Question about Transcend Electronics - Others
Pen drive not showing - Transcend Electronics - Others
  • Transcend Master
  • 27,725 Answers
W 7 First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically. for XP or earlier click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X you will need to update/reinstall drivers right click to reinstall drivers if you can see your usb drive but its not working ports (com&lpt) right click update driver if this fails to fix the problem Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts if you need more help with this or if i have missed the problem post a reply Hope it helps.
Posted on Jan 11, 2013
Will not format. Shows as non recordable or non replayable
VIRUS OR TROJAN INFECTIONS:
Virus or trojans can run some process that keeps running in background. This not only harms the computer, but also prevents the pen drive from formatting as it shows that the drive is in use. Remove and re-insert thepen drive, don't double click on drive and cancel autorun operations if it starts automatically. Run a virus scan on pen drive, this will help fix the issue. Now format the pen drive.
CORRUPTED FLASH CHIPS ON PEN DRIVE:
If the pen drive is not detected at all, or shows a less capacity, then there are high chances that its a chipcorruption. Flash chips are the actual hardware components that save the data. A physical or electrical or electromagnetic damage to these chips make the pen drive faulty. This can happen because of voltage fluctuations and faulty USB ports. In such case, get the flash drive replaced if its under warranty as it can not be fixed otherwise.
FAKE PEN DRIVES:
Sounds a bit un-believable but true. There are a lot of pen drives in the market which are of very cheap quality which are fake copies of some known brands. Beware of such pen-drives. Always purchase pen-drives or memory-cards from a reliable source with bill and warranty to avoid any mess later.
Jan 09, 2011 | Memorex DVD-R 4.7 GB 16X - 100 Spindl...
I have a fake Transcend pen-drive of 32GB.Its property is showing31.2GB free space.When Iam putting any data into it, is showing until i pull out my pen-drive.When i pull out my pen-drive and again when i...
So you know the little errors you get when not removing your drive safely? That is most likely the problem. Removing them non-safely can damage them and cause data lost. You may need to get a new drive.
May 22, 2017 | Transcend USA 120GB Storejet 2.5" SATA -...
Pen drive cannot open
Please install the usb driver and check again.
Jul 02, 2009 | Electronics - Others
Why my pen drive shows only files but not folders?
Its the virus Known as "New folder Virus"(it may have other names").
You can get your folders back by installng a very good anti-virus or else by downloading "Pen-Drive-Recovery-Demo.exe" from many websites( Search "Pen Drive Recovery" In google) and you can get serial from me..
by mailing me at devgolani@gmail.com
Regards
Devesh Golani
devgolani@gmail.com
Mar 20, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
MY KINGSTON 2GB pen drive shows zero spacing......
do you still have warranty for the Pen drive, suggest you take it to the shop you bought it. you seem to have got a defective ped drive. also if you have the serial numbers, check online with Kingston to see if you have got a genuine kingston product.
Feb 02, 2009 | Electronics - Others
Ttanscaned pen drive problem
I Have Cruzer micro (8Gb) pen drive When i Insert pendrive And open Show message (Pls Insert Disk) When I try to format Pen drive Show message (There is no disk in drive G) G Drive Right click And go properties Show 0byets Pls solve the problem Regards, Prashant
Jan 13, 2009 | Electronics - Others
Pendrive problem
opening pen drive, it shows 'please insert the disk' & it shows 0 bytes & while trying to format it shows the same message again , i am using 2 gb pendrive of trancend.
Oct 24, 2008 | Transcend (589307) Media
Pen drive does not open
Your pendrive is affected virus and do the format both pen drives and first cheak with your usb port also once and when you are pushing the pen drive in the pc should be smoth dont press just push some times light is appear but data cabe is not connected to pc
Jun 17, 2008 | Computers & Internet
PEN Drive in Case of Windows 98
did you copy an installation of win98 to your pendrive and you want to boot it from there? check your bios/pc setup settings if it supports boot from USB,
May 12, 2008 | Microsoft Windows 98 for PC
How to remove write protect from pen drive
I OWN A TRANSCEND pen drive of 8gb when i try to copy or format the command it shows is "cannot create,remove the write protected"what shall i do .the pen drive is very new
Jan 12, 2008 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Electronics - Others Logo
43 people viewed this question
Top Transcend Electronics - Others Experts
Joe Goldman
Joe Goldman
Are you a Transcend Electronics - Other Expert? Answer questions, earn points and help others
