Question about Xerox CopyCentre C20 Black and White Copier
Xerox copycentre c20 paper jam in 2 how do i get it out please
I have a Xerox copycentre c20 and it has a paper jamin number 2, how do i get the paper out.
  • spidersmartj Apr 22, 2009
    I bought Xerox C20 about a year ago and now out of warranty (90 days). Paper jams occurred once every other week (pretty heavy usage). We were able to take out the torn paper and it worked all right, but this time even after we took out all that is visible, it still says the same errror. The locaion of the paper jam is pointing to the top path location.
    Any idea how to fix it?
  • Anonymous Mar 24, 2014
    Xerox copycentre 238
    President:
  • 2,072 Answers
Unplug the machine, open the right door. Get a phillips screwdriver.
Look on the upper portion of the paper path, you will see an assembly with yellow waning stickers that say HOT. There are 4 silver screws on that fuser assembly. Remove those screws, and unplug the white connector. Pull back toward yourself to remove the fuser.
Lay it down and remove 2 silver phillips screws , it will open up and you can remove the paper. Make sure the machine has been off for a half an hour or so, It is hot. Take a good look at the black aluminum coated roller on top. See if it looks smooth and clean, If it has a lot of toner built up on it, you will have to repalce the fuser or it will continue to jam and give you ghost ( light reprinted) images up and down your page.
Also the M20 does not handle large black ares on a page such as a picture or magasing cover being copied. Largs solid areas tend to stick to that heat roller. If you do copy a photo, try and allow about 2 inches on the top of white. Just move your original down on the glass about 2 inches from the edge. 2 inches to tie right of the edge of the glass.
Posted on Jan 18, 2009
Xerox Copycentre C20: Copier doesn't scan top 1-3 inches of page. Happens intermittently. When this happens, it moves everything else on page to the top of the copy, cutting out what should be
The document feed rollers may be dirty/worn which is causing the paper to come into the scan area late causing your document cut offs. use a clean, lint-free cloth dampened (not moist) with water and clean the document feed rollers. Confirm they are dry then, try scanning multiple pages and see if they pull through without stalling. If they do, it's time to replace those rollers.
Aug 27, 2017 | Xerox CopyCentre C20 Black and White...
My Xerox CopyCentre C20 doesn't always print the entire page, as if it is only scanning part of the page. It happens when the original is placed on the glass surface as well as when the original is sent...
the paper size detector may not detect the original size of the document check the paper tray indicator light on the panel and make sure the direction is the same with the original document onthe glass
Aug 26, 2010 | Xerox CopyCentre C20 Black and White...
When I use the automatic document feeder on my xerox copycentre C20 I get a black line running the length of the page. If I make a copy from the glass, one sheet at a time, it is fine. Is there a way to...
You have something on your "**** glass", the narrow piece of glass that the scanner "looks" through during adf use. Get some window cleaner or rubbing alcohol and clean it with a damp cloth. Often, it's correction fluid (Liquid Paper). A little dot is all it takes because the paper is traveling across the dot, effectively drawing a line down the length of the page.
(Please rate this response as I'm trying to obtain the next level.)
Aug 04, 2009 | Xerox CopyCentre C20 Black and White...
Our copier makes light copies.
Most likely, you need a new toner cartridge, part number 106R01047
Jul 24, 2009 | Xerox CopyCentre C20 Black and White...
I need Know, How enter to service mode
Press,,,,, Menu #1934 . What you may want to try first is to do what is called the Shading adjustment. That calibrates the scanner.
It would be found in the maintenance menu after you enter diagnostics.
You must place 5 pieces of white paper on the glass before you perform the adjustment.
There really is no way to increase the amount of toner concentration on that machine. You may very well have a defective ink cartridge. That is not uncommon on the C20. There is a metering blade in the toner cartridge that often times does not allow enough ink to be applied to the toner roller.
May 13, 2009 | Xerox CopyCentre C20 Black and White...
XEROX COPYCENTRE C20
u can find manual for this copier at the link below:
www.lostmydrivers.com
Jan 10, 2009 | Xerox CopyCentre C20 Black and White...
Xerox Copier Model XC1020
if the paper is black and the copies are coming out there is a problem with
1) the drum,
2) the transfer unit--- the unit under the drum, with thin wires,
Jan 08, 2009 | Xerox CopyCentre C20 Black and White...
RX paper tray full
Yep, easy fix. Look into the area where your copies come out, between the paper try and scanner. look towards the upper back and you will see a flag sensor, about 2 inches wide and 1 inch in height. It has come out of the 2 clips it snaps into. Carefuly move it around until you line it up properly then snap it back into the clips it mounts to. You may have to gently squeeze those clips together to hold the flag in place.
That is your problem. Easy one to resolve.
Feb 12, 2008 | Xerox CopyCentre C20 Black and White...
Xerox CopyCentre C20 Black and White Copier Logo
1,099 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
