Question about General Electric RanCooktop Stove 6" Heavy Duty Surface Burner Wb30t10001
How to replace gasket on ge jgsp28sek2ss
MFG Part Number: WB04T10059
2 Suggested Answers
Ge pfs22mi door gasket
This is going to be tricky so watch the video and tell me if the answer to you question comes out and resolved by the tricks revealed in the below video.. Sea Breeze
When you say latch can you tell me the part number of the latch you say that you need replaced? Here is a link to the parts you are describing HERE
GE Profile French door bottom freezer Model # PFS22MISBWW Door Gasket and related parts
Apr 01, 2013 | GE Profile Bottom-Freezer Refrigerator...
What is the part number for the rubber gasket or bellow for the GE front load washer Model #WBVH5200?
The door rubber gasket/bellow for GE WBVH5200J0WW/J1WW/J2WW/J3WW/K0WW is part number WH08X10036. The said part may look a bit different from the original one installed on your machine but it is an original equipment manufacturer replacement part and is equivalently functional.
Jul 18, 2011 | General Electric WBVH5200J Front Load...
SN tag missing from pre-owned Advantium SCA1001FSS001
A missing or unreadable serial number relieves the manufacturer of all responsibility for any warranty, so all parts and labor cost will be on you.
For future reference, the service manual is here.
You can order parts and accessories here.
You can download GE owner's manuals and installation instructions here.
Jul 02, 2010 | GE Advantium 120 Convection/Microwave Oven
Broken door gasket how to replace on GE front
You'll need to determine which bellows gasket your washer needs before you undertake the repair. Go to the following link and enter in your washer model number to get the line drawing and parts breakdown.
http://www.searspartsdirect.com/partsdirect/index.action?pop=flush
Click on the "find a part" and enter in your model number
Typically, the tub gasket (door seal) is part number #WH08X10022 with a new substitution part #WH08X10036. However, since each model can be slightly different, depending on the serial number which denotes when it was manufactured, you might want to confirm that the above gasket is the correct one for your particular washer.
You can also call the folks at Sears Parts Direct at 1-800-252-1698 and give them your complete model number AND serial number before you start in on the repair, so you can be sure you have the correct substitution bellows gasket.
It's a relatively easy repair, all you need to do is remove the spring retaining wire around the outer edge of the bellows gasket, just peel it back at the edge to see it. Now locate the locking loop by going around the rim. Once you find the locking loop, you can remove it using a couple pairs of small needle nose pliers as they make it easier to get off.
Once you've done that, you'll see the locking plate that holds the back side of the bellows gasket onto the outer washer tub. Remove those fasteners and you can get the bellows off and start in on putting the new bellows onto the washer, just reversing the order you used in the removal process.
Just take your time removing the old gasket so you remember what you're doing and when installing the new gasket so as not to rip or tear it in the process. I'd also suggest you let the gasket relax for a good 4-5 hours (to get the kinks and folds out of it from the packing box) before you do the installation.
Here's another link to one of my other solutions for installing a bellows gasket on a GE front loading washer that you can also review for more installation tips, etc.
http://www.fixya.com/support/t2730376-need_help_in_installing_door_bellow_ge
Hope you find this Very Helpful and best regards!
Sep 15, 2009 | GE Washing Machines
Door seal ripped , model is GE Adora GHDVH670HWW. I need a part number for this seal, cant find anything anywere
This is the model that was made by GE to be sold exclusively though Home Depot stores. The cross over model is the GE WCVH6600H0BB
The tub gasket (door seal) is part number #WH08X10022 with a new substitution part #WH08X10036. However, since the GE Adora line might be slightly different, depending on the serial number which denotes when it was manufactured, you might want to confirm that the above gasket is the correct one for your particular washer.
I'd suggest you call the folks at Sears Parts Direct at 1-800-252-1698 and give them your complete model number AND serial number before you order any repair parts, so you can be certain they'll work for your washer.
It's a relatively easy repair, all you need to do is remove the nuts and washer at the top and bottom of the cabinet all around the opening (once you've opened the door) to get the counter balances off, so you can access the gasket and remove it and replace it with the new one.
Here's a line drawing that shows the exploded view of the tub section, with the gasket (item #306). Just take your time in removing and reinstalling the new gasket so as not to rip or tear it in the process. I'd also suggest you let the gasket relax for a good 4-5 hours (to get the kinks and folds out of it from the packing box) before you do the installation.
http://www.searspartsdirect.com/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fGR708157-00004.png
Aug 25, 2009 | GE Washing Machines
The rubber door gasket is torn, how to replace,
Get the model number off the washer
and go to appliance store who service or Sears
Jun 10, 2009 | GE WSXH208A Front Load Washer
General Electric RanCooktop Stove 6" Heavy Duty Surface Burner Wb30t10001 Logo
29 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
