Question about Sewing Machines
I already tried to check my needle, yet the threads still do not join or sew.
I have check the flat side of the needle, yet no change took place. the upper tension still does not join the lower tension. Any other suggestion?
  • Sewing Machines Master
  • 7,365 Answers
The machine could need some type of adjustment or there could
be a timing problem and the machine needs to be serviced.
Posted on Dec 31, 2012
5 Suggested Answers
SOURCE: Thread in needle or bobbin keeps on breaking
The tread only breaks in the needle. what can i do . i don't get to sew anything . I tread the needle and get everything ready and start the machine and as quickly as that the tread is broken and the machine has not sewn at all.
Posted on Apr 07, 2009
Zenqi
  • 208 Answers
SOURCE: My white 2000 serger is dropping the thread on the
Could be as simple as poor quality thread (not using MaxiLock thread), the needles not inserted properly (the left is slightly higher than the right), a missing stitch forming pin on the needle plate, the needle bar being too high or a looper timing issue.
As the needles raise, the upper looper should move to the right with the right needle tip slightly above the eye of the looper.
Posted on Jul 19, 2009
  • 36 Answers
SOURCE: lower thread tension very loose
is the bobbin threaded correctly? the screw on the bobbin case is the point to adjust its tension.
Posted on Jun 02, 2010
  • 48 Answers
SOURCE: upper tension too tight. Have
You need to check to see if your bobbin tensioner has broke. Look at your schematic to determine if everything is still where it's supposed to be. Good Luck.
Posted on Apr 20, 2011
I took my needles out to change them and can't get them back in!
Heather, switch off machine from electric supply.gently lay machine on its back, you will then be able to look at the needle holder .remember the needle has a flat side and this must corispond to the shape where the needle enters into the space for it . be sure you tighten needle into place with the tool provided for the job. Reston machine back onto it's base . Tread up machine and slowly turn by hand the side wheel to make sure the needle is in the right place. When this is working you can refit electric cable as continue sewing. P'S try sewing on a bit of spare fabric to make sure all is well..happy sewing , lois
Aug 20, 2016 | Sewing Machines
Why does my bobbin thread tangle around my bobbin plate
try changing the needle
Correct needle insertion is mandatory for proper use of your sewing machine.
Raise the needle bar to the highest point, then loosen the needle clamp screw to remove the old needle.
Place the new needle in the needle clamp with the flat side of the needle facing the back, (round needle, the groove in the needle should face away from the shaft).
Push the needle all the way up as far as it will go. Then tighten the needle clamp screw.
try rethreading the machine top
Jun 10, 2012 | Brother Sewing Machines
The thread keeps on snapping when i sew straight stitch?
try adjusting the top thread tension-to see if the tension is too tight
rethread the machine--top & bobbin just in case the thread is caught some where
check to make sure there aren't any burrs on the needle plate
Jun 05, 2012 | PfaFF Sewing Machines
My sewing machine singer 7256 giving me a problem causing my fabric underside stitches bird nesting and suddenly the bobbin case comes out from its place and thread strangles and stuck, Why?
try changing the needle-- Correct needle insertion is mandatory for proper use of your sewing machine.
rethread the machine top & bobbin
make sure the thread has not come off the thread take up lever
also check the top thread tension
do you have a manual?
Jun 04, 2012 | Singer Sewing Machines
Janome mini heavy duty sewing machine
when you sew keep a eye on the thread take up lever & see if the thread comes off while your sewing, I've had this happen to me & I've been sewing for over 30 years. if this does happen, take a pair of pliers & very gently close the take up lever just alittle but not enough to damage it.
also check the needle to see if it's damaged--if your not sure change the needle--flat side goes to the back of the machine
always make sure the fabric & needle & thread are compatable--the thread must be able to pull thru the needle with out any problem
also check to make sure there are not any burrs on the needle plate or bobbin or bobbin case
Feb 26, 2012 | Janome SEW MINI Mechanical Sewing Machine
I was sewing, turned the machine off to pin something, and when I turned it back on, it jammed in the bobbin area. It will only stitch one stitch and then jams. I have taken it apart over 30 times, and...
have you tried changing the needle-
1.the needle may be bent or damaged--try rolling the needle on a flat surface to see if it's bent or not
Correct needle insertion is mandatory for proper use of sewing machine.
Raise the needle bar to the highest point, then loosen the clamp screw to remove the old needle, place the new needle in the clamp with the flat side to the back of the machine or if using a round needle--the groove in the needle should face away from the shaft.
Push the needle all the way up to the stop or as far as it will go, then tighten the needle clamp screw
2.upper tension may be to tight--try 3 to 5
3.thread may be hanging up in bobbin case--check area for loose threads or lint
check the thread take up lever-if the thread come off the thread take up lever that will jam the machine up--I've had it happen to me
Sep 13, 2011 | Euro-Pro Shark 9110 Sewing Machine
Brother xl-2600 As I am sewing ( not thick material) the thread keeps breaking, also over seams it is not sewing through. Then, when my bobbin ran out, went to change it and when pulling the needle down...
try changing the top thread tension to 3 or 4
also rethread the machine just in case the thread is hung up somewhere
take the bobbin out & put the bobbin in reverse of what you did before
you said you changed the needle, check to make sure it in correctly,, the flat side goes to the back of the machine, push it all the way up before tightening the screw
Aug 06, 2011 | Brother XL-5340 Mechanical Sewing Machine
Singer TT600A needle is moving, but stiches are unformed. I've tried everything. I've already changed the tension and did everything in the manual repeatedly.
Make sure the needle is installed with the flat side of the needle shaft to the back of the machine.
A sewing machine should always be threaded with the presser foot up. This opens the tension control so the thread can "seat" into the control.
When a sewing machine is threaded with the presser foot down, the tension control does not open to properly accept the thread.
If the machine is already threaded, lift the presser foot and pull about 6" of thread through the needle.
Last resort: the machine needs to be taken in for service. Sometimes the stitch is not forming because the timing needs to be adjusted.
Apr 01, 2010 | Sewing Machines
Needle is falling out. could the threads be gone in the little screw that holds it in place? was working fine till went to change broken needle yesterday. also seems like its hitting off the bobbin case...
Hi! Sewing machine needles have a flat side on the shaft. This flat side has to go in a specific direction, depending on your sewing machine. For example, on both my Kenmore and Brother machines, the flat side has to be at the back (facing away from me), but in my Singer Featherweight, the flat side goes to the left. Unless the flat side of the needle is in the correct place, the bobbin thread will not pick up and the needle may hit the bobbin case.
If you have the manual for your machine, check there to see how the needle should be inserted. If you don't, I suggest you try 'trial and error' to find where that flat side of the needle shaft goes.
Happy Sewing and let me know if this solves your problem!
Feb 10, 2010 | PfaFF Sewing Machines
Stitches are skipping, bobbin problem?
Here are a few things to try. One of these should fix your problem.
* Re-thread your needle
It may be threaded incorrectly (backwards).
* Change your needle
Your needle may be blunt, bent, or otherwise damaged.
* Your fabric may require a different needle. Generally, heavier fabrics require larger needles and
thinner fabrics, smaller needles. You may also need a larger needle if
you’re sewing through many layers of fabric. And make sure to use a ballpoint needle for knit
fabrics and a sharp needle for wovens (or a universal needle for either).
And make sure your needle is appropriate for the type of thread you’re using.
* Adjust the pressure of your pressure foot
It may be too light for your fabric.
* Change your thread
If your upper thread and bobbin threads are different types, try using the same thread for
both. And use a good quality, brand name thread.
* Adjust your thread tension
It may be too tight or too loose.
* Re-thread your machine
It may be threaded incorrectly.
* Change your needle plate
Try switching to a needle plate with a smaller hole (a straight stitch needle plate).
* Reinsert your needle
Make sure it goes all the way into the holder and that it’s positioned correctly – usually with the
flat side away from the bobbin, but consult your machine’s manual to be sure. I know you said you checked this already but it might not hurt to double check it.
Important Note:
After changing your needle plate, check to make sure your needle aligns perfectly with
this smaller hole before starting to sew. A misaligned needle could hit the plate and break, which
could be dangerous. And make sure to change your needle plate back for zigzag and other wide
stitches.
Hope this helps.
Sep 15, 2009 | Kenmore Sewing Machines
Sewing Machines Logo
12 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
