Pilot is on but heater is not - Heating & Cooling
    Problem Solver:
  • 5 Answers
Gas valve is on pilot
Pilot flame is impinged
bad millivolt generator
or bad gas valve
Start by cleaning the pilot, than replace t-couple
Posted on Dec 31, 2012
Pilot lite will not stay on when I release the igniter pressure knob REH-18-N wall heater!
IS there gas? YES ok. So if you can get the pilot lit, but when you let up on the button it goes out. Few things to check. On some heaters the manf. install a safety switch to drop the pilot out if its not venting or if its over heating.
Jan 01, 2017 | Heating & Cooling
Wher is pilot light
Why will my pilot light on the gas water heater not stay lit for ...
diy.stackexchange.com/questions/.../why-will-my-pilot-light-on-the-gas-...
Jul 28, 2011 - The pilot light went out on my gas water heater. I followed the ... This could be from a valve not being all the way open. It could also be from a ...
How To Relight Your Pilot Light On Your Water Heater ...
? 7:54
https://www.youtube.com/watch?v=gqM7kMkkFAI
Apr 15, 2013 - Uploaded by TipsNNTricks
How To Relight Your Pilot Light On Your Water Heater. TipsNNTricks .... I answer the following questions in this video. How can I relight my pilot ...
How to Light a Water Heater (with Pictures) - wikiHow
www.wikihow.com/Light-a-Water-Heater
wikiHowJump to Questions and Answers - If the pilot light doesn't relight or goes out immediately after ... if you are unable to light the water heater after several attempts.
Jan 13, 2016 | Water Heaters
HOW CAN YOU TELL IF THE PILOT LIGHT IT LIT?
The Hayward H Series Pool Heater with standing pilot uses a standing flame to safety initiate combustion, and the standing pilot flame is uses to generate about 0.400 to 0.450 volts DC to operate the gas valve.
CAUTION: Your Hayward H Series Pool Heater is essentially a furnace. Only qualified technicians with proper training and tools should repair your heater.
Once you have completed the pilot start procedure in your heater manual, the pilot flame should be visible but it is difficult to see. The pilot is located at the bottom of the heater, to the left side of the burner chamber, about half way between the front and back of the heater. Before attempting to verify the pilot, it's wise to turn the thermostat to the full counterclockwise OFF position. There are two useful methods to verify the pilot: 1) Before you initiate the pilot procedure, place a small mirror on the floor of the heater on the left side of the burner chamber, just inside the combustion area. CAUTION: DO NOT attempt to place or remove this mirror while the heater is in combustion mode! After placing the mirror, you should be able to see the pilot assembly. Follow your pilot start procedure, then you should be able to see the pilot flame in the mirror before you turn the gas valve knob into the ON mode. Be careful to remove the mirror before initiating combustion. 2) Only when the pilot flame is on will the thermocouple generate the circuit voltage required to operate the gas valve. During the pilot start procedure, while the gas valve knob is still in the "pilot" position and the pilot flame is on, the circuit voltage can be measured at the gas valve without danger of initiating combustion. Using a volt meter, measure the voltage between the RED and WHT wires on the gas valve terminals. This measurement should be between 0.400 and 0.450 volts DC. If below, the gas valve will not operate even if the pilot is ON.
After verifying the pilot, be sure to remove the mirror (if used) and the voltmeter (if used), turn the gas valve to "ON", and return the front heater cover before initiating combustion.
May 24, 2014 | Hayward 250kbtu Ng Pool Heater - Inground
Need to light pilot light
You need to turn the knob on the gas valve (inside the heater) to the "pilot" position. Then, while holding a flame over the pilot assembly push down on the knob.
Gas should come out of the pilot and ignite. Continue holding the knob down for 10-15 seconds. Release the knob and the pilot should stay lit. If not the pilot generator may need to be replaced.
Turn the knob to the "on" position, close the heater and turn the heater on and turn the thermostat to hot. The heater should fire. If it does not fire and the pilot goes out, that may also indicate a pilot generator problem.
Nov 20, 2013 | Teledyne Laars Pool & Spa
Where is the orifice on a williams wall gas heater 290622
Where the pilot is unscrew pilot tube from pilot assembly and inside there it is
Feb 26, 2013 | Williams (5009622) Ceramic Gas Wall...
Do not know how to start pilot light
There should be instructions on the inside of the heater access door. Make sure you are comfortable working with gas heaters. Make sure the shutoff valve supplying gas to the heater is on. Turn the gas valve to "pilot", press and hold it while attempting to light the pilot. Once the pilot is lit, continue holding the gas valve knob down for about 30 seconds. The pilot should stay lit once you release the knob. If the pilot stay lit, turn the gas valve to "on". Replace the heater access door and make sure you have proper water flow and attempt to light the heater. If it will not light, or the pilot will not stay on, you will probably have to replace the pilot generator. It provides voltage to run the heater and after time it wears out and produces less and less voltage. A millivolt heater runs on less than one volt so any power loss can be a problem. If you are able, test the pilot generator with a multimeter to see if you are getting at least 500mv when the pilot is on. If not, you should replace the pilot generator or even the entire pilot assembly. Hope this helps...
Sep 27, 2009 | Pentair Minimax Ch 400,000 Btu Propane...
Heater shutting off
this type of heater is very sensitive to the state of the pilot since it uses a Renni type thermocouple to sense a low oxygen situation. Usually the pilot needs to be cleaned. If that does not restore operation only other thing to do is try replacing the thermocouple.
A low pilot will usually hold for a few minutes so I would expect that you have a bad thermocouple.
Nov 17, 2008 | Desa International Blower Glow Warm Wall...
Vulcan freeloader hot water heater
Could be moisture in the gas supply line - get your gas fitter to purge the line at the meter.
Jul 08, 2008 | Heating & Cooling
Heating & Cooling Logo
19 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
