Question about Dishwashers
Lg ld2131sh leaking
Checked all water connections and no problems. only leaking when in cycle
4 Suggested Answers
Master_Tech
  • 770 Answers
SOURCE: LG 3 in 1 Dishwasher model LD2131SH
E1=Water inlet Error
Not reached to the normal
water level in spite
of 10 min. water supply
Causes:
The Water Supply Tap is closed.
The Water Supply is shut off.
The Inlet Hose is kinked.
The Water Pressure is very low.
(below 10 psi)
Inlet Valve is OK?
The filter of Inlet Valve is clogged
by impure water.
The Hall sensor is OK?
The Impeller of Air Guide is bound
Solutions:
Take action on Water Supply
device.
Measure the electric resistance of
Inlet Valve. (950-1300 )
Clean the filter of Inlet Valve.
Check the frequency of Inlet Water
by the Test Mode.
Replace the Air Braker.
Posted on Aug 20, 2008
  • 423 Answers
SOURCE: Dishwasher states there is a water leak when visually there isn't
Assuming that you have checked under the dishwasher for a leak (through a faulty sump gasket):
Since there is not actual leak, check the following:
-Confirm that the height of Drain Hose connection (sink-Drain Hose) rises greater than 20′ _minimum_ as it travels to the drain connection.
-If that does not solve the problen, it is probably a worn/broken Impeller of the Washing Pump.
Unless you are mechanicly incliend, a service call is probably the way to do. If you need further steps, please reply. Otherwise, after you ahve used the advise, please accept this solution.
Posted on Mar 28, 2009
SOURCE: LG LD2131SH dishwasher has an HE error code. What can that be
I need operating manual of LD2131SH, thanks
Posted on Aug 09, 2010
We are having a problem with our LG Dishwasher. The machine is washing for about half an hour and then will stop and report an E1 error. According to the user manual this means "Water leakage in Hose...
Most of the problem in dishwasher is related to float switch that informs the timer to move to the next cycle. There are two float switches, one for water level and the other one for water empty or drain. These two must move else the cycle will continue for ever.
May 07, 2017 | Whirlpool 24 in. DU940QWD Built-in...
Water leaks (drips ) into tub after cycle/spin is complete
You have a bad pressure switch or the small hose connecting to the pressure switch may be bad
If the washer leaks water when is filling only, check the following: 1.Fill hoses
2.The water mixing valve
3.Filling injector ( If your washer uses one )
4.Filling spout
If the washing machine leaks during the wash cycle, check the following:
1.The pump
2.The tub stem & seal
3.Tub to pump hose
4.The drain hose
5.Tub (rusted holes)
6.The drum support bolts
If the washing machine leaks during the spin cycle, check the following:
1.The drain hose
2.The tub cover seal
3.The pump
4.The pump hoses
5.The stem & seal
Feb 10, 2008 | Maytag LAT2300 Top Load Washer
Ge top load washer leaks from over flow during spin cycle
check your pump it may be partly plugged if it is try to clear or replace pump
Aug 06, 2009 | Washing Machines
Mar 28, 2009 | Dishwashers
Machine leaks at beginning of rinse cycle
have you checked the rubber seal round the door might be torn
Mar 03, 2008 | Samsung WF337AA Front Load Washer
Water leaking
If the water is leaking at what seems like the beginning of the spin cycle it might be the hose connection to the drain pump or the pump itself. If so, it's a lot easier to fix than the drum seal.
Dec 31, 2007 | Maytag SAV5701A Top Load Washer
Washing machine
If water is leaking only during the times when it is supposed to be coming in , then the first places to check are at the hose connections and the hoses themselves. If it continues to leak after the water stops coming in , then you have to look at the drain connection and finally at the drum seal.
Nov 22, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Leak problem
Ours did same thing after nearly same amount of time.
Run a couple of sanitary cycles without any cloths.
Only use HE detergent.
Problem stopped after this
Oct 08, 2007 | LG WM1815CS Front Load Washer
Amana LWA50AW Washer Leaks!
you need to get the front off... grap a light and get down and look inside to find out whats leaking... with out looking its just guessing check all water hose connections, water pump, and main seal where transmission goes thu drum
Sep 05, 2007 | Amana LWA40A
Dishwashers Logo
24 people viewed this question
Top Dishwashers Experts
Owen Barnes
