Question about New World 70TC Electric Single Oven
Hello , i do have New World 70TC electric oven and grill every time we use oven steam come out is there any enstracions how to fix this problem pleas
This oven is great it was in the kitchen when we moved to this house we don't have any catalog hope i can get any help many thanks raja.elasswad@googlemail.com
SOURCE: New World E70DOA - Oven/Grill Temperature
Steve, I have a PDF of the manual. send me an email to david.stevens@vibanalysis.co.uk and I will reply with document attached.. We recentley moved house and were in the same situation. We contacted Newworld who sent us a paper copy which I have scanned to PDF.
Dave
Posted on May 04, 2008
SOURCE: new world tgo 70 grill
I have a TGO 70 for sale in Doncaster
Posted on Nov 02, 2008
barkencoa
  • 3463 Answers
SOURCE: I am not sure if I should leave door open on NW90 electric
It is normal to grill with the oven door open, only use it closed when you are using it as a oven.Hope this solves your query.
Plz rate my answer.
Thanks,and a merry xmas.
Posted on Dec 20, 2008
gasman44
  • 83 Answers
SOURCE: My grill won't light
Hi
Forgive me for asking this, but you have read the instructions haven't you?
If you have, and it's still not working, then the likelihood is that there is a fault, this could be one of the following:
Faulty solenoid valve to grill (some grills had a safety button fitted to stop you from closing the door if the grill was being used)
Blocked pipe inside unit
Either way you need to get a qualified gas engineer to take a look at it, if it's under warrranty call the manufacturers first!
I hope this helps
Steve :)
Posted on Jul 14, 2009
  • 8 Answers
SOURCE: Hello chaps my new world e60cm oven is only
Hi Andy. I have the same problem with mine, just had a repair man come out and the bottom heating element had gone. Don't know if this is a common fault, but maybe the first place to look.
Posted on Nov 26, 2009
New world 70tc grill element which wire goes to which terminal
Are you talking about the element itself or the switch? On the element itself it should not matter as elements are usually a closed CCT with no connection to eth. If you are talking about the switch end that is a different matter.
Jul 19, 2014 | Ovens
NUMBERS MISSING FROM FRONT OF OVEN
if you get a solution could you tell me too please? Or do you have a link to where I can get a manual from please@
Nov 10, 2013 | New World 70TC Electric Single Oven
Grill temp. too high
Replace the thermostat for the grill
Apr 08, 2013 | New World 70TC Electric Single Oven
The temperature markings on the top oven/grill have worn off - can anyone help
the first knob has tree positions in the middle is off to the left the top (grill) heats to the right top (grill) and bottom heat, the second knob indicates the temperature in the following way ..50....100....150....200....250..good luck
Nov 27, 2012 | New World E70DOa Electric Double Oven
NEW WORLD - NW601FP Electric Oven
i believe after buying this oven that the left knob at turning clockwise position 1 is defrost which works by just blowing room temp air around, position 2 is oven on, position 3 is conventional grill must be used with door open and position 4 is fan grill can be used with door closed ,and the knob on the left is for setting oven temp and and turn fully round when using the grill to heat the grill
Jan 17, 2012 | New World Ovens
I have just purchased a new electric cooker. The old one had three terminals in the back, one each for live, neutral and earth. The new one has three marked live, two marked neutral and one marked earth. I...
Hi.
Live goes to live as normal earth to earth as normal, and the neutral is probably a comonj terminal, in other words it probably has a lnk joining the 2 neutrals together.
Nov 09, 2010 | New World 70TC Electric Single Oven
New World TGO 70 grill not working because door was closed
THIS IS PROBABLY BEST LEFT TO A QUALIFIED ENGINEER. To reset the grill thermal cut out. This is located under the metal panel at the top of the unit and it is necessary to ether partially or fully remove the whole oven from its housing to get at it. 1. Disconnect electric supply. 2 remove the 2 housing retaining screws. These are located either side of the at the top of the grill cavity. 3.Pull the whole oven /grill unit out and support it underneath to stop it falling forward. 4. Remove metal cover covering top of oven. 5. the safety cut out is a small component that has 2 wires connected to it by spade terminals, in the middle of which is a small red button. push this button gently with the end of a pencil or screwdriver until it clicks. This should now be reset and allow the gas supply to the grill to resume. Finally reassemble making sure that the integrity of the gas and electrical supplies are, in no way compromised and test.
Aug 20, 2009 | Ovens
Lettering missing from dials - what should they read?
How do I know if a handy man with a liscenceBakersfield Ca
Aug 07, 2009 | New World Ovens
Plz rate my answer.
Dec 20, 2008 | New World E90DOa Electric Double Oven
New World 70TC Electric Single Oven Logo
55 people viewed this question
Top New World Ovens Experts
paulcarew
ashburton
Are you a New World Oven Expert? Answer questions, earn points and help others
