Hi, It's a dental chair unit. And I have problem with this control board. When I switch it on, it keeps on trips like this. I don't know where to start with? I checked the board for the damage and fou
  • danny tan
    danny tan Apr 04, 2017
    could be a bad capacitor or some component that spoilt. check the board for burnt marks..
    New Friend:
  • 28 Answers
You might want to look at this:
Posted on Dec 31, 2012
No lights, won't run. Nothing. Worked fine yesterday.
Hello. Critical question--is the dishwasher on that GFCI circuit!? If so, (A) you might have voided any warranty and (B) you should NEVER have appliances with digital boards on a GFCI circuit. Why? Because the method GFCI breakers and outlets use to keep us safe(how they reference current to ground) can blow out the electronic control boards plugged in to the circuit they monitor. I am ALWAYS telling my customers to immediately switch out an outlet or breaker which is protecting a washer, dishwasher, or microwave. I know that electrical codes often mandate that a GFCI device be within 3 feet of a water source but the design engineers didn't think about that one...It often is buried in the users manual to NOT connect the device to a GFCI.
Now, after all that, I need the model number of your unit to help you most accurately--some dishwashers have a main fuse on or near the main control board. If this fuse opens, voila! The unit is D-E-A-D until you replace the fuse. However, if there isn't a fuse, you've got a blown main board(and possibly user control panel, too). Power slams like the one you experienced are notorious for damaging control boards. That's why power outages are so destructive--they either blow out boards immediately or cause them to fail in about 3-4 weeks afterwards due to the damaged chips on the board starting to fail from over-current/voltage. I hope I helped you!
Oct 02, 2015 | KitchenAid Dishwashers
I need bay a 3 to 5 trophy x ray tube trx708 dental
Try to consult with the dentist that may give better ides as well as you can know about the bay dental, which I know about DentistsinmobileAl here you will get more detail about bay dental.
May 17, 2014 | Trophy TRX708 Dental X-Ray
Chair is stuck in a raised position
Hello. The chairs lift needs to be cleaned from the inside and the hydralic fluid changed.
Apr 18, 2014 | Flight Dental A10E Patient Chair
Dental chair
Have to call the gnatus dental technician...
Jul 26, 2013 | Medical
I don't know what kind of chairs to put in my living room. What should I do?
EBay has a really great Buying Guide regarding living roomchairs. It give you certain things youshould know and some tips to keep in mind when looking to purchase chairs foryour living room. Check is out here:
May 29, 2012 | Furniture
Hi i have a rheem super quiet 80 attic unit.. the heat is not working.. the unit will not power up and circuit board is not lit
Hello, if the furnace does not work at all the main thing to check is your line supply voltage. low voltage and fuses. Make sure the circuit breaker is not tripped and verify that you are getting 120 volts to the integrated control board at the L1 nd neutral terminal at the board, if not most likely the breaker is tripped, secondly make sure that the fuse on the unit is good, usually it will be on the integrated control board if it is a newer furnace or on the side of the furnace at the switch box if it is a older furnace, make sure the fuse reads 0 ohms with your meter. Lastly check the transformer, check Resistance on both sides of the transformer and you should get resistance, if not replace transformer, let me know if you have any further questions I will be glad to assist you.
Feb 05, 2011 | Heating & Cooling
Tripping electricity
HI, The reason for the over-pull is due to the unstable conditions located at the main PCB that controls this affected unit. The voltage is not stable, due to the damage located at the PCB(circuit instabilities). Just to be safe, have your local electrician inspect the breaker box for shorts and damage to the appropriate circuit block. If the electrician confirms that the breaker is in good condition; replace the main control board(PCB) that is mounted near the compressor or behind the rear access panel.
Jul 21, 2010 | Whirlpool Freezers
After a power down the range keeps coming up EO F2? I have reset using the OFF/clear button. Oven lights but trips off to EO F2
Hi. This code is an indication of a Shorted keypad (also called touch pad)
Follow the steps below to address this issue further.
1. Check keypad connector for firm connection (keypad connects to control board, via ribbon cable). Make sure the connection is sound, and not severed.
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models may incorporate the keypad in to the control board as one unit. In this case, replace the entire control board (also called ERC or clock).
Dec 04, 2009 | Kenmore Kitchen Ranges
Chair will not go up or down
The clicking is the mechanical part of the switch, but the electrical part may still be bad. In all the chairs I have serviced, it has always been the switch. The switch itself goes for about $25 plus labor to change it, and the whole control unit retails for about $100. the best test is to take the controller apart and short out the center wire to either side and check the chair for movement.
Jan 22, 2009 | Pride Mobility Products Casual CL30KD Lift...
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
