Question about Masonry Tools
Dewalt shopmaster TP400LS schematic for planer belt replacement
I need to replace the belt on TP400LS planer. Manual doesn't supply any info on how to do this. Any suggestions?
  • 885 Answers
You can go to Dewalt's website at http://servicenet.dewalt.com/ or an aftermarket site like www.ereplacementparts.com to find good breakdown pictures of your tool. You can also order parts from them or get part numbers to search the web for better prices.
Posted on Feb 14, 2013
Bati99
  • 88 Answers
SOURCE: Help i need to change my Dewalt DW733 Planer Blades i lost manual
try dewaltservicenet.com They have manuals as well as parts breakdowns.
Posted on Apr 16, 2009
sparktgo
  • 68 Answers
SOURCE: Need an user/owner manual for a Delta Shopmaster
Heres your Manual:
http://powertool.manualsonline.com/manuals/mfg/delta/tp300.html
Posted on Oct 15, 2009
SOURCE: I need to change the belt on a Roybi AP-10 planer
I called sears and they actually HELPED
Posted on Oct 28, 2009
SOURCE: dewalt 735 planer. dust is accumulating in the
Had the same problem. Drove me nuts trying to figure out where it is coming from. It most likely is a worn in hole in the squirrel cage where the two halves go together. You won't see it unless you remove the fan and both halves of the blower housing. Take them out and put the two together and have a look from the inside. The wear is along the seam. I used hot glue in that area to fill the gap. Squirt it on one half and put the two halves together while hot. Also, you can buy replacements for these. Hope this helps.
Posted on Apr 11, 2010
wentlanv
  • 710 Answers
SOURCE: How do I replace the
Hi ladyccowboy1,
The drive belt is on the side with the handle (you might already know that :>)).
Take the top off, then remove the lifting gears. Remove the side cover. You'll see the cutterhead pulley that has ridges on it to keep the belt from moving in and out. Remove the pulley.
Change your belt and reassemble.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Posted on Apr 24, 2011
Belt on my dewalt dw680 planer slips and starts smoking
If the ball bearing of the armature was getting too hot by working with too hard woods may be the bearing of the armature can melting loss the drive belt have lost a little tension by it the housing and a bearing has to replaced in that case.
Feb 10, 2016 | Dewalt DW680K 3-1/4" Planer
My Dewalt 735 planer won't turn on. I blew the house fuse a few times, it would start after I came out. Now it won't start at all and it's been a couple days
The 735 draws 15 amps, which is the rating of typical lighting circuits in homes. The receptical in the wall is sometimes 15 amps although those circuits usually have 20 amp breakers. Since you said "fuse", it might be a bad fuse or even the wiring between the two. Circuit breakers go bad also. If you can confirm the receptical supplies voltage, it is time to check the 735.
Unknown if the device has a termal switch inside. I doubt it would go bad, but you implied a resting period allowed it to run several more times after the fuse in the basement was replaced. If it reset once, it should do it again. If you can find a diagram, there might be a fuse inside, but someone would have to take it apart to check.
A motor can get so hot that a solder joint inside can let loose and it will never run again. Sometimes the coil (windings of the motor) can short out (melt together) and this will increase how much current goes through it and also generate more heat and melt more windings together. Besides producing a smell, your house fuse would burn out real quick.
I had a chuckle over your 2nd sentence but I dare not say why. If it started after you came out (of the house), why did you not run it for a longer time?
A motor requires more power at the instant of turn on. 15 amps of running current will require 20 amps or more when starting. "slow blow" fuses (vs quick action) and circuit breakers can deal with the short period over current requirements.
Nov 23, 2015 | Dewalt Planer (DW734)
Replace v belt on dw735 planer
REMOVE COVER SO YOU CAN SEE THE BELT, PULL THE BELT AS YOU TURN IT AND IT SHOULD COME OFF
Nov 07, 2014 | Dewalt DW735 13 Inch 2 Speed Planer With 3...
Change the belt on a dewalt 733 planer
Here is a link to a site I am a member of, Lumberjocks.com. The link is for a discussion on how to replaced the belt on your planer!
Good Luck!
http://lumberjocks.com/topics/10176
Oct 03, 2013 | Dewalt Planer (DW734)
Need owners manual for delta shopmaster tp300
Go to http://servicenet.dewalt.com, put your model number in the search box and you'll be able to view/download the parts breakdown and owner's manual.
May 04, 2012 | Delta TP300 Shopmaster 12-Inch Portable...
I need a copy of the owner's manual for Dewalt's Dw733 power planer...please
Check the planer product label on your DW733. DeWalt has two DW733 (type 1 and type 2) models. The manuals for the DW733 is available on the product page: http://www.dewalt.com/tools-discontinued/machinery-portable-thickness-planers-dw733.aspx . See the drop-down list of documentation on the right side of the page. You'll see a pop-up page with more documentation available on the right side of the page. Scroll down to the Instruction Manual.
I hope this helps.
Dec 13, 2011 | Tools & Hardware - Others
How do I replace the drive belt on my dewalt planer
Hi ladyccowboy1,
Handie Andie
Apr 24, 2011 | Delta TP300 Shopmaster 12-Inch Portable...
Wood will not feed through
I had this problem with a Grizzly that is chain-driven. One of the links broke. I replaced the link, and it's been fine ever since.
Apr 21, 2009 | Delta TP300 Shopmaster 12-Inch Portable...
Apr 16, 2009 | Delta TP300 Shopmaster 12-Inch Portable...
How to change planer blades on the Delta PT400LS 12.5" planer?
you will need the directions from the owners manual , do not guess at this it can be a hazard if not done properly i have manual and will try to look it up and figure how to get the info to you
Nov 19, 2008 | Delta TP300 Shopmaster 12-Inch Portable...
Masonry Tools Logo
355 people viewed this question
Top Masonry Tools Experts
Tom Chichester
Are you a Masonry Tool Expert? Answer questions, earn points and help others
