My currys essential washing machine beeps during cycle and stops help
Washing machine shakes on spin and makes an awful noise now it has stopped working completely during cycle it beeps continuously and will not spin I have swithced off by the mains and tried to restart the maching but it still continues to do the same
  • Washing Mach... Master
  • 17,130 Answers
Remove the power for sometime , check if the spindle is FREE and moves. , Remove the back and under side to inspect for any damage to the motor or drive. check the power lines, check on the motor CAPACITOR. Now when powering check the VOLTAGE to the motor. if this is low or absent then the program controller unit is faulty.
Posted on Dec 31, 2012
SolutionGuy
  • 331 Answers
SOURCE: Loud noise when spinning
I agree with Gittos on the bearing assessment. This considered part of the drive system. If it's less than 5 years old, your next move is to contact Sears and claim a warranty repair on the tranny (it has a 5 year warranty on it). If it's more than 5? Well, honestly it wouldn't be worth the repair. You'd have spent more money on all the parts required than what the unit is worth (worth= what it would sell for in working condition on the market). Hope it's less than 5!
Posted on Aug 12, 2007
  • 7 Answers
SOURCE: loud noise during spin cycle
this is my experience repairing the maytag washer Atlantis mav series 9750 aww, I had to replace the spin bearing since it was making a jet engine noise when it was spinning out the water. its not an easy job for my 1st time taking this machine apart, you literally take it all apart to get to this bearing, but now I can show how to do it with pictures making it easier for you to do it. even if you have to replace something other than the spin bearing, this how to tutorial will show you how to get to most of the parts in this machine
tutorial located here tutorial located here https://sites.google.com/site/maytagwasherrepair/maytag-washer-repair
Posted on Apr 08, 2008
SOURCE: Fisher & Paykel GW712 washing machine continuously
Out of balance switch could be faulty/ coroded.
have a gw 709 and it had the same problem, out of balance switch had jammed on
Posted on Apr 15, 2009
co7196
  • 3433 Answers
SOURCE: making an awful ratcheting noise during aggitation and spin cycles
Under the agitator there is a rachet mechanism that works the agitator. If it is stripped, it will skip until the next good tooth.. when it fails entirely the agitater will stop going back and forth. Its nylon and age along with overloading hastens its dearg.. If you can get the parts you can replace it yourself without difficulty. There is a single bolt in the center of the agitator top . Remove and loft agiyator straight up.
Posted on Jun 15, 2009
  • 3 Answers
SOURCE: GE washing macine stops during the wash cycle
This is exactly what my machine was doing, as well. I fixed it by cleaning out the filter in front of the water pump.
Searching here, I found that you can remove the lower front panel (three screws along the bottom edge is all it takes) to get to the filter. With the panel removed, you'll see a round white plastic cover (about 3-4 inches diameter) that screws out. Get a bucket under the cover to catch the water that's in it (could be 2 quarts or more) and unscrew the cover.
The cover pulls out, revealing that is actually a screw-in plastic strainer. I found tons of coins, broken pens, paper clips, etc. in mine when I did this. A lot will be deep inside the black rubber hose that connects this filter housing to the washer drum. You can rake the stuff out with a bent wire clothes hanger. Shaking the black hose will help hurry the junk along and out of your machine. Screw the cover back on after the clean out and your machine should go back to normal.
Thinking about it, front loaders will have lots of small items flushed into the pump compared to top loaders. Coins you alway found in the bottom of the drum in a top loader, they all wind up in the filter of a front loader. And once it slow the drainage to a crawl the machine will shut down multiple times when it can't drain the water out completely, and it will never step up to it's max spin speed with all that water still in the drum.
Posted on Nov 30, 2009
Fisher & Paykel Aquasmart washing machine makes loud banging noise then stops during rinse/spin cycles
Your Aquasmart machine requires 4 new suspension damper rods & 4 top bands, these are a common problem for AquaSmart machines.
Feb 02, 2013 | Fisher and Paykel Washing Machines
Makes clunking noise when changing modes--does not spin dry
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 24, 2010 | Amana 3.2 cu. ft. Top-Load Washer
Machine makes awful noise during any movement, spins very slowly, not enough to spin out. Making an awful noise, like stripped gears and won't drain
There are three reasons for such awful noise during spinning. Either the drum or the bearing turning the drum. Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
Thanks
Jan 01, 2010 | Washing Machines
Maytag Neptune makes loud drums like sound 5 min before it stops.
its probably because of the way the clothes are in it. you have to make sure the clothes arent leaning to one side and that they are evenly set up. otherwise when it goes into the spin cycle itll lean and hit the side of the washers inside and make it shake and do what you said it was doing.
Jun 04, 2009 | Maytag Neptune MAH5500B Front Load Washer
Making an awful ratcheting noise during aggitation and spin cycles
Jun 03, 2009 | Maytag Legacy Series Top Load Washer
Stops spinning during cycle
spint the dial a few times working as of now
Apr 28, 2009 | Washing Machines
Rattling noise during spin cycle
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Nov 12, 2008 | Maytag MAH2400A Front Load Washer
Looks like the drum has droped
You will need to get the bearings replaced. Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Sep 18, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
158 people viewed this question
Top Washing Machines Experts
