SOURCE: diesel smell in washing machine
Try using a cup the the same soap you would put in your dishwasher and run is with the hottest wash setting possible
SOURCE: fridgidaire front loader washer/ problems with softner dispensor
In the back of the dispenser is a button / lever to press down to remove the entire dispenser. Remove it and take off the cover over the fabric softener / bleach chambers. You may find some junk under the cups in that cover, or in the tubes sticking up through the bottom of the dispenser.
The way this thing works is like this: You fill up the dispenser with the liquid, but that liquid doesn't get up to the top of the tubes. When it's time to dispense, the washer adds water to the appropriate chamber, raising the level to above the tube. The liquid then goes down the tube, creating a suction which (ideally) draws the rest of the liquid up into the cup, over the edge of the tube, and down the dispenser. The washer will add water several times to accomplish this. The system isn't perfect, but it usually works with few moving parts.
If the fabric softener is especially thick, it will have a hard time getting siphoned down through the tube. If it looks as thick after the wash as it did before the wash, the machine isn't adding the water to the cup. I believe on the Frigidaire, there's a separate valve (all part of the same valve assembly) for each dispenser chamber. If it isn't adding the water, you'll have to replace the whole valve assembly.
SOURCE: The fabric softner is not going into my washing machine
hi there just try washing the complete soap drawer again in boiling water leave in there for 10minutes to let the hot water work into the gaps and make sure u take all the holders out of the drawer u sometimes have to use a tooth brush to get into the small holes at the bottom of the little funnel what your softener holder goes over also get a small flat blade screwdriver and clean inside that funnel if thats not clean it will stop softener from going away if this doesnt work still then when your softener is supposed to be taken thru the programme make sure the washer opens the valve for the water to go into the fabric softener holder if it doesnt then the solenoid will need replacing as this could be faulty. LET ME KNOWHOW U GET ON PLEASE PETER
SOURCE: Fabric softener does not drain out of dispenser
Hi. Remove dispenser and thoroughly clean, are you sure you have cold water going into dispenser?
SOURCE: LG Top Loader Fuzzy Logic 5.5. The water
No you just need to get the drain hose up higher...the water is siphoning out and is either caused by the end of the drain hose still in water and not having an air gap or the hose is not going up higher then the top of your washer...
Lifting the hose up should give you an air gap and get the hose high enough to stop the siphoning...
heatman101
Testimonial: "I am extremely impressed that this won't cost a call out service fee. . . and looking like a bimbo. thanks, heatman!"
