Question about Dell Latitude CPX Notebook
External Toshiba 400GB HDD not recognized on my Dell CPx J650GT
I am running WINXP SP3, and my brand new Toshiba 400GB HDD is not being recognized by the system either through the onboard USB port or through the PCMCIA 2 port USB card, which I think is a generic from China. All it says on the card itself is USB 2.0 Cardbus 2 port Notebook Adapter.
Please help ASAP as I have been going quietly insane these past few days looking for USB drivers for my laptop/cardbus/HDD without any success.
Thank You ahead of time for all your help and efforts.
Jay Dunn
  • Nikola Malesevic
    Nikola Malesevic May 11, 2010
    Hi.
    Can you perform a few steps so we can get more info about the problem?
    1. Connect your hard disk.
    2. Right-click My Computer, click Manage.
    3. Click Device Manager.
    Can you see device listed in the hardware list? What's the icon next to it? Does it have yellow or red warning sign on it?
New hard drives need to be formatted! So go into the control panel switch to classic view, ( if you are still using category view for the control panel ) open administrative tools, then open computer management. Next open disk management. In disk management your new drive will show as raw, you will be give the option of formatting the drive, select primary partition and format in NTFS.
This will then format the drive, when this has finished your new drive will appear in my computer.
Alan
Posted on Jan 18, 2009
Have just been given the Toshiba Hard Drive PX1396U-3T01, number 2978109s. No install instructions, or paperwork. He is now overseas. How do I install the HD, or get a driver?
Your Toshiba PX1396U-3T01 external HDD is USB-attached, so you'll need to acquire a
standard USB cable to accomplish the physical layer attachment. USB cables do not have
the same connector at each end - the system (computer) end has a USB "A" connector (flat-shaped), and the device end (HDD) has a USB "B" connector (square-ish shaped).
There is no software (driver) needed for this external HDD - support for USB-attached external
drives (either HDD or flash drives) is built into WinXP, WinVista and Win7.
IF your version of MSwindows doesn't want to recognize the Toshiba when you plug it in, try
START > Run > then type in "diskmgmt.msc"
then select the command "Rescan disks."
If you're running Mac OS or Linux, repost including your OS (operating system) info.
Aug 15, 2011 | Computers & Internet
My dell latitude cpx j650gt does not have recovery partition working and I neeed to restore it to factory settings. I do not have original OS discs as I bought it used.
You do know only certain models have an os image on their harddrive and it is this that is enabled with F9 whilst booting (or other key)Failing this you will just have to install from external Dvd/Cd rom etc-this is the fact.
Davey Snake!
Oct 30, 2010 | Dell Latitude CPX Notebook
External hard drive is not detected
Check Following Instructions:
1. Check your USB cable properly connected to the computer.
2. Go to My computer - right click on property - Hardware - Devices Manager - in below - USB Mass storage device - right click on this - and Uninstall - then again right click - click on Scan - it should be reload your USB drivers
your External Hard Drive will be detected
Apr 25, 2010 | Seagate USB 2.0 External Enclosure + 400GB...
HDD problem emminent
The bios menu has an option for SMART enabled. disable it in the main bios menu. hope this helps!
Feb 27, 2009 | HP xw6600 Workstation with 650W 80 PLUS...
Need 2 install the fastest PIII processor possible on CpxJ650GT
you obviously seem to have the adequate knolledge so why dont you overclock it...
overclocking used to be a touchy subject but know its undrstood that that it creates no problems..the chips are designed to be overclocked,in fact overclocked should now not be the trerminology for it ...it was called overclocking cos then it wasnt natural and created unstable systems ..now it is merely enhancing .
Jan 24, 2009 | Computers & Internet
How do you take the hard drive out of a dell latitude cpx J650GT
on the bottom of the laptop there should be four screws un screw those and take the cover off next take the keyboard and top covering off then carfully remove the hard drive which should be loacted near one of the fans.
Nov 26, 2008 | Dell Latitude CPX-J Notebook
HDD both IDE or SATA 1 are not recognized
Unplugg the disk from motherboard and reboot your computer
Shut off the computer, connect the drive again and start up again.
If the problem continue, set the drive on your bios manually.
If after that the problem continue replace the disk.
Oct 06, 2008 | Abit KV-80 Motherboard
3.5" Dynex USB 2.0 External Enclosure + Seagate Barracuda 7200 RPM 500 GB HDD problem with computer recognizing the HDD and the enclosure
 If your running XP , go to control panal , Admin tools>Computer Management >Storage > Disk Management . Look for it there . If its there see if it says what file system . If none format it . If it isnt there then chack the jumper on the hard drive it self . It should be set to master or cable select .
Sep 03, 2007 | Seagate USB 2.0 External Enclosure + 400GB...
PC won't recognize external usb HDD
You may not have installed the HDD correctly in the case... I had the same problem with my Thecus N1050 enclosure, the green power light on the enclosure would come on and the drive would spin up but my PC would not see the HDD!!??... I thought, becuase i could hear the drive spinning that i had it installed correctly but this wasn't the case, when i removed the enclosure again and FIRMLY pushed the HDD into the connector (all the way in) and connected it back up to my PC, it recognised it instantly. Hope this helps!
Jul 25, 2007 | Seagate USB 2.0 External Enclosure + 400GB...
Dell Latitude CPX Notebook Logo
211 people viewed this question
Alun Cox
