Question about Microsoft Windows Vista Ultimate Edition
What is the computer access code - Microsoft Windows Vista Ultimate Edition
  • Nikola Malesevic
    Nikola Malesevic May 11, 2010
    Hi.
    Can you please explain what exactly are you trying to do when you are being asked for computer access code?
  • 38 Answers
Same as password, a series of characters and numbers that enables a user to access a computer.
Posted on Oct 03, 2009
Forgotten my computer access code
If you are referring to the power up access code screen that comes up when you first turn on your computer, it can be erased by removing the disc type button battery located on your motherboard. Make sure computer is un pluged from the power source. Remove the button battery for 30 seconds. Re-install it and power the computer up. It will boot up normally. If you are referring to a lock out of your Operating System, you will need to purchase a password recovery / reset program and load it into your computer during start up using the boot drive options selections located in your start up / set up menus. Its usually called: Boot Options or Boot Drive Options
Jul 14, 2014 | X2 Systemax NO OS AMD Desktop Computer -...
Chrysler 300 esp bas light along with abs light
You'll need someone to check the body computer for trouble codes to know what to do next. You may find an auto parts store with the right code reader to access the body computer, but most readers only access the engine computer.
Once you have the codes a mechanic can check those codes to find the problem.
Jul 14, 2014 | 2008 Chrysler 300
I need a access code to recieve a fax
you have a fax machine or you have a fax program on your computer?if you have a fax machine you dont need access code.
Nov 27, 2013 | Brother IntelliFAX 1570MC Plain Paper Fax
Traction control light keeps flashing why? no codes
Are you using a scanner that will access the body computer ?
Generic code readers may only access the engine computer.
Jan 16, 2013 | 2000 Jaguar S-Type
Transmission selonoid assambly
Diagnostic Test Code (DTC) P1750 is a "generic" OBD fault code that is output by your engine control computer to let you know that the transmission control computer is reporting a problem with one of the transmission control solenoids. To find out the nature of the problem and which of the solenoids has the failure, you must access your transmission control module and retrieve the fault codes from there.
The transmission control computer outputs 2-digit codes that are not accessible by a generic OBD code reader.
Jan 20, 2012 | 1998 Mitsubishi Montero Sport
How do I lock access to my DIR-615 router
Go into the routers configuration pages and turn on wireless security.
Use your browser and type 192.168.1.1 into the address bar. Type in admin for the logon and admin for the password and the routers options will be displayed. When you turn on wireless security, you will need to enter a code key. Write down the code key as you will need to enter this key into every computer that you wish to use your network.
Then save and reboot the modem.
Thats it.
Enter the code on the computers accessing the network and they should be fine too.
The code key should be kept in a secure location, stuck up on your desk is NOT a secure location.
This will prevent any computer that does not have your code key from accessing your network.
Jan 22, 2011 | D-Link DIR-615 Wireless Router
Set up access code
You want to secure the wireless network.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Click Here for step by step instructions
Jan 31, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
How should i find my computer access code
need more info bios code,windows code,windows op serial code? please be detailed
Jun 29, 2009 | X2 Systemax NO OS AMD Desktop Computer -...
Computer Access Code
To create a new access code
  1. Go to the host PC whose access code you would like to change.
  2. Make sure that the GoToMyPC service is running (look for icon_white2.gif icon in the system tray).
  3. Right-click on the icon_white2.gif icon in the system tray and select Change Access Code.
  4. Click the Forgot it? link.
  5. Enter your email address and account Password.
  6. On the New Access Code dialog box, enter your new access code, confirm the new access code and click OK.
Note: You will need to be at the host PC to perform this function because you will not be able to log in to your host PC without knowing the Access Code for that PC.
Thats if you want to change the access code but if you are simply looking for your access code you need to get in touch with your group.
Code Access Security is a new concept brought in by the .NET framework. Code access security essentially involves granting permissions to an assembly. Code access security uses the location of assembly and other information about the identity of code as a primary factor in determining permissions to be granted to the assembly. This information about the identity of an assembly is called evidence.
Once loaded in runtime, the code starts executing in the restricted environment depending upon permissions granted to it. If the code is not trusted enough to run or runs but performs an action for which it has no permissions, then a security exception is thrown.
The code access security system means we can stop running of malicious code and also restrict the code to run in a restricted environment where we are sure that it won’t do any damage to the resources. Let us now see few cases where code access security becomes
crucial.
Suppose an organisation is working with some extremely important data, we would use a code access security system to state which code is allowed to access the database and which is not. Similarly if we run an application from a network drive and it tries to access the file on a local drive an exception must be thrown. This can be done using a code access security system.
It is important to know that code access security protects resources like local disk, network, user interface from malicious code. It is not a tool for protecting software from users.
Code access security works on the basis of Code Groups and Permissions.
Dec 05, 2008 | X2 Systemax NO OS AMD Desktop Computer -...
Microsoft Windows Vista Ultimate Edition Logo
19 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
