Question about Honeywell Intellisense IS2535T 35 PIR Motion Detector w PetImmunity Tamper
I have a dt-725d pir alarm activated now red light on pir is on and can not reset alarm on keypad taken front off pir nothing happened 5 other pirs ok
After power cut and alarm activated could not rest alarm and noticed while all pirs except 1 were ok the the red light on 1 was on the pir flashes when there is movement detected but stays on red have taken the front off the pir and nothing happened no tamper alarm sound, alarm will now not rest or claer
3 Suggested Answers
SOURCE: PIR Intruder alarm magnetic contact
Hi Bowdi,
Please find the below the information on the contacts.
You will fine two silver screws - This is your Alarm pair and this will go back to the alarm zone on the panel PCB.
The three other brass screws are just junction screws so you can join the cables to go to other doors.
You will need to join the black and blue together to make the tamper circuit.
Regards will
Posted on Sep 06, 2009
szanti
  • 36 Answers
SOURCE: MY HONYWELL PIR HAS 8 WIRE CONECTIONS WHICH ONES
What model is it
Posted on Nov 28, 2009
Hello I have my veritas security alarm ringing and it won't stop ringing after we put the reset code.something blew off while the electrician was fixing a fuse in the utility room
Looks like a blown fuse if you have pir detectors make sure that they are working, if not change the aux fuse in the control panel.(blown).Must be same type as original
Also check the power light on the main panel,or keypad.
Jan 02, 2018 | Cars & Trucks
PIR switches and house wiring is incompatable?
Several possibilities. First use standard light bulbs until it is working. Some of the PIR have triac outputs which need a minimum amount of current to work. CFL and LED lights can be a problem with electronic switches/dimmers.
The PIR needs electricity to operate. The black and white wire are probably power and return, there is no neutral to connect to the PIR. Unless you can get a different PIR that does not need line power to operate you are out of luck. There may be some that can cycle steal power and would work but I am not familiar with them.
I assume the three way is a three way PIR and the lights that are flickering are electronic such as LED or CFL.
If you talk to one of the people where you bought the switch they may help you free of charge.
Good Luck
Feb 23, 2014 | Electrical Supplies
How do i use the flash so it will take pics at night? and what does PIR mean on the menu shouldi set Hi Lo or Med?
hi ,ill be suprised if theres a flash , it should just automaticly switch to night vision using infra red light,, as for PIR,,p.i.r stands for
passive infra red,, its like a beam that when disrupted will switch something on , in your case, "take a shot"the high medium and low just refer to sensitivity,,mouse , cat, dog . elephant ,
Oct 15, 2013 | Wildgame Innovations Axe 2 2Mp Game Camera
LINTECK LS400 WONT DISARM
You have most likely "bought a duffer" I have 30 years experience with alarms.
!. Remove the internal battery, power down the panel.
2. leave "dead" for 10 minutes.
3. reinstate the power, Mains first then refit battery (Make sure terminals are correct for each wire)
4. Retest.
If the above does not work give Lynteck a call on
  • 01282 717 490
  • email sales@lynteck.co.uk
Mar 05, 2017 | Home Security
Wiring diagram for a p i r to a light
They all wire the same. The black wire on the PIR connects to the incoming (usually black) hot or switched wire. The red wire on the PIR connects to the light(s), usually a black wire. The white (neutral) wire from the PIR connects to BOTH the incoming white wire and the white wire that goes to the light(s).
Jan 17, 2012 | Home
Scurity penal temper
seems one of your tamper swicthes has been activated,you should be able to isolate which one is needing attention and mute the sounder too
It is common for the tampers to fail in very moist conditions ie outside siren boxs exposed to the elements or a rodent has chewed thru your wiring
i could be a simple as a spider sitting on the tyamper switch in side the box.
If your alarm is monitored then you will have to call an alarm company to fix this for you unless you have the right skills to trace isolate and repair this problem,
May 26, 2010 | GE Security GBC-PI-950-P5 Pir Camera...
Hi Liam here I just installed a networx nx4 and when powered up key pad has 1,2,3,4 flashing rapidly with service light on I was able to get rid of service light but zones still flashing And there is only...
This could be a supervision problem. If zone expanders, gsms, keypads, etc. are added to this alarm panel, you must enroll the device with the control panel. This is done by entering into programming mode ( * + 8 + {go code} ) and then simply exiting programming mode by hitting the exit button. The GE NetworX control panel and it's affiliated compatible devices will auto-enroll after about 15 seconds. The default 'go' code is 9713, but this is usually changed by the alarm company installer.
Apr 21, 2010 | General Electric GE NX-591E-GSM NetworX...
Honeywell Intellisense IS2535T 35 PIR Motion Detector w PetImmunity Tamper Logo
Top Honeywell Home Security Experts
Sean
Mike
Are you a Honeywell Home Security Expert? Answer questions, earn points and help others
