SOURCE: 1996 Honda Accord Timing Belt Installation. I need help.
You didn't post the size of motor so please use the one that is for you:
2.2L (F22A1) ENGINES
Install the timing belt, around the pulleys, in the sequence shown
SOURCE: car will not shift into overdrive
As a response to solution #1 these cars do have an overdrive while in D-4, mine was shifting in and out at 70 mph until it finally quit and the rpm is now 3100 at 70 mph insted of 2700. The car still shifts 4 full times just not the fifth-OD. I still can't find out what fixes this problem either.
SOURCE: MY 91 HONDA ACCORD ACCELERATES AND DECELERATES BY ITSELF
sounds like a bad fuel sensor on the throttle body i had the same problem...u can find the throttle body with sensor at the junk yard for about $40... 30-45 min easy fix also replace the gasket....
SOURCE: my drive 4 light on my honda accord wagon is
There are two speed sensors. One is on the tranny under the throttle bosy and one is under the tranny.
This is the one under the throttle body
This is the one under the tranny near the right wheel.The Countershaft speed sensor is the best bet. i replaced this one on a 1995 honda accord with flashing d4 and after replacement it was gone.the part will be about 125 bucks.
SOURCE: 1993 Honda Accord transmission problems
Need a scanner ,read the codes , do what the shop manual tells you to do regarding testing and repair.
Gonna take a guess cruse control and tach problems probably a wheel sensor possible the ecu.
