Question about HP LASERJET PRO M1132 MFP
Unable to scan on laserjet m1132 MFP
My computer has Windows 7. I am able to print and copy documents. The problem I have is that I can not scan using this printer. What should I do to use the printer for scanning as well?
    Novelist:
  • 135 Answers
Have you tried START button, ALL PROGRAMS, Windows Fax and Scan?
My ancient HP 3330MFP works fine with it using a USB cable.
Posted on Oct 16, 2013
  • HP Master
  • 3,606 Answers
Hello you have to open the HP LaserJet Scan.
In the HP program group, select Scan to start HP LaserJet Scan
Select a scanning destination
Click Scan.
Here is a user manual in more details:
http://images10.newegg.com/User-Manual/User_Manual_28-115-668.pdf
You need adobe reader to read the content.
Good luck
Posted on Jan 02, 2013
mohanchennai
  • 490 Answers
SOURCE: Blank Scan from HP Scanjet 5590 Flatbed Auto Feed
Scanning is possible in 'Text' mode and 'Picture' Mode. In text mode, which is simple 'Black & White", this can happen, particulalrly if the text is in color. Either you increase the contrast settings or scan the document in Grey/color and convert it to B&W using the software. By this you need not check if there is output!. ( I am assuming that otherwise the scanner is performing okay). File size in B&W is very small as compared to Grey/color.
S. Mohan
Posted on Apr 06, 2008
  • 47 Answers
SOURCE: hp scanjet will not copy to print
FROM HP, searched and found after three or four weeks of unresolved solutions .. and that's fixed the problem !!
Solution Follow the steps below:
  1. Click Start , then Printers and Faxes .
  2. Right-click the system default printer and click Properties .
  3. On the General tab, right-click the default printer and click Copy .
  4. Click Cancel to exit.
  5. Click Start and then click Run .
  6. In the Run dialog box, type regedit and click OK . WARNING: Using Registry Editor incorrectly can cause serious problems that may require you to reinstall your operating system. Hewlett-Packard cannot guarantee that problems resulting from the incorrect use of the Registry Editor can be solved. Use Registry Editor at your own risk. It is strongly recommended that you make a backup copy of the Registry before you edit it. For information about how to edit the Registry, view the "Changing Keys And Values" help topic in Registry Editor (Regedit.exe) or the "Add and Delete Information in the Registry" and "Edit Registry Data" help topics in Regedit32.exe.
  7. In the Registry Editor window, click Edit , then click Find... , and search for the following key: HKEY_CURRENT_USER\Software\Hewlett-Packard\DigitalImaging\hpfccopy .
  8. Double-click Printer in the right pane.
  9. In the Edit String window, paste the printer name as it appears in the Registry under Value data (for example, hp photosmart 8400 series) .
  10. Click OK and close the Registry Editor.
  11. Press Copy on the scanner. The default printer connected to the system should normally print the scanned document.
Cause This issue occurs when the default printer or the list of printers is not recognized on the hpfccopy function in the Current User section of the Registry.
Posted on Oct 12, 2008
SOURCE: hp photosmart c4585 printer won't scan wireless
I had a similar problem, the problem i had was that HP scan Pro just quit on me whenever i opened it up to scan using wireless and usb. so i wen to the help and support website and downloaded the installation software for the printer.
http://h10025.www1.hp.com/ewfrf/wc/product?product=3757825&lc=en&cc=uk&dlc=en&submit.y=0&submit.x=0&lang=en&cc=uk
then uninstalled the HP software i had previously installed and then installed the downloadable software from the link above. then it all seemed to work.
i dont know if it could be a bad batch of software disks that got distributed with the printers or what? but just to let u know, i encountered this issue using Mac OS X i don't know if its the same for other Macs and PCs. Either way i think its a software issue so if in doubt just download all the latest software and drivers etc. from the HP website.
you didn't buy this from PC World recently when they had this printer on offer did you? cos i did, just noticed the date when this was posted. i got mine last week and only just installed it today!
Good Luck
Posted on Apr 18, 2009
michael_grey
  • 365 Answers
SOURCE: HP 4570C flatbed scanner. Windows XP. USB
Go to the control panel and look under cameras and scanners.Then look under events.You should be able to figure it out from there.
Posted on Jul 22, 2009
homedesigner
  • 583 Answers
SOURCE: I use hp scanjet 3670 now with Windows 7, before
Go to this website and select your operating system and download the updated drivers.
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=298541&taskId=135&prodTypeId=15179&prodSeriesId=298539&lang=en&cc=us&submit=Go%20â»
Posted on Jan 26, 2010
Testimonial: "I guess that's what I'll have to wait for - thank you"
My mfp m1132 is showing error E8 and cant copy/scan. what do I do?
Juliet. Most likely the scanner lamp, or scanner control unit assembly is defective. If you're technically savvy, you could remove the scan glass and lube the shaft that the scan lamp assy slides on. Sometimes that will fix it. Otherwise, the whole top scan unit will need replacing. That could cost over $300 for the replacement.
Oct 07, 2015 | HP LaserJet Office Equipment & Supplies
Why can't I scan using this printer?
reinstall software and try again.
Aug 06, 2015 | HP LASERJET PRO M1132 MFP
My hp laserjet M1132 MFP is printing but not scanning or copying.
that is a driver issue, and Windows is notorious for issues like that, assuming you are using Windows. Go into Device Manager and use the 'Update Drivers' tab.
Aug 19, 2014 | Office Equipment & Supplies
it's a driver issue. update the drivers, or paY SOMEONE TO DO IT.
tHERE IS NOT ENOUGH INFORMATION TO BE ANYMORE POLITE.
I am unable to make photocopy on laserjet m1132 mfp
i have paper and ink but mu photocopy can make anything can't laod any paper so tell me the solution
Feb 17, 2014 | HP LASERJET PRO M1132 MFP
Laserjet m1136 mfp
Have you considered installing the scan tools on the other computers? Print sharing is a function of windows; assuming that the printer is not a true network printer. Windows does not have the ability to share scanners. But this is where the software can scan the network and find a HP scanner. Also some scanners can perform a "scan-to" function; but I believe the software need to be installed on the destination computers for this to work as well.
Dec 11, 2013 | Office Equipment & Supplies
Hp laserjet m1132 refill problem solution
Replace with professionally remanufactured toner... it works better... or increase the resolution if you are copying...
Sep 28, 2012 | HP LASERJET PRO M1132 MFP
I have refilled my HP LaserJet M1132 MFP toner and the print quality does not look good. It is very faint and if I try to increase the contrast, it is not readable. Please advice.
Nov 19, 2010 | Office Equipment & Supplies
Hp laserjet m1319 mfp series
Are you using the software that shipped with the machine? I use the" HP Scan To" program which allows me to scan it to a slew of file types.
The only downer: I can't put the software on more than 1 computer. Apparently, it recognizes that the printer is hooked up to another machine and won't let me install any drivers on other computers (except the print driver).
Sep 25, 2008 | HP Laserjet M1319F Laser Multifunction...
HP LASERJET PRO M1132 MFP Logo
2,827 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
