Question about Panasonic SC-BTT490
Cannot access setup menu on Panasonic SC BTT 490
All that is displayed is a blank screen, in addition to this the subwoofer is not outputting sound. All connections have been checker and are firmly in place.
3 Suggested Answers
SOURCE: hi, advice me where I can find the system cable for an SC-HT900?
the system cable you are looking for is called: K1HA25HA0001 If you google it you'll get a number of places where you could buy, including ebay but their not cheap, hope this helps
Posted on Jan 02, 2010
  • 569 Answers
SOURCE: I have a Panasonic Model TC-p42X1 TV hooked up to
It's possible that you have the wrong type of HDMI cable. You need one that has Audio Return if you want to feed your Home Theater system with audio from the TV. There are several types of HDMI cable,some with audio return and some without. The two basic types (not including Ethernet) are described below - you need the High Speed version, which does have Audio Return.
hdmi-standard.jpgHDMI Standard This is the most basic HDMI standard which all cables have to meet. Cable should contain all the connections required for HD transmission, and have to deliver at least a resolution of 720p, (Video mode of 1280 x 720 meaning 720 Horizontal lines). These cables do not contain an Ethernet connection, or audio return.
hdmi-high-speed.jpgHDMI High Speed HDMI High Speed cables will support higher resolutions of 1080p. This means at least 1080 Horizontal lines, and cables rated at this specification may well support high resolutions of up to 4096 x 2160 (2160 Horizontal lines), check individual cables specifications for this data. Cables in this specification will also support a data transfer speed of 10.2Gbs (not to be confused with ethernet data speeds which are different), and a clock speed of 320Mhz. These cables do not contain an Ethernet connection, but do include an Audio Return Channel.
Posted on Feb 03, 2011
Settings for apn are blank. what is my apn code
Hi Edward,
Here are the steps..
Internet Setup
Step 1: Enter Settings
Step 2: Select Wireless & Networks
Step 3: Select More...
Step 4: Select Mobile Networks
Step 5: Ensure Data Enabled is checked (enabled).
Step 6: Select Access Point Names
Step 7: Create a new APN (Select Menu, followed by New APN). Enter WIND Data as the name for the new APN. Under the headings APN enter internet.windmobile.ca (leave all other fields blank).
Step 8: Save the APN settings by selecting menu and then save.
Picture Messaging (MMS)
Step 7: Create a new APN (Select Menu, followed by New APN). Enter WIND MMS as the name for the new APN. Under the following information in the listed headings:
  • APN: mms.windmobile.ca
  • MMSC:http://mms.windmobile.ca
  • MMS Proxy: 74.115.197.70
  • MMS Port: 8080
  • MCC: 302
  • MNC: 490
  • APN Type: mms
  • Leave all other fields blank.
Android 2.1 to 2.3
Internet setup
Step 3: Select Mobile Networks
Step 4: Ensure Data Enabled is checked (enabled).
Step 5: Select Access Point Names
Step 6: Create a new APN (Access Point). Enter any name you would like to call your internet connection and the access point as internet.windmobile.ca (leave all other fields blank).
Picture Messaging (MMS) setup
Step 6: Create a new APN (Select Menu, followed by New APN). Enter WIND MMS as the name for the new APN. Under the following information in the listed headings:
  • MMSC: http://mms.windmobile.ca
  • MMS Port: 8080
  • MCC: 302
  • MNC: 490
  • APN Type: mms
May 10, 2016 | HTC 7 Surround T8788 Windows 7 Wm 3.8"...
Hi i have a dual dvd 210 player and i am not getting any out put from the rca jacks eg front rear or sub the unit is brand new .
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=6&cad=rja&uact=8&ved=0CFEQFjAF&url=http%3A%2F%2Fwww.dualav.com%2Fsupport%2Fmanuals%2Fxdvd210.pdf&ei=fRiLU8-PIIXJsQSj1YD4Cw&usg=AFQjCNHYPq2K6IQ2YgF7SxJ0LIvmb_kJHg&bvm=bv.67720277,d.cWc
Make sure the subwoofer output on the Dual unit is turned to the 'on' position Page 10 of the manual explains how to access the audio options; i.e. the subwoofer output. ." From the main menu screen press setup in the bottom left corner to access the setup menu. Select the audio icon on the top. Use the up and down arrow keys on the right to scroll up and down through the available sub-menu options." Make sure the subwoofer output is turned "on"
May 31, 2014 | Car Audio & Video
I have a Sharp Aquos with a optical output, i conected it to the tv optical input of the panasonic sc ptx7 but it doesnt have audio via optical,on the contrary via rca works perfectly.
hi,
check the following on ur tv
1. Press MENU to display the MENU screen,
and then press c/d to select "Digital
Setup".
2. Press a/b to select "Audio Setup", and then
press ENTER.
3. Press a/b to select "PCM" or "Dolby
Digital", and then press ENTER.
4. Press MENU to exit.
PCM The optical output terminal output studio signal in PCM form. If your digital audio system does not support Dolby Digital, select "PCM".
Dolby Digital
The optical output terminal outputs audio signal in Dolby Digital form. it reproduces sound from surround program of digital.
also check the input assignment of ur dvd palyer's tv input. if it is selected as analog then change it to digital.
ok
Dec 20, 2010 | Panasonic SC-PTX7 Home Theater System With...
Panasonic sb-wa 340 active subwoofer has just low freequensy noice from subwoofer ! The other speakers working good and dvd fanction normally !
This is normal operation.. The subwoofer will only play sounds below a set frequency...There may be a crossover setting in your menu that you can adjust the frequency cutoff to your liking.
Oct 01, 2010 | Panasonic SC-HT690 System
SAHT920 DVD: when movie starts, a BITRATE test screen appears
go to setup and switch off bitrate in the setup display menu
Apr 03, 2009 | Panasonic Audio Players & Recorders
SC-BT !00 Panasonic wireless speaker connection won't link
If you go into the set up menu and go to the speakers set up - it only shows the right, left, centre and subwoofer on the screen. You need to go down to the box below these speakers and activate the rear speakers which are not shown. The wireless section will then light up w1/2 on the display at the front of the scbt100 - i had to call panasonic to figure this out and they advised me it was missing from the instructions!!!
Feb 23, 2009 | Panasonic SC-BT100 Theater System
Unplugged insignia box replugged cannot access menu unit comes on
Plug the Insignia output to TV video 1. Turn on TV, set to video 1 source. Turn on Insigna. You should now have picture and be able to go through the set up again.
Dec 31, 2008 | Insignia Digital-to-Analog Converter for...
SC-RT50 Decoding Surround Sound From Aux and Inputs
The other players need to be setup to output digital sound. Assuming you are using a digital or optical audio cable, go into the setup screen of the Blu-Ray or Tivo etc. and select the audio setup screen. Set the audio output to PCM.
Sep 07, 2008 | Panasonic SC-RT50 System
No sound at all in any mode
If you get a F61 error when the unit is powered on then the output ic is bad.Subwoofer has the power amp built into it.You may have damaged the IC with a mixup in the +/- speaker hookup and the common ground connection in the A/B box.Seems your subwoofer will need service.
Oct 28, 2007 | Panasonic SC-HT730 System
Panasonic SC-BTT490 Logo
87 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
