like you have to unsolder the board from the speaker to lift it up enough to get at the solder tabs on the battery, luckily I have access to a Pace soldering station with a vacuum pump. I'll hopefully try this next week and get back to you all.
Posted on Jul 11, 2009
SOURCE: Yaesu FT-416 not Transmitting
Check the connection going to the BNC antenna connector from the circuit board. I have seen this wire break before. KB9EKH
Posted on Aug 26, 2009
  • 211 Answers
SOURCE: yaesu ft 1500 m
Here you can see the schematics http://www.repeater-builder.com/yaesu-vertex-standard/ft-1500/ft-1500m-sch.pdf
The manual can be found on the Yaesu website, http://www.yaesu.com/indexVS.cfm?cmd=DisplayProducts&ProdCatID=106&encProdID=92FB2363C1E0B9EBC9D3479054E0120B&DivisionID=65&isArchived=1
Good luck,
Gerard
Posted on Jan 30, 2010
Radio power`s on but no transmit or receive on ssb however it will transmit with full power on fm
If your receiver was operating previously but now the SSB option is not working, very likely the sideband detector has failed. I'm not directly familiar with your Yaesu unit but, in most Yaesu transceivers, the SSB chip and control circuit (including diodes) is identified in print on the main board.
May 16, 2015 | Yaesu FT-990 DC Transceiver
Yaesu ft-990 no receive or transmit
Lynn, SSB (Single SideBand) only applies to AM (Amplitude Modulation) transmission. There is no way to broadcast SSB in FM (Frequency Modulation) mode.
May 16, 2015 | Yaesu Radio Communications
Yaesu 270 not transmitting nor receiving
Hi this can be down to many reasons, radio keypad locked, receive on tone squelch, set on "Relay" or "Repeater", or even radio failure. Without the radio I cannot help, but that may give you some ideas.
Feb 14, 2015 | Yaesu Ft-270r Vhf Ft 270r Ft 270 R
How to turn beep off when transmitting
all the beep is for is so people can tell when you are done transmitting. There should be a push knob or button or just a plain old knob that has R.B. printed next to it . Turn it off.
Apr 12, 2014 | Yaesu FT-2900R 75 Watt 2 Meter VHF Mobile...
Any frequency over 148.000 i cant talk on, i can just listen. anyone know why?yaesuft1900r
The Yaesu FT1900R is an Amateur (Ham) Radio 2-meter Transceiver. Although the receiver covers from 136-174 MHz, will only transmit from 144-148 MHz. Please note that you do need an Amateur (Technician Class or above) License to transmit on the 2-meter Amateur Band. You no longer need to pass a Morse Code test to get an Amateur License. You still have to pass a written exam, but that isn't difficult if you are willing to study a bit. Contact your local Ham Radio Club or the American Radio Relay League (A.R.R.L.) for more information.
Dec 26, 2013 | Yaesu Ft 1900r Vhf Mobile 55 W Two Way...
Just got a Galaxy DX 2547. Barefoot works GREAT. Problem: When connecting to my linear (Texas Star 667V) rig fires up AOK on AM but on SSB it has issues driving the amp. SWR is OK Radio SSB output ~...
Have you tried turning the mic gain up,and not knowing Texas star model numbers,is it a mobile linear,if so,do you have a sufficient power supply?Just some thoughts off top of my head.
Aug 22, 2011 | Galaxy Radios DX-2547 40-Channels Base CB...
How do i get expanded freqs on my ft1802 yaesu tranceiver
The FT-1802 is a 50 watt 2 meter FM transceiver. It can transmit anywhere between 144 - 148 Mhz (the FM portion) of the 2 meter ham band. It can receive anywhere between 136 - 174 Mhz without any modifications. There is a modification to enable transmit "out of band" below:
http://www.ham.dmz.ro/yaesu/ft-1802-extended-transmit-modification.php
There are few details about the results of this mod - typically these provide for transmitting on frequencies outside (above, below or both) of the 2 meter ham band. Transmitting outside of the ham band without a proper license for the frequencies in the U.S. is a violation of FCC rules.
Sep 08, 2009 | Yaesu Radio Communications
PPT works in the lower bands (under 148 Mhz) but not 156 range
Your radio has not been modified to transmit outside of the amateur bands.
Jun 07, 2009 | Yaesu NABC NABC LMR NICD BATTERY FNB-29...
Baby monoitor reciever piking up no sound or delayed sound - link light flashing
A delay may be caused by interference from other radio sources. I heard of one case where a woman's cell phone call overpowered the transmit power of her baby monitor.
Other things that can cause interference or other receiver problems:
1. monitor in contact or close proximity to running appliances or their cords. (induced electromagnetic field)
2. neighbor with baby monitor on same channel ('cross-talk')
3. distance between transmitter and receiver too far (the strength of a radio signal fall dramatically over larger distances. think of how often you lose cell phone coverage)
4. reduced power: low battery strength or cooked power supply
5. transmitter or receiver insulated from signal (if your monitor was transmitting/receiving through any metal obstruction)
May 07, 2009 | Kitchen Appliances - Others
Ref: YAESU FT 102 TRANSCEIVER [1] My bias normally between 75 - 85 ma begins to creep up after a few minutes of operating, using push to talk. On ceasing speaking and listening, it is OK but on the...
Hi John,
You have thermal run away in the PA bottles. Change all three for new ones and you will cure the problem.
With regards to the VOX make sure the DELAY control is not set to high, located above the RF amp button.
Regards,
Paul (G4KWM)
Apr 03, 2008 | Computers & Internet
Radio Communications Logo
110 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
