Question about Dishwashers
Hello, My dishwasher Ariston LI 480 A does not work, When the power-on button is pressed, there is no sound for being ready and a washing program can not be selected, The last washing there were sounds as it is finished and all lights were on, and after closing the door it started with Rapid program, Thanks in advance, Linda
  • 190 Answers
SOURCE: My Ariston LI 700 I dishwasher doesn't complete wash cycle
dear customer,
 we recommend u to perform the following checks on ur dishwasher,
  1. Test the timer motor
  2. Test the thermostat
  3. Test the heating element
for more details for self test instructions try the link http://www.acmehowto.com/howto/appliance/dishwasher/dishwasher.php
Plz rate this solution.. thank you..
Posted on Apr 08, 2009
SOURCE: Rotary switch selection of washing program.Whichever one selected - machine sounds to start up, whether or not the start button is pressed. However no sound of washing kicks in as was usual and eventu
Found a local man on the internet, who popped in and leant the machine forward then backwards and then flushed out the system, explaining that the program cycle had gone awry and there was water where there should have been air and so microswitches had not triggered in the right sequence. All fine now.
Posted on May 08, 2009
SOURCE: Ariston LI 45 door will not remain closed and will
Strip the door and re-set the switch. Ensure the metal part of the catch on the machines main body is not distorted
Posted on Jan 02, 2011
heatman101
  • 43501 Answers
SOURCE: Hello. My dishwasher is ARISTON
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Posted on Jan 06, 2011
Macmarkus
  • 2605 Answers
SOURCE: Dishwasher is shutting off. I select the wash and
Hello Maureen Johnson, welcome to FixYa.
I'll start by acknowledging your post indicates the problem is with your dishwasher not starting/functioning, however if you could post the complete model & serial number I would be better equipped to help you further. If you could also verify it is a Viking (built by Asko) as the header suggests.
I'll look forward to your reply and try and help you move forward from there.
Thank you. Regards,
Macmarkus :)
Posted on Jul 21, 2011
I have an Ariston 640 LI dishwasher and no water seems to be flowing into the dishwasher
hi there Mellisa, Is the tap turned on? if it is in may be the inlet valve at fault you will need to have it checked it see if the valve is recieving the open command from the controler. let me know if this helps, regards
Gary
Oct 16, 2011 | Ariston Technologies LI640S Dishwasher
Hello. My dishwasher is ARISTON HOTPOINT LI 480 A, built in. While washing, something cracked inside, and a white smoke appeared in the upper right of the machine. Can you help me with this ? Thanks in...
heatman101
Jan 06, 2011 | Dishwashers
Jan 31, 2010 | Ariston Technologies Dishwashers
Hi, my dishwasher type ariston LI 420 does not drain.the led 1 and 2 from left side blinking. Can you suggest me somethings. there's a file with the error led code to consult. Thanks' in advance
you might have a blockage in your filter or in the pump,first i would find out where your waste pipe goes out to if it is plumbed out through ur sink take the hose off and hold it in a bucket and turn the unit on you should hear a sucking sound and if the does now drain then have a look in the sink waste trap it is very common for the sink waste to get blocked
Oct 21, 2009 | Ariston Technologies LI640S Dishwasher
DIshwasher wont start, flashes pre-wash and was lights
1) Ensure the dishwasher is turned off. 2) (may not apply) Turn the plastic blue lever located under the sink to the vertical position (this opens the valve, so water can go into the dishwasher) 3) Pour powder indo the dishwasher 4) Turn the dishwasher controller to the top position (the 12 o?clock position) ? this is the eco-setting. 5) Press the on/power button on the dishwasher, so that it now turned on (a light will display) 6) Move the dishwasher controller to the ?R? position (it?s on the very left), and leave it there a second or two. 7) Move the dishwasher controller back to the eco-setting (the 12 o?clock position).
Apr 19, 2009 | Ariston Technologies L63SNA Stainless...
dear customer,
Apr 08, 2009 | Dishwashers
Need to find parts dealer for Ariston dishwasher
Please let me know where I can order replacement part for LI 700-NA I need a water valve, serial number of that part 409245172. Thank you
Feb 02, 2009 | Ariston Technologies Dishwashers
Ariston Dishwasher LI 675 DUO
4) Turn the dishwasher controller to the top position (the 12 o’clock position) – this is the eco-setting.
6) Move the dishwasher controller to the “R” position (it’s on the very left), and leave it there a second or two.
7) Move the dishwasher controller back to the eco-setting (the 12 o’clock position
Sep 16, 2008 | Ariston Technologies LI640S Dishwasher
Stars cycle thin stops lights reg and eco start blinking
Clean out the filter really well, then replace it. This should reset the dishwasher. If it does it again when you try to run the dishwasher. Take the filter out and re-seat it. Some times it's not sitting exactly right. Good luck and I hope that helps.
Mar 04, 2008 | Ariston Technologies LI640S Dishwasher
Dishwashers Logo
287 people viewed this question
Top Dishwashers Experts
