Question about Desa International GWP20T GLOWARM Wall Mounted Panel Heater
Will turn off after 1 min run on low heat burn
What can i do to fix my glo warm from shuting down after it has ran on low heat for 1 min only does this on low heat.
    Problem Solver:
  • 12 Answers
Hi Billie,
You didn't mention the model number, but they are all pretty basic. The flame sensor and thermo pile which are thin flame sensors, get charred and need to be cleaned. They should be cleaned with a soft cloth or even a dollar bill will work (a worn one)
When the heater shuts down it usually means it is not sensing the flame and this will cause it to shut off automatically. I have included a link to get the owners manual below.
Good luck and be sure to turn off the gas and power to the unit before working on it.
Click Here to Get Owners Manual
Thanks,
Paul
Posted on Jan 28, 2009
Pilot is on, wall switches for both ignition & fas have been changed out. Still get NO flame when wall switches are turned on.
Heat & Glo ' Install & Owners Manuals
www.heatnglo.com/Owner-Resources/Install-and-Owners-Manuals.aspx
Each fireplace, stove and insert has a rating plate which contains your model number and serial number. Gas and wood burning fireplaces have a rating plate in ...
Resetting Your Heat & Glo® IntelliFire™ Plus Ignition ...
? 2:21
www.youtube.com/watch?v=_-8dY8tUGhw
Aug 24, 2012 - Uploaded by HeatandGlo
Resetting Your Heat & Glo® IntelliFire™ Plus Ignition System Video ... Relighting Your Heat & Glo® Standing Pilot FireplaceVideo - Duration: ... How to Install Your New Gas Log Set - The Fire Place - Palm Desert - Duration: ..
Oct 07, 2015 | Heat N Glo 6000 Gas Fireplace Manual
Have installed a new Honeywell thermostat. The fan does not turn off even when the room has reached the desired temperature. I originally replaced th ethermostat because the old one the fan ran forever and...
Most T-Stats have a On / Auto on a forced air system. On means the fan will run all the time even if it is not calling for heat. Auto only runs when calling for heat. Does the fan turn off in the auto mode at all? To test it...BE SURE THE FAN IS IN THE AUTO MODE ON THE T-STAT... Turn the thermostat all the way down and keep it there for appox 15 mins. If it is wired properly and the fan limit is set properly the fan should turn off. If it doesn't it is not the thermostat were the problem lies.
Most forced air units have a fan / high limit switch. There is a setting on the switch for the fan to turn on and a setting for the fan to turn off or it has a setting and a differental switch for it to turn off/on. Example - the fan comes on when the temp in the heat exchanger reaches 110 degrees F and will shut down at 95 degrees F after the thermostat is satified...this would hav a differental of 15 degrees F. It may be set to low and the fan continues to run long after all of the heat has been removed from the heat exchanger. This in turn will cause cool air to be coming out of the registers.
Mar 09, 2011 | Honeywell CT87B ROUND HEATING&COOLING...
Heating unit blows warm air then turns to cold air
it sounds like unit could be kicking out the low pressure switch or if it is a electric furnace it could be the sequincers
Jan 11, 2010 | Ruud UBHC Air Conditioner
Driver's side heated seats keeps shuting off
try swopping the feed wires around and run the passenger one over to teh drivers side
Oct 23, 2009 | 2004 Saturn VUE
Yamaha ar 230 engine middle lightcome on in on both tach and shut
With the newer yamaha jet boats your route of easiest resistance is gonna be to take the boat to a Yam dealer so they can put a diagnostic machine on it. Alot of sensor problems can be solved much easier and cheaper after running the diagnostic and pinpointing exactly what the issue is. The lights on the dash are for high temp and low oil. If you checked the water temp and it seemed ok, check your oil levels.
Apr 12, 2009 | Sport & Outdoor - Others
Dyna- glo tag along info
these units do not have a low oxygen senser on then,they only have a tip over senser.they work very well in a tent for warming the air up in the tent.but tents do have a lot of air flow tto them.must of the heat goes up to the roof anyway.they are nice to turn on in the morning to knock the chill out of the air to get dressed.hope this helps,let me know
Mar 17, 2009 | Dyna-Glo Double Tag-a-long Heater
Shuts off when switched to low and smells when running.
clean the burner and the orifice you can use a air line or blow off a vacum cleaner
Nov 20, 2008 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
Glo warm?
u need a 100 lb tank minimum for the heater to operate properly
Oct 19, 2008 | Desa International Blower Glow Warm Wall...
Desa International GWP20T GLOWARM  Wall Mounted Panel Heater Logo
109 people viewed this question
Top Desa International Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
