Question about Baumatic 18 in. BDW45.1 Built-in Dishwasher
Tablet holder keeps opening trigger going off all the time
Tablet RC6272W23 will not turn on ..?
attach to usb connected to computer an trigger it on . pull an push cable its a trick take ur time . it might go into debug menu mode
Jan 12, 2015 | Tablets & eReaders
No matter how Long I charge my tablet it won't turn on how can I fix that?
connect it to a computer usb an turn it on randomly pull an put in cable same times it will trigger it to go into debug menu likely . dont get in a hurry
Jan 05, 2015 | Tablets & eReaders
How do I set the system time on a seven inch dragon touch tablet
Hi Leah,
Here is the short answer:
  1. Go to settings,
  2. Open Settings Area, go to Date and Time
  3. Tap "Set Time" to manually set the time and date,
  4. Un-tick the "Automatic" feature to keep the manual setting.
Here is a good tutorial: How to set the time date and password on an Android tablet
Hope this helps.
Dec 28, 2014 | Tablets & eReaders
I was taking a shower and the team got into my next book 7 now i cant get pass the loading screen how can i fix steam damage
first thing i got to ask..did you try using a hair dryer on low heat to dry your hair and tablet after u figured out eletronics and water dont mix?
next time try a ziplock bag to keep it dry..ahaah. just kidding.
here is a link i use to walk customers thru opening up a tablet..follow it close.. if open it up and use a soft cloth and gently dap any standing water..then let it AIr dry for 24hrs..then if still not working..plug in power for while to warm up..use a hair dryer on low to dry any hard to reach spots..if it still doent power up...use it for a soap holder and buy new one
good luck
chad man
Oct 08, 2013 | Nextbook Tablets & eReaders
My DeWALT DW936 Type 2 Trim Saw is coming on and turning off and I have to push the trigger several times for it to come on, I'm not sure if it would be the brushes or the trigger.
Sounds like the trigger,you would see sparks if the bushes were going out and a loss of power would be present as well.I use cardboard or Styrofoam(push them in) to keep track of bolts and a magnet for the small stuff.
There are two types of brushes,the ones that come out of the saw and and the ones that are held back with a piece of wire in holes in the front of the brush holders.After assembly the wire is pulled through the vents.Thank you for choosing FixYa.com.
I always add this for your information. If this is not the solution that you are looking for please re post because when we pick a question to answer FixYa takes it out of the question queue.
May 27, 2011 | Garden
Soap dispenser doesn't open
My recommendation is to switch over to a tablet and merely put the tablet on the floor of the dishwasher bypassing the soap holder all together. It should work just fine that way. good luck.
Dec 29, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
Update for 150x150 hoop
If you have a light gray button then you need to have the embroidery unit upgraded. The hoop will fit on the machine, but the machine can not recognize the hoop. The new hoop holder that needs to be installed will have a second sensor trigger allowing the machine to recognize more hoops. The original holder only has one trigger and can only recognize earlier hoops.
Contact an authorized Husqvarna repair center to have your embroidery unit upgraded.
Nov 26, 2008 | Husqvarna Designer I
Help I can't thread my machine!!
Hi Jacqueline....I can honestly tell you that nobody over the internet can be more helpful or effective than what you physically have available to you right now. I truly understand what you mean regarding the manual "teaching" you the correct threading order, so just put it at arms length for now. When you're ready, open your looper cover, and methodically study the color coded guides, visually tracing from spool holder to looper, working your way from right spool holder to left spool holder. Take your time, and if angst or frustration begin to creep up on you, just walk away, and continue when you WANT to. The repetition in visually studying the color guides will trigger your memory. And when it does, you're not going to remember the right way, instead, you're going to begin to understand what is wrong, and before you know it, you will be reaching for that manual, but this time, the manual will indeed provide your answers.....please update your post with developments, and I will continue to do my best to help you....good luck my friend
Aug 01, 2007 | Singer 14SH654
Dishwasher tablet not releasing
sounds like the dispenser solenoid is faulty you will need to replace the whole unit, this involves removing the door panel.
Jun 08, 2007 | Indesit 24 in. DE73 Evolution...
Baumatic 18 in. BDW45.1 Built-in Dishwasher Logo
Top Baumatic Dishwashers Experts
Greg Cann
Greg Cann
Kolbrun...
Are you a Baumatic Dishwasher Expert? Answer questions, earn points and help others
