Question about Cell Phones
N85 camera not working after changing flex - Cell Phones
Dark spots on appears on nokia n85 8 mp camera
The dark spots is seen in your camera because inside the camera (LENS) some dust/particles may stick.You can check it out by removing the camera and clean all the lens and the housing (cover) which is seen straight to the camera(lens).If not solve the last thing is to change the CAMERA (lens).Good luck
Feb 20, 2012 | Nokia Cell Phones
N85 no display no sound and no light on powering on it only vibrates
  1. 1ST OF ALL YOU WILL HAVE TO CHANGE THE FLEX CONNECTING FROM THE MOTHER BOARD TO THE SCREEN BOARD
  2. IF THE PROBLEM STILL OCCURS, RELOAD THE PHONE WITH A FLASH FILE.
Feb 03, 2011 | Nokia N85 Cellular Phone
I have nokia n85 i can't hear anything when i use headset
hi, try change your ear piece...it faulty.
cheers
May 29, 2010 | Nokia N85 Cellular Phone
N85 automatically switches off when i call
man just turn off and press 3 and hold and press * and press green call buttons at a same time and power on the phone this will format and phone will 100% ok.
Apr 21, 2010 | Nokia N85 Cellular Phone
Is the ******** in the n86 the same as in the n85 meaning if i have an n86 can i install an n85 ******** insteed of the oregional and if yes will it work properlly???
Hi,what do you mean by the ********* in the n86 and n85*******,but whatever it is,the n86 is a little modification of the n85,they have the same operating system,anything that works on the n85 will work properly on the n86,and vice-versa.
Thanks and take care
Apr 02, 2010 | Cell Phones
Nokia n85 pin code
hello friend .
the proble to your phone is just easy and simple the pin code that you need for phone is one and it work for all nokia phones if you have not change it or someone have not do that for you the code is 1 2 3 4 5 then click on ok or yes.
Note pls. if there is a change some were then you have to take your phone to good phone work shop around you for unlocking then you will be able to operate your phone again
Mar 15, 2010 | Nokia N85 Cellular Phone
Nokia n85 only show nokia and restart.
yes. this is the boot ic problem. pls. change the ic. this ic is stay near key pad ic. this is contains only 12 balls.
Apr 20, 2009 | Nokia N85 Cellular Phone
Cell Phones Logo
20 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
