Question about Hotpoint RB787 Electric Kitchen Range
Clock and lights work but burners and oven will not heat turn on
I flipped
  • 4 Answers
I know how to solve this. call me at 757-454-2358.I know how to solve this. call me at 757-454-2358.
Posted on Apr 15, 2009
Why won't the oven or the burners heat up on our brand new model CFEF3018LB range
Thank you for your inquiry, friend!
It could be a possible issue with the control panel or burner switches within the Frigidaire range. I would recommend performing a reset on your appliance which you can do by flipping the household circuit breaker off for ten minutes. It could also be an issue with your range not receiving sufficient power. You may want to seek assistance from a professional for proper repairs. -Matt
Oct 16, 2014 | Frigidaire Kitchen Ranges
My stove is a GE and everything works but the burners and oven.
check your breakers everything you said means not enough voltage
Apr 05, 2014 | GE Stove/Oven/RanSurface Burner Knob -...
Moved Kenmore electric oven (2 yrs old) and now neither the oven or stovetop heat up. The clock is set.
This may sound silly, but go check your circuit breaker and flip it completely off and then back on. Sometimes it does not completely trip and your clock only needs 120 volts to work which you have, but the heating coils need 240 volts. If you have an older house that has a fuse panel instead of circuit breakers you could have a blown fuse.
Feb 12, 2014 | Kenmore Ovens
My Frigidaire electric range wont work (burners and oven)
The clock display works on 120 volts but the burners and oven require 240 volts. I would check the breaker or the receptacle to see if they're bad.They may be supplying only 120 volts. One more less common problem could be the terminal block on the range where the power comes in. Very rarely they will melt. BE SURE TO UNPLUG THE RANGE if you have to check the terminal block. Hope this helps.
Feb 12, 2013 | Frigidaire Ovens
Oven will not heat up
Is the gas turned on? Do the stove top burners work? Check for kink in gas hose.
Nov 11, 2012 | Ovens
We recently moved, when we got to our new house we plugged in our stove. We turned on the burner and it didnt work, we tried the other three and they didnt work either.. Finally we tried the oven but there...
i would first try the breaker it sounds like you only have half the power coming to unit and the light and clock will work but the heating componets will not as they require the full 220-245 volts
it sounds very odd that everything as far as burners and elements are out but you have a clock display and light... you have lost one of the legs of power somehow...either the double breaker is not fully on and may require turning off oven breaker and resetting or half the breaker has failed... a sure way of testing would be to pull out and with a volt meter test to see that you have 220-245 volts coming to oven,,, hope this helps out repost if anymore questions...
Feb 07, 2011 | Amana Kitchen Ranges
Model FEFL78CBC frigidaire oven bottom (bake) burner won't work everything else works fine --even broiler element works fine. Just used self-cleaning cycle, which did work. Next morning oven won't heat ....
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
Nov 28, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Clock and lights work but burners and oven will noy heat turn on
Your wire connection from service panel to stove is corroded. It needs replacement. Check the length of the wires (three: two hots, and one neutral). Turn the breaker off first. Call me at at 757-454-2358 if you need anymore help. I don't get online often, so you need to call if you want anything clarify.
Jan 18, 2009 | Hotpoint RB787 Electric Kitchen Range
No heat in oven or on range
when you turn on the top burners do you hear the ignighters clicking please hold my rating for now as i need to ask a few questions
Jan 11, 2008 | Frigidaire FES367 Electric Kitchen Range
No heat at burners or oven
check your fuse / breaker box make sure you have power (sounds like you dropped a leg of power) make sure breakers/fuse is on/good flip it to off the to on if oven don't work then take a look at the cord to the range check power at the wall then open where cord goes into range check power or you may even find the cord burnt in there if so replace all damaged wires good luck
Dec 21, 2007 | GE JBP82 Electric Kitchen Range
Hotpoint RB787 Electric Kitchen Range Logo
172 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Justin Duby
Justin Duby
Ismael Rodriguez...
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
