Picture on my BenQ PB 6210 is faint even after lamp replacement. How do I reset Lamp Hours?
SOURCE: Reset Lamp Hours Timer
This works on a couple different Toshiba models -- might work on yours...
Make sure the main power switch is OFF. Hold the "ON", "MENU", and "INPUT" buttons at the same time and turn the main power switch on. Keep them held until the yellow power standby light comes on, then let go. It is done.
Posted on Dec 06, 2007
Marrie
  • 563 Answers
SOURCE: BENQ PB2140 PROJECTOR - RESET LAMP AFTER REPLACEMENT
Hi Terence
Yes you have to reset the lamp timer.
How to do this :
1.) Hold in the up arrow key on the Projector for 5 seconds , a on-screen display will appear in the top left hand corner.
2.) It will read : Press left or right and then Menu or Auto.
Just follow the steps and the lamp timer will be reset.
Thanks for using Fixya !
Posted on May 19, 2008
Jay_Sav
  • 93 Answers
SOURCE: lamp change
Press the Auto button when it says it's going to turn off, then hold Exit, then when it tells you, press Auto again - worked for me literally 5 mins ago :)
Good luck
Posted on Mar 04, 2009
Nic61
  • 1073 Answers
SOURCE: how do you reset lamp hours on a vpl px21
Hi!
Here is the manual in PDF, on page 33 you can see how to reset the lamp hours.
http://www.roscorrentals.com/equipment_manuals/Sony%20VPL-PX31.pdf
Nic
DONT forget to RATE me
Posted on Apr 22, 2009
projdoc
  • 2237 Answers
SOURCE: Lamp timer reset not occurring with the remote control
with the projector in standby (lamp not on), press in order: reset, <-, ->, enter. then turn it on.
Posted on Nov 16, 2009
BENQ W1060 projector POWER lamp flashing but not working. What's wrong?
When you replace the lamp you have to reset the hours menu on the lamp. It is found in the menu under settings.
Aug 19, 2014 | BenQ W1060 - Dlp Projector
I have a BenQ PB 6210. After switching it on, it first displays that the lamp has run 2001 hours and should be replaced. After this window disappears, it takes maybe 2 seconds and the projector shuts...
Hi cholthusen,
Please be informed that the average lifespan of a projector's lamp is around 2000 hours. The light bulb is almost certainly the problem. The best solution would be to change the bulb. The easiest way to do that is to change the lamp assembly (fresh bulb is in the new assembly). You may also try resetting the unit. Turn the unit off, then physically remove the power cord. wait for about 10-15 seconds then start it back again. If this did not work, please replace the lamp.
Hope it helps.
Thank you for using FixYa.
Jun 23, 2011 | BenQ PB6210-DLP PROJECTOR XGA Multimedia...
How do I reset lamp hrs on benq 6210
Resetting the lamp counter
i. Press and hold the Exit 5 button on the projector for 5
seconds to display the total used lamp time.
ii. Press Auto on the projector or on the remote control to
reset the lamp hour to "0".
iii. Wait about 5 seconds to let the OSD disappear.
Feb 14, 2011 | BenQ PB6210-DLP PROJECTOR XGA Multimedia...
Hi there. I've got a benq mp721 which i've just changed the lamp on. the problem is: how do i reset the lamp timer?
Turn On projector, press EXIT and Up Arrow buttons on projector for 5-6 seconds, lamp hours display will appear, press Auto on projector or its remote to reset lamp hours to zero, wait 5-6 seconds to display will get disappear itself.
Thanks.
Jan 20, 2011 | BenQ MP721 DLP Projector
Lamp is not coming on. It was replaced recently Benq 8720
Check in your instruction Manual about pressing a button sequence while starting up. Some projectors do not actually know when you have changed the lamp, so you have to reset the lamp timer by pressing a button sequence. Often a genuine replacement lamp will have an instruction set which comes with the new lamp ( If you still have it !! :) You may have replaced the lamp but not reset the counter and it has shutdown because the counter has reached a critical umber of hours.
Jan 02, 2010 | BenQ Office Equipment & Supplies
My benq projector turns on for a few minutes (light and fan going strong), then it shuts down.
if it goes through shut down mode (lamp first and fans run a while), reset the settings to factory default. while you're in the menu, check the lamp hours (under settings). if they're close to 2000 hours, replace the lamp. if the projector shuts down immediately, fans and all, you have a power supply problem. you'll need to replace it.
Nov 30, 2009 | BenQ Office Equipment & Supplies
Benq PB8220 lamp used for 375 hrs shuts projector automatically
Hi Ash, check your manual as by memory you can do this by a 2-3 button reset via the remote control. Regards Kevin Andreassend. http://www.iceav.co.nz iceavtech@gmail.com +64-9-4142348
Jan 05, 2009 | BenQ PB8220 DLP projector 2200 ANSI lumens...
BenQ MP610 Multimedia Projector Problem
I don't have the manual on this one, but in general if the lights indicated that the lamp needed to be changed because of hours of use, then until the lamp hours have been reset, the lights will remain. The owner's manual should have the procedure for resetting the lamp hours. Try that and update this if you still have a problem. Also, check to be sure that the lamp access door is closed completely. There are safety switches that get activated when the door is not installed correctly.
Dan
Sep 25, 2008 | BenQ MP610 Multimedia Projector
Light hours getting close to 3000, but picture still looks good,will resetting lamp hour hurt and keep using same lamp be ok. thanks david
No do not reset the lamp hrs. because the lamp might reach the ed of life and could blow resulting in mercury poisoning. If you notice there is a warning sign that pops up in red or something saying to change the lamp, it will shut down eventually during that warning time. You have gotten a lot of hours with that lamp and consider being fortunate to have such reliability. Buy a new lamp when needed as it will improve your experience.
Jul 04, 2008 | BenQ PB6100 Multimedia Projector
Reset after lamp replacement
benq mp610. press EXIT button for five sec. you see counter hrs. then press AUTO button to reset
Oct 13, 2007 | BenQ (200NSH-LAMP) Projector Lamp for...
19 people viewed this question
k24674
jasbo
jasbo
