Question about Baby Gear
How can I repurpose the changing table I no longer need.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 67 Answers
When my kids outgrew the changing table, we simply removed the changing pad and used it as a dresser to store their clothes, which didn't cost a cent!
Posted on Dec 31, 2012
Thermal overload protector
Use the first part of the model number to fid who the manufacture of the saw/ motor is. Example: 110.123456- 110 is Whilpool. Then cal the manufacture direct. Also sometimes Grainger has direct replacements.
Jan 25, 2014 | Craftsman Sears 10" Table Saw Motor 62505
What is the history of the drafting table (drawing table)?
They used to be next to the desk in the study or library of a house in the preindustrial era and also in the early industrial era. During the industrial revolution, draftsmanship became a job so only those working in the field had these tables and they were no longer found in people's private homes. They were no longer built from wood and brass but rather from steel and plastic.
Jan 03, 2013 | Furniture
Is there an after-market up-grade for the rip-fence on my sears craftsman table saw - model 113.298151 ?
i need a replacement fence for my craftsman model #113.298762 craftsman no longer makes them . the only other replacement , i found was a delta 36t-30 t2 , which also no longer made thanks bill in ohio
Dec 19, 2012 | Craftsman Radial Arm Saw Table Locking...
What equipment do you need to use your diaper changing table? I bought a brand new changing table for my new baby but feel like I don't know what to do with it.
Don't worry, there's no right way to use a changing table. The important thing is to make sure you have all the right stuff with you before you start changing your baby's diaper as you can't leave them unattended half way through to go and get something. Check out this YouTube video that gives a detailed but easy to follow guide to changing tables.
Aug 14, 2012 | Baby Gear
Voice mail message will not change
Press the table button then enter in table 1
Jun 25, 2010 | NorStar Meridian M7310 Phone
Outdoor table with boken support strut on one side and folding mechanism no longer works
What a coincedence! I have the same problem on my Stiga Equinox. I have two ways to help u. U could order a new strut from wherever u bought this table, or you could get a longer screw for the strut(thats what I did) hope this helps u! :)
Jan 12, 2010 | Kettler Stockholm Outdoor Table Tennis...
Manual for #103.0205 circ. saw
Earlier comment 103.0205 Table Saws does not need lubrication is simply wrong.
The103.0202, 103.0203, 103.0305 Craftsman Companion Table Saws main Arbor axle DOES have to lubricated or else the axle bearing will quickly loosen side-to-side or vertically and fail to provide accurate saw cuts.
FWIW, Sears no longer sells Arbor Axle replacement parts... The Table Saw Arbor axle and Bearing Housing cannot use sealed bearings unless the saw case is re-milled and extensively modified. There are 2 Oil Hole Plugs (part# 475-32) that need to be opened and oil applied so the Arbor axle shaft does not get scored or worn.
I use 30wt motor oil to relube the Arbor Axle Shaft depending on amount of use, temperature, and axle rotation stiffness.
Remember, the higher the RPM speed of the table saw motor and/or the longer the use, the more frequently you may need to relube the Arbor Axle Bearing!
Nov 19, 2009 | Sears Saws
I need to replace my table saw switch assembly
I am not getting either # from sears parts. I deal in Craftsman Belt drive table saw parts. I should have a switch that would work for you. Can you send a picture? jimatcavanaungh@cs.com
Nov 03, 2009 | Craftsman Saws
Need help with blade changing instructions. no longer have the manual for this tool
First of you need to know it the thread is a right hand or left hand thread. This can be accomplished by removing the table plate and looking at the end of the arbor. Once you have determined that, you need a proper size wrench and a piece of scrap wood to jam between the teeth of the blade and the table top to hold the blade in position. Loosen the nut and washer to release the blade. Revers these steps to install the blade.
Mar 31, 2009 | Saws
Baby Gear Logo
432 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
