Question about HP StorageWorks Ultrium 448 LTO 2 Tape Drive
Fan power fault - HP StorageWorks Ultrium 448 LTO 2 Tape Drive
Hf3163tn fan and heating element not working. has power to elements and to switches
I'm not familiar with model number;but with fan ovens ,if the fan fails the element it blows onto will over heat and burn out .Its a common fault .
Check for power on fan and element .
If fan doesn't run with power on, or runs slowly or stops occasionally and element with power on does not heat,both will need replacing.
Good luck.
Feb 21, 2018 | Ovens
Tip
Ducati Fault Codes
Engine Fault Codes - Ducati 749/999
To see the fault codes, with the ignition off hold both dash buttons down and turn ignition on.
1.1 TPS Disconnected
1.2 TPS short circuit to earth
2.1 Pressure Sensor short circuit to power supply
2.2 Pressure Sensor shorted to earth
3.1 Water Temp Sensor shorted to power supply
3.2 Water Temp Sensor shorted to earth
4.1 Air Temp Sensor shorted to power supply
4.2 Air Temp Sensor Shorted to earth
5.1 Battery Hi
5.2 Battery Low
10.1 Hor. Coil shorted to power supply
10.2 Hor. Coil shorted to earth
11.1 Ver. Coil shorted to power supply
11.2 Ver. Coil shorted to earth
12.1 Inj1 shorted to power supply
12.2 Inj1 shorted to earth
13.1 Inj2 shorted to power supply
13.2 Inj2 shorted to earth
14.1 Inj3 shorted to power supply
14.2 Inj3 shorted to earth
15.1 Inj4 shorted to power supply
15.2 Inj4 shorted to earth
16.0 Pump Relay
17.1 LH Fan shorted to power supply
17.2 LH Fan shorted to earth
18.1 RH Fan shorted to power supply
18.2 RH Fan shorted to earth
19.1 Starter Solenoid shorted to power supply
19.2 Starter Solenoid shorted to earth
30.0 ROM/Eprom error
34.0 Signal Panel Sensor
36.0 Speed sensor
37.0 Immobiliser (transponder)
37.1 Immobiliser (antenna)
37.2 Immobiliser (instrument panel serial driver)
37.3 Immobiliser (serial cable disconnected)
37.4 Immobiliser (ccm serial drive)
37.5 Immobiliser (key not recognised)
37.6 Immobiliser (ccm program)
38.0 Can Line error
Source http://moto-files.weebly.com/ducati-fault-codes.html
on Dec 20, 2016 | Motorcycles
NEC LCD1760V shuts power down after 3seconds
Hi Ron usually power down issues are caused by faulty power supplies especially if the projector looses power completely however the logic board could be protecting itself if it detects a fault such as a fan not working either way it is not recommended that you try to fix it yourself unless you know what you are doing, but it may be worth removing the cover and checking that the fans are working and connected properly, occasionally the lamp can be at fault especially if it has been used for many hours if the projector tries to power up and you see light through the lens and then it looses power its probably the psu at fault, if it powers up then goes into standby of fault then its most likely a logic issue. I hope this helps Regards Ant
Nov 30, 2011 | NEC Office Equipment & Supplies
Code po560
You will find all Diagnostic Code details available at http://ww.bluejag.co.uk .
This code P0560
Fault Code:- P0560 Indicates a Power-train fault
The fault is generally due to a problem in the Vehicle Speed & Idle Control area
Fault Description: Battery power supply voltage malfunction Note: This DTC can be flagged due to fuel injection pressure sensor fault. If P0193 is also flagged, correct first.
Action of ECM:- none
After clearing the DTC, complete the Engine temperature cool (cooling fans not running) Remove ignition key for 20 seconds (cooling fans not running) Ignition key in, position II for 5 seconds (do not start) Repeat cycle two additional times
Check for a reoccurrence of fault DTC.
Possible Fault:- ECM battery power supply open circuit, high resistance
Jun 18, 2011 | 2002 Jaguar X-Type
Sanyo plc-sw30 i have a problem when i power on the projector , there is no power lamp on a very slow light is visible and the projector shut down and the fan are in very high power
The uProcessor thinks that it has overheated and is frantically trying to cool down what it thinks is a hot lamp.
This condition has many causes from an exhausted lamp to lamp ballast fault or even a power supply fault or a heat sensor/fan fault.
Mar 30, 2011 | Sanyo PLC-SW30 Multimedia Projector
Good morning. I have a Bosch Worcester Greenstar 28i Junior. As the fan statrs up the mains power trips out. Is it the fan at fault or could there be another/different fault.
it could be the fan or the pump best thing to do is disconnect fan and start it up and if it does not blow that the problem
Feb 04, 2011 | Heating & Cooling
REMOTE DOES NOT WORK FAN OR LIGHT
Surely the fault in the remote control. open the remote is out off warranty and look for fault in the crystal or the IC. Solder and check, also the power connection and battery. If none work the IC can be faulty.
Sep 01, 2010 | Hampton Bay B52852WPB Redington III White...
Intermittent fan problem - fan regulator likely?
As it's an older car maybe the fan motor brushes are worn out, otherwise could be a coolant sensor internal fault or wiring fault somewhere. You need a wiring diagram so you can understand how power feeds fan and what switches it on/off, then you can look for a solution.
May 08, 2010 | 1999 Mercedes-Benz E-Class
IGBT FAULT ERROR KEEPS OCURING ON DF6 340 IVERTOR INVERTOR HAS RUN 14 INTAKE FANS FOR ABOUT 4 YEARS NO OVERLOADS ARE TRIPPING ETC
E30 IGBT fault If an excessive current is applied at an IGBT (transistor in the power end stage), the output voltage
is switched off to protect the transistor.
Sounds like maybe a fan has gone bad and is drawing too much current.
Try disconnecting the fans and reconnecting one at a time. Also check
the fans to make sure they turn free and are not blocked.
Aug 17, 2009 | Electronics - Others
Problem of motherboard
Could be a power supply fault, motherboard fault, or fan fault. Many new motherboards will not power up if the fan doesn't rotate, to prevent the processor getting fried.
Dec 06, 2007 | Intel D101GGC Motherboard
HP StorageWorks Ultrium 448 LTO 2 Tape Drive Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
