Question about Dishwashers
The outlet hose has broken just inside the back of my dishlex dishwasher. How do I fix this ?
  • 17,129 Answers
Click this link for tips : Dishwasher
Posted on Jan 24, 2013
  • 10865 Answers
SOURCE: dishwasher water at bottom of well.
That little plate has to be gently removed with a screw driver and a hammer.
Posted on Apr 01, 2009
Maytag317
  • 1136 Answers
SOURCE: leaking dishlex dishwasher outlet hose
HI If you get me the model#, I can look this up for you.
Thanks
Vic
Posted on May 23, 2009
SOURCE: Dishlex 500 dishwasher doesn't fill.
The cup looking device shoud be a switch that turns the solonoid off if water leaks there ,Try bypassing the switch to see if it works,Also check the door switch to see if it is making,Hope this helps Cheers.
Posted on Jul 30, 2009
mnwarfield10
  • 452 Answers
SOURCE: how do I open a Dishlex 300 dishwasher with a
just pull it ...it should open.............
Posted on Dec 30, 2009
caroldon
  • 17129 Answers
SOURCE: Where can I find a drain hose for Vulcan Dishlex
Contact the pneumatic dealership / hardware shops where a variety of hose sizes will be available. Take the sample size hose and measure the length required for the drain.
try this link for an universal type hose
http://cgi.ebay.com.au/Universal-2-5metre-Dishwasher-Outlet-Hose-W063B-/140229403478?pt=AU_Home_Appliances&hash=item20a652e356
Posted on Sep 14, 2010
Dishlex global300 is gone into flood mode how do I fix it
Dishlex Global 300 Dishwasher issues - Kitchen - Home - Whirlpool ...
forums.whirlpool.net.au > Home > Kitchen
WhirlpoolAug 31, 2011 - As stated in the title, it is Dishlex Global 300 model and it was here when ... is flooding about to happen inside the DW and prevents flooding). Bosch or Asko dishwasher
Mar 7, 2014
Dishwasher that actually WORKS PROPERLY?
Dec 3, 2012
Dishlex Global 300 dishwasher woes
Aug 8, 2005
Dishwashers ...
Mar 28, 2004
More results from forums.whirlpool.net.au
Nov 25, 2015 | Dishwashers
Electrolux Dishlex DX302SJ#6 not draining
make this test and fix it. Merry Christmas
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Read more: http://www.appliancepartspros.com/repair-help/dishwasher-repair-help.html#3#ixzz2nvKv4oia
Dec 19, 2013 | Dishwashers
Where can I find a drain hose for Vulcan Dishlex 550 Hydrapulse dishwasher
Sep 14, 2010 | Dishwashers
I have a dishlex Global 500 which runs for 3-5 minutes then displays nF
nf= not filling. check inlet vale, or fault will be with pressure switch. If you have poor water pressure, you may need to increase the fill time- insructions can be downloaded from:www.electrolux.com.au, click on "customer service", then "download manuals", then Dishwashers-semi integrated, electronic, then download Dishlex Global Part 1 and Part 2.
Information on setting fill time can be found at the back of Part 2, but Part 1 has a list of the fault codes
Aug 05, 2009 | Dishwashers
Jul 30, 2009 | Dishwashers
Leaking dishlex dishwasher outlet hose
Thanks
Vic
May 23, 2009 | Dishwashers
Check water light is on
I had the same problem! First disconnect mains power, then switch off the mains water to the water input hose, and disconnect the hose. Disconnect the waste outlet hose from your drainage. ( this will release some water from the hose ends, so a washing up bowl would be handy ) You will need to tip the dishwasher on to it's back, be carefull not to damage the waste outlet hose, and watch out from more water spillage. Next remove the two screws on the base metal cover, and spring out the cover from the two side clips, the cover can then be removed, you should have a screw holding an earth lead remove screw and lead from cover.
Inside the bottom of the dishwasher you will see a small electric pump fitted to the side of the dishwashers drain, it has two wires with spade connector on them, disconnect these from the pump noting colour of the wires for reassembling. The pump has the same diameter hose as the outlet hose. Next carefully remove the rubber elbow pipe from the pump and hose end this will need to be washed with clean water. Then to remove the pump, press and hold down the locking tab, where the pump is fitted to the drain, and twist the pump anti-clockwise. The pump will then release from the drain. Inspect the pump impellers for damage, and that the pump has free movement, also check condition of the rubber O-ring. Inspect inside of drain for broken bits of china and glass, remove and clean, also check the outlet hose for any blockages.
( run some water though the hose backwards from the water tap and collect it in a bowl from the pump end of the hose ) Reassembly is the reverse of the above, check electrics inside have not got wet, if ok switch on. The check water light should now be off.
Alan
Jan 11, 2009 | Bosch 24 in. SGS43C12 Classixx...
Electrolux dishlex dishwasher
www.nzherald.co.nz said it affects Electrolux dishlex machines with serial numbers 70700000 to 72400000
Jul 25, 2008 | Electrolux 23 in. ESL624 Built-in...
Dishlex global 300
try holding the start and program buttons simultaneously for a few seconds, it seemed to reset itself for me-i have done this a few times now.
Feb 04, 2008 | Dishwashers
Dishwashers Logo
66 people viewed this question
Top Dishwashers Experts
Owen Barnes
