Question about Lexmark X5470 All-In-One InkJet Printer
My ink cartrige says incorrect cartridge
I have changed the black ink cartridge and it wont work
    Scholar:
  • 54 Answers
Well if you are sure you replaced it with the correct model cartridge the only possible cause of this is a defective chip on the new cartridge, this is very common with "refilled" cartridges.
I would return the cartridge if it is new and simply exchange it, if this is indeed a new cartridge then it is probably just a fluke.
there is one other possibility if this does not solve your problem, the cartridge slot could have a bad sensor, unfortunatly if this is the case the printer is generally not worth fixing if you spent less then 250$ on it, so you may simply need a new printer but i would obviously try another cartridge first as bad cartridges are fairly common.
Posted on Jan 19, 2009
Black Cartrige Missing
Did you use a brandname ink cartridge - or is it a knock-off brand? If it is a brand name - then the cartridge is most likely defective. If it is a knock-off brand - some printers do not recognize the electronic in the cartridge and therefore don't see it as one being installed.
This may also help
Dell 922 AIO Black Ink Cartridge Missing Message
May 02, 2017 | Dell AllinOne Multifunctional (v515w)...
Replaced new ink keeps saying right cartrige is incorrect wont let me print. the cartrige is correct i paid $50.00 for a two pack of black and color ink!!!
Wiping the nozzles with a moistened soft cloth or removing and reinserting the cartridges usually helps. The cartridges for the Lexmark X7170 are black: 32/34 and color: 33/35. If these are the cartridges that you purchased and even tried your old and new cartridges yet the problem persists, please don't hesitate to contact Lexmark technical support.
Mar 23, 2011 | Lexmark X7170 All-In-One InkJet Printer
Ink cartrige problem i replaced both cartriges keeps saying right cartrige is incorrect wont let me print
Mar 23, 2011 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
My Epson c88 was working fine. I changes ink cartridges and now the black will not print.
Your printer head may be closed.To remove the problem jast open ink cartrige from the cartrige chamber. set a seringe with full of black ink into the plustic pin which are tidely insert in the ink cartrige. After push 2/3 time your printer work fine again.
Thank You .
Shohagtush
Oct 20, 2010 | Epson Stylus C88 InkJet Photo Printer
Receiving the message "Ink Catridge problem: ink cartridge appears to be missing or damaged". I've tried everything from cleaning cartridge holders to replacin cartridges. Nothing works and the printer...
The message you are getting may be due to the following reasons :
1) Cause : One or more ink cartridges missing.
Solution : Remove and reinsert the ink cartriges and verify that they are fully inserted and locked in place.
2) Cause : One or more of the ink cartriges are not installed or are installed incorrectly.
Solution : Remove and reinsert the ink cartriges and verify that they are fully inserted and locked in place. If the problem persists, clean the copper-colored contacts of the ink cartriges.
Nov 24, 2009 | HP Photosmart D7260 Printer
Epson Stylus 1520 won't print black
when you replace a cartrige make sure you take off only the yellow tape .. if you take off the white tape also then the cart wont work anymore .. careful about using off brand ink .. i used the cheep stuff for about a year before they changed the formula without telling me .. it clogged the heads completely .. .. nice wide format printer .. hope you get it working ..
Oct 01, 2009 | Epson Stylus 1520 InkJet Color Printer
Printer not reconizing ink cartriges after 2 weeks use
please change your printer cartridge
05 black
06 Color cartridge
it is problem code not cartridge part no
Thanks
Aug 04, 2009 | Canon PIXMA MP180 All-In-One InkJet...
What does the cartrige icon stand for in the hp deskjet 840c?
If the cartridge icon is being displayed and the printer wont print it means either the cartridge is installed incorrectly or you are out of ink.
May 17, 2009 | HP Office Equipment & Supplies
Printer says right cartrige is incorrect
remove the cartridges and reinstall them back, turn the printer off , if that does not work, did you use a new original cartridge or a recycled cartridge ?, either way will trick the printer into the new cartridges, i, hope this solves the problem good luck.
Jun 01, 2008 | Dell 922 All-In-One InkJet Printer
No black ink print. Prints in light blue
Cartriges have a shelf life. It's printing in blue either because it has dried up or is out. Different cartriges have different timelines but if you haven't been using the printer often, it could have dried up or is simply out of ink. I would suggest first to try cleaning the head of the cartrige where the ink comes out with alcohol and a Q-tip and then if that doesn't work, buying a new black cartrige.
Nov 06, 2007 | Office Equipment & Supplies
Lexmark X5470 All-In-One InkJet Printer Logo
50 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
