Question about Brother PC-210 Computerized Sewing Machine
Frozen motor My machine's motor froze up, cleaned out the bobbin area and removed the one cover that I could but did not see anything jammed in there. How can I get in there and clean it out? According to the manual it has to be serviced at a dealer however we are stationed in Germany. I've had it for over three years so the warranty is no more.
  • Brother Master
  • 1,564 Answers
Well, you don't. Germany should have sewing machine repair people. Call around.
Posted on Jan 01, 2013
WonderTech
  • 268 Answers
SOURCE: lower thread keeps jamming even though bobbin case
Here are some things to try.
* Re-thread your machine
* Change your bobbin
There could be a nick along the edge of your bobbin spool that’s catching your thread as you
sew.
Also, before you start to sew a seam, grasp the upper and bobbin thread tails. Hold them back
and out of the way as you sew your first couple of stitches. This will keep them from getting
caught in your machine.
I hope one of these solutions help.
Posted on Sep 15, 2009
  • 6 Answers
SOURCE: Brother 2003D jammed
i am not familiar with the brother safety device myself. however things i would check might be to first check the manual for the machine. if not available try to turn the machine off if it is electronic in hope that it would reset itself. i would also totally unthread the machine and change the needle. embroidery machines need to have needles changed more often due to their high speeds.What type of fabric were you sewing on? Some of the newer machines are just not made to sew on very heavy fabrics and this might be causing something in side to spring. Try to stitch on a lighter fabric with a stabilizer under it
Posted on Apr 30, 2008
  • 52 Answers
SOURCE: Brother SE-270D sewing machine bobbin won't wind
the rubber ring on the bobbin winder has probably gone bad which would mean replacing it but you can buy a portable bobbin winder called a sidewinder for around 20.00
Posted on Jul 16, 2009
  • 1788 Answers
SOURCE: My Brother pc-420 (Project Runway)
I would call Brother at 1-800-276-8437 and complain that you took it in to their authorized service center and the problem is even worse. I would try for a new machine or them to send you a call tag to fix it themselves. A machine only a year old should not have that kind of problem. Be assertive and not afraid to speak up. You deserve better service.
Posted on Sep 20, 2010
SOURCE: Brother VX-1120- The needle is not picking up bobbin thread.
I had the same problem with my brother vx-1120 sewing machine. I set the needle to lowest position by using the hand crank. Then I loosened the knerled set screw that holds needle in place. Then I moved needle shaft till the eye of needle is just lower than the hook on the shuttle loop maker. It made my mechine work. There are instuctions for ajusting timing on machine but I think these mechines are built to not fix and throw out. Just because there where no ajustment marks at all on machine, any machanical machine will needed to be ajusted sometime.
Posted on Oct 30, 2010
I have a 1951 singer s#AJ947704, flywheel froze, anything I can do?
Yes, likely you have the thread jammed up in the bobbine area. If that is clean, tehn it could be that the grease is old and gelled making it very hard to move. Perhaps a few drops of alchohol on teh main bearings will help, then once it is moving freely add lots of drops of oil.
However first make sure it is not jammed up by thread somewhere.
Moses
Sep 07, 2014 | Singer Sewing Machines
Balance wheel doesn't turn
Don't force it. open up under the presser foot and the bobbin area.... pick out any threads.
Sep 01, 2012 | Janome L-344 Mechanical Sewing Machine
My singer sewing machine is jammed. it sewed awhile, the bottom tension too loose, I adjusted it a tad, now its jammed again
try changing the needle
adjust the top tension one number or letter higher till the stitch looks
normal
clean under the needle plate & in the bobbin area for lint
make sure the bobbin is not warped
make sure the bobbin is inserted correctly into the bobbin case
try rethreading the machine top & bobbin
it's also possible that the machine could be out of time & needs
to be checked at a repair shop
Aug 23, 2012 | Singer 3116 Simple
Brother Sewing Embroidery Machine
I agree with sylviaivie about find another repairman, they are suppose
to guarantee the work they do.
when the upper shaft is replaced & then the machine is retimed
the machine should work just fine.
but just don't take it back to that man to be repaired
here is a tip if it happens again,,
always try to cut the top thread first,
& turn the machine up on it's back to access the bottom cover
take the cover off the bottom to get access to the bobbin thread
where you can cut the bobbin thread
then you should be able to get the needle out without breaking it &
damaging the upper shaft, replace the needle & make sure
that the thread is good quality & not knotty, clean out the bobbin area of lint or thread
always change the needle on the embroidery machine every project
make sure the bobbin area is kept clean of lint or thread
clean under the needle plate at least once a week for lint if you
embroidery everyday or just often
Aug 01, 2012 | Brother Sewing Machines
My machine started knocking & the lower thread jamming; how do i fix it?
have you tried a new needle
Correct needle insertion is mandatory for proper use of your sewing machine.
Raise the needle bar to the highest point, then loosen the needle clamp screw to remove the old needle.
Place the new needle in the needle clamp with the flat side of the needle facing the back, (round needle, the groove in the needle should face away from the shaft).
Push the needle all the way up as far as it will go. Then tighten the needle clamp screw.
check the bobbin to make sure it's not damaged
rethread the machine top & bobbin
clean under the needle plate & in the bobbin area for lint or threads
also make sure the top thread doesn't come off the thread take up
lever
Jun 07, 2012 | Singer Confidence 7467 Mechanical Sewing...
Pfaff 2024 bobbin case basket is jammed-even after clean & oil
the jam that happened may have caused the machine to jump time & it would have to be serviced
May 16, 2012 | Sewing Machines
Pfaff select 1540 bobbin thread jam
if there is a thread in the hook area try taking a pair of needle nose
pliers to try & get the thread out, if that doesn't work then you might
think about taking the machine to a sewing machine shop to have the
machine checked since the needle will not go up & down & handwheel
won't move
May 03, 2012 | PfaFF Sewing Machines
I can't get the bobbin thread to the to thread correctly in the machine in order to sew
make sure the bobbin is inserted correctly into the bobbin case, some
bobbins only go one way.
clean under the needle plate & in the bobbin area for lint & threads
May 01, 2012 | Elna Sewing Machines
Sewing machine motor jams when I sew thick fabric
a part of the computer is malfuctioning, & needs to be checked
try a new needle
rethread the machine using every thread guide
clean under the needle plate & in the bobbin area for loose threads & lint
Mar 19, 2012 | Sewing Machines
My machine was working.fine when during a seam it froze. I took off the the bobbing cover and saw the bobbin case had shifted out of place. I replaced it and got the needle moving freely again and now my...
clean under the needle plate where the feed dogs are for lint
also get a can of air & use it on the bobbin area
change the needle
rethread the machine top thread & bobbin
make sure the bobbin is not warped or damaged
check the top thread tension
Nov 17, 2010 | Brother CS6000i Computerized Sewing...
Brother PC-210 Computerized Sewing Machine Logo
42 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
