Question about Reebok Exercise & Fitness
I have a rodgerblack gold treadmill ag-10302 when i switch it on at wall it trips the circut in my fuse box help please
    Top Expert:
  • Reebok Master
  • 12,223 Answers
1) please use a table lamp in connect in wall circuit. if the c.breaker trip again, the problem is your outlet wall. Call electrician or test the wires for touch each other or ground improperly, and fix it.
If the circuit is NOT trip, test the power cord for defective 2) test the main switch for shot circuit 3) test the c. breaker for defective 4) test the motor see the if the motor if short circuit see my personal TIPS for help motor , see the diagram attached. 5) test the output board, the board can be short circuit and replaced. Happy NEW YEAR God bless you
i have a rodgerblack gold treadmill ag-10302 when  - 12_31_2012_3_44_50_pm.gif12_31_2012_3_45_16_pm.jpg
Posted on Dec 31, 2012
  • 175 Answers
SOURCE: when the machine is switch
hi..It is next to the switch where you turn on.Open the
casing that stores the motor etc.Should be able to locate
it there,usually hidden inside a capsule.
check it out..
thank u..
kindly rate my response..
Posted on May 09, 2009
SOURCE: looking to find a user manual for Roger Black Gold
Hi I just found out where to get the manual ring 0845 6000 464 they should be able to help - ive been trying to get a manual too and had success at last from the Reebok Tech team, they were great and fast too! Gd luck!
Posted on Mar 24, 2010
maxtreadmill
  • 832 Answers
SOURCE: I have a Horizon elite 507 treadmill, everything
Unplug your treadmill and remove motor shroud ,locate Motor control board their a series of LEDs . Now without getting on treadmill hit start look down and you should a light starting to flicker this is your PWM signal, t the upper console sends a signal to the lower board and instructs the motor to start. This tells me that the upper board and cable are functioning properly and our problem is either the board or motor.
DC motors can be easily tested in a number of ways. Many times a motor is replaced only to find another problem exists so be sure to test the motor if you think it is a problem. Methods to test a motor: 1) Cordless drill battery- get a fully-charged, 18 volt (preferred) cordless drill battery and on most treadmills connect the red and black motor leads to the battery (some have different colors but if you have two wires and get it hooked up backwards, the motor will just run backwards and won’t be harmed). If good, the motor should operate at about 1 MPH. 2) Car battery- these are 12VDC high amp batteries so the motor will turn slowly but you can walk on the belt. Always be careful with battery acid on these things so we don’t recommend bringing them in the house…take the treadmill to the battery.
If the motor test good then all fingers point to the Motor Control Board replace the board. When was the last time lubricated the running deck?
Answer: Never ! Then I suggest you purchase lubricant and apply it on the deck about 75% to 85% of the problems are belt and deck related.
Posted on May 23, 2010
Testimonial: "Many thanks for prompt response, seems that the treadmill works only when in the upright position and not the horizontal as per normal. Gonna have to learn to run up walls i guess"
  • 5370 Answers
SOURCE: Horizon Fitness Treadmill - Quantum
Check the treadmill "continuity" , the treadmill connections correctly grounded. If that is checked ok then either the outlet itself is bad .Try plugging the treadmill on another stronger outlet, such as a kitchen outlet..But if its still shorting out and blowing the fuse then its internal motor problem.The motor or its wiring is got weak,so when you press the start button the motor starts and treadmill turns off and blow fuse.--------- This should help.Thanks.Helpmech.
Posted on Jan 23, 2011
ercupa190
  • 12223 Answers
SOURCE: treadmill trips internal fuse/switch after 5 to 15 minutes of use
Dear Sir:
I will try to help you.
Please use the videos with patience+and carefully.
You must use some basic tools and Dvom(DigitalVoltemeterl):
http://www.youtube.com/watch?v=-oeXTKqWECw&feature=related
http://www.youtube.com/watch?v=GPI6dFJCUA4
http://www.youtube.com/watch?v=hKbAqvuOBS0&feature=related
http://www.youtube.com/watch?NR=1&v=KiEZDNe0F8Q
http://www.youtube.com/watch?v=GdlAxZHLDys&feature=related
http://www.youtube.com/watch?v=AFuRo2zHpCg&feature=related
With this videos you will be available to fix it.
If you need further assistance, please reach me.
sincerely. God bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Posted on Oct 21, 2011
Roger black AG-W11306 been walking on treadmill for about 20 mins when it cut out and tripped the main power breaker switch cutting out TVs and all electrics in house any ideas
bfe672f8-10b0-4eca-a009-dc9848741c38.gif1) LUBE the treadmills very important with silicones or waxy READ your owner manual
2) Run the software calibration for diagnose and fix it.
3) Measure the input voltage motor
4) measute the output voltage from controller board for input voltage motor.
Jun 03, 2013 | Exercise & Fitness
My reebok z7 treadmill wont switch on
1) put some desk lamp in the outlet wall, if lamp is ON the circuit is o.k if NOT c.breaker of fuse are blown or tripped, replace and reset .
2) otherwise, test the power cord for open, and break.
3) test the power switch for defective.
4) reset the c.breaker and test the fuse replace and reset
5) Try again. if the problem persist the problem is around the power supply see the block attached.
God bless you
Sep 05, 2012 | Exercise & Fitness
My york treadmill keeps tripping all the electric in my house
1) Unplugged the treadmill, and test if the c. breaker from your house is tripped.
2) If continuos tripped the problem is your HOME, and NOT in the treadmill.
3) Connect the treadmill, if the treadmill NOW tripped the problem is Treadmil.
4) Test the power cord for cross wiring and repair, AVOID any extension cord for feed the treadmillL DO NOT USE.
5) See if the outlet box in your wall is o.k some wires touching between provoking short.
6) open the treadmill, and test the power button for short and replace, see if there are some wires touching the chassis of the treadmill and repair.
see the block diagram and troubleshooitng.
God bless you
Jun 28, 2012 | York Exercise & Fitness
Problems with my proform 397 treadmill
Dear Sir:
Please do the following:
http://www.youtube.com/watch?v=jH3ctwTvdVo&feature=related
http://www.youtube.com/watch?NR=1&v=inR6gJ0_37w
http://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=related
To usethese instructions, you need to have a familiarity with electricity and aworking knowledge of a voltage multimeter. With all of these tests, USEEXTREME CAUTION!!! Never let the voltage ground directly to any part ofthe treadmill or your leads ground while you
are testing voltage.
1)To begin, set your volt meter to AC volts. We are going totrace the power from the wall outlet through the
treadmill to see where it ends.
2)
With the treadmill unplugged, test the wall outlet. You should have from 115 to125 VAC. Optimally, you will
have at least 120 VAC.
3)Follow the power leads from the power cord to the lead ends.With the treadmill unplugged, connect your
meter to the lead ends. Plug the treadmill in and check your reading. It shouldbe the same as your reading
from the wall outlet.
4) Continue this process with the electrical system, following theleads, as they pass through, breakers, fuses,
and the like.
5)Where the power flow ends is where your problem is. Sometimesit will be in a bad connection, sometimes
it will be in a shorted breaker or blown fuse, at times it may be as simple asa safety switch not working
properly, or it may be a major problem with a component.
5) In some cases, components work in tandem (i.e.- a controllermay need a signal from the console
computer to release voltage to the motor)
TESTING FUSES, BREAKERS, WIRING, AND SWITCHEST
1) One of the most common problems with power outages is problemswith fuses, breakers, wiring, or switches.
2) If your treadmill is equipped with a safety switch, set yourvolt meter to continuity. Touch your test leads together to make sure you
are getting a closed circuit. With the treadmill unplugged, back the leads offthe safety switch, usually near the upper display computer.
With the safety key out, test the switch. It should be open. Push the safetykey in. Your circuit should be closed. If this tests ok, move to
the next step.
3) While testing for voltage, you can unplug your treadmill andtest the fuses, breakers, and wiring harnesses. Sometimes a breaker may
have shorted open and not tripped. Test these components individually. You wanta closed circuit on all of themSincerely. God bless you. If you need further assistance, please reach me.
E.CUADRA
MANAGUA, NICARAGUA.
Oct 28, 2011 | Proform Crosswalk 500 Treadmill
When i turn on my treadmill it makes a strange sound then the trip switch goes on my electric box..only bought it today second hand and i really need it as i hav had 3 spinal fusions and neck fusion and...
12_7_2011_9_47_46_pm.gifPlease observe the block diagram that I did for people like you. Now you will have a great Idea how going on in the treadmill. example: 1possibility: Capacitor in short 2) Coil in short 3) Main Motor short 4) Main Motor controller board short.
Now you will have a voltemeter and make the test.
Alternatives #2
Finally I am suppossing the electric box is from your house. In that case there are not the problem mentioned before since the treadmill has internal fuse will be trip. So you can test the power cord, if some wires is touching with the other, or if the ground in Outlet from you wall is Not o.k that produce a Ground. Please do not use extension cord, that extension there are NOT good dimension by carrier enough amper aprox 20amp, this will be strip the BREAKER or fuse in your house. If you have a doubt call a electrician to inspect your ground where you connect the treadmill. sincerely.
E.CUADRA
MANAGUA, NICARAGUA.
Apr 03, 2011 | Proform 560hr Treadmill Walking Belt
Haven't used my ProForm 585s in a couple of months, now when I insert the key, no lights or anything. We've hit the reset button and checked outlets and such. Suggestions?
Your on the right track. If power is coming from the wall, it goes through the circut breaker ( red switch next to the power cord entrance), then it goes to the motor controller, the up to the console switch at the magnet/kill switch. To verify that you are getting power past the circut breaker, remove the motor hood. You can now see the motor controller on the left ( opposite the motor), it will have a red light on when it has power. If you dont see that light check the circut breaker.
Let me know,Matt
Dec 10, 2010 | Proform 585 CS Treadmill
Looking to find a user manual for Roger Black Gold Treadmill AG=12302 if anyone could advise where I could obtain a copy
Feb 27, 2010 | Exercise & Fitness
When the machine is switch on from the main socket and than on from the machine on /off switch, it trip the whole house fuse box.I have change the 13amp.plug fuse, I cannot locate where the machine...
check it out..
thank u..
May 09, 2009 | Exercise & Fitness
Roger black gold treadmill
Me neither. I can switch it on but cant get it to do anything :(
Apr 30, 2009 | Exercise & Fitness
Exercise & Fitness Logo
469 people viewed this question
Top Reebok Exercise & Fitness Experts
Electro Med Services...
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
