Question about Jabra BT250 Consumer Headset
My jabra bt205 charging light stays on for about 8 hrs, when it finally goes off saying it is fully charged, my jabra won't turn on as if the battery is flat, so I plug it in again and it charges
  • drivewithala
    drivewithala Dec 31, 2012
    Thanks mrkrypto, but to put it in pairing mode it needs to be turned on and mine won't turn on!
5 Suggested Answers
  • 3 Answers
SOURCE: Jabra BT 350 has stopped connecting
Hey everyone! I had the same problem, and I actually got it to work again! I hope these directions will help you get yours to work (from the manual):
1. Put the headset in pairing mode
• Make sure the headset is off.
• Press and hold the answer/end button until a solid blue light comes on. <== THIS IS VERY IMPORTANT! HOLD THE BUTTON UNTIL YOU SEE A SOLID NON-BLINKING LIGHT! (This is where I was going wrong with the directions.)
2. Set your Bluetooth phone to ‘discover’ the Jabra BT350
Follow your phone’s instruction guide. This usually involves going to a ‘setup,’ ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’ or ‘add’ a Bluetooth device.
3. Your phone will find the Jabra BT350
Your phone then asks if you want to pair with it. Accept by pressing ‘Yes’ or ‘OK’ on the phone and confirm with the passkey or PIN = 0000 (4 zeros).
Posted on Oct 27, 2008
  • 16 Answers
SOURCE: Jabra BT205 - headset no longer charges
Try this link for help and explanation.
http://www.fixya.com/support/t190081-jabra_bt250v_indicator_light_doesnt
Posted on Jan 07, 2010
  • 16 Answers
SOURCE: jabra bt 250v not charging or cannot use headset.
Try this link to help you on this site it is a battery problem
SOURCE: jabra does not charge - no lights
All of these solutions just sya mine doesnt work either. No **** it doesnt work, why would i be on this website if it worked. I want solutions not pansey namsey whiners.
Posted on Feb 07, 2010
2007 is250 battery died, then was fully chared, now the car isn't detecting the key and won't start
all new cars are set up that if the battery deads it goes into lockout mode. it is so the dealer ships can make money
Dec 16, 2012 | 2007 Lexus IS 250
Motorola triumph won't charge when plugged in
I tried everything, bought 3 new batteries, 4 new chargers and everytime about a day goes by and the phone dies in less then 3 hrs and stays dead...tried connecting to usb, tried removing the batter and still dead...finally followed the steps on the website: https://motorola-global-portal.custhelp.com/app/answers/prod_detail/a_id/83322/p/30,6720,8064 first I held down the power and lower volume buttons for 10 sec. and no luck, removed the sd card followed by downloading the manager and motocast from the website above and finally...looks like the charge light finally turned back on...Finally guess this is what it needs with all the downloads and memory used i need to keep it up to date....I guess...hope this helps others...i was ready to tear this phone apart and just buy a new one...just saved some $$
Jul 27, 2012 | Motorola Mobility Triumph WX435 Cellular...
Why did my lights go down and battery volts drop?
First put your battery on a slow charge 6-8 hrs.then check the batteries voltage it should have at least 12-12.8 volts if it does'nt then you need a new battery.If has 12 volts after its charged and goes dead after its installed in the car then you need a new alternato.
Jan 27, 2012 | 1995 Cadillac Eldorado
I lost my manual to my duracell instant jumpstart . Just wanna know to properly recharge my unit.
I'm having the same problem where it won't take a charged. If you left it with a dead battery for say 6 months, it probably ruined the battery. You should have a charger for house current and car voltage charger. I guess your dead in the battery like me. I'm taking it to Battery Plus to check it out. It only had a 1 year limited warranty. Good Luck.
Oct 30, 2010 | Duracell ® Instant Jumpstart System
Wont turn on
If it is fully charged, press and hold the top button until the blue led light comes on. To get it into pairing mode you need to switch it off, then switch it back on but hold the top button down for 8 seconds until the blue light comes on and stays on
Aug 27, 2010 | Jabra BT250 Consumer Headset
Charge/in use light
Typically the charge light will stay on as long as the phone is on the charger. After 16hrs, the battery should be fully charged. Leaving it on the charger constantly can actually overcharge the battery, shorening it's life. The best thing to do is use it until it tells you the battery is getting low, then charge it uninterrupted for about 8-12 hrs. Of course, that's ideal and can't always be done, but the more you can do that, the better.
Hope that helps, and please rate my answer, good OR bad.
Feb 03, 2008 | Vtech 5.8GHz Analog Cordless Phone
Won't charge up...
I had the same issue. So what I did was get a small screwdriver, opened the A210 case removed the battery. You will notice orange tape (remove it) then attached to the battery is a small board (the defective part) . Cut away the board, then you will need to solder the wires back to the thin metal film leads. And voila it will now charge, make sure to never let it charge for more than 2 hours. Do this at your own risk. Of course this will void the warranty.
Nov 27, 2007 | LG Jabra A210 Bluetooth Adapter for...
Jabra BT250 Consumer Headset Logo
65 people viewed this question
Top Jabra Radio Communications Experts
TO Lady
Greg Cann
Greg Cann
Michael Vincent Cruz
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
