Question about Motorola Mobility H700 Wireless Headset
Motorola H700 I just purchased a Mortorola H700 earpiece for my phone which is a Samsung A900. the directions the head piece came with do not match the settings on my phone therefore I can't seem to get it to work... What can I do?
    Scholar:
  • 35 Answers
First, you will need to put the H700 into pairing mode. Look at the last digit in the part number for your headset (there are 3 versions). If it "A" or "B", do the following... 1. Starting with the headset powered off (flip closed), hold down the Call button for 1 to 5 seconds until the light is steadily lit in purple. 2. With the light steadily lit, flip out the boom. The light should remain steadily lit in purple. If the light is flashing, or if the light starts flashing anytime before completing the steps below, the headset is not in pairing mode, and these steps will need to be repeated. If you part number ends in a "C", do the following... If the headset has never been paired with another device, simply open the headset boom. The indicator light becomes steadily lit in purple. If the headset has previously been paired with other devices, first ensure those devices are turned off. Then open the headset boom and the indicator light flashes in blue. After about 5 seconds, the indicator light becomes steadily lit in purple. And finally, you will have to follow these instructions on you A900... 1. While in standby mode, press the Menu/OK button 2. Select Tools (9) 3. Select Bluetooth® (4) 4. Highlight Yes, using the navigation keys, on the Enable Bluetooth® prompt 5. Press the Menu OK button to enable Bluetooth® 6. Select Bluetooth® (4) 7. Press the left soft key for Add New 8. Highlight Search, using the navigation keys 9. Press the Menu/OK button to begin search for new device 10. Highlight the desired Bluetooth device, using the navigation keys 11. Press the left soft key for Add to List 12. Enter Passkey "0000" press the Menu/OK button, you will get a brief message stating pairing 13. Press the left soft key for Done 14. At the Trusted Devices screen, press the left soft key for Connect 15. You will get a brief message stating connecting 16. After being connected you will return to the Bluetooth® Trusted Devices screen Hope this helps. Good luck
Posted on Jun 30, 2007
This was great thanks soooooo much!!!
Posted on Jul 02, 2008
Earpiece won't link to phone anymore
Hi Josh,
there may be a battery or an internal antenna failure on your headset.
You might try re-pairing the devices if you can.
Jan 08, 2010 | Motorola Mobility H700 Wireless Headset
Reset Samsung A900 to Factory Settings
http://www.samsung.com/us/function/search/resultList.do?searchWord=A900
Jul 28, 2009 | Cell Phones
I can't sync my motorola H715 bluetooth head set with my Iphone 3GS, can you help
I have the H715 but my iPhone only showed the H721 instead of the H715. I selected the H721, entered the passcode and connected. Called my home phone with the earpiece in and it works.
Jul 06, 2009 | Motorola Mobility H700 Wireless Headset
Earpiece holder around ear seperated - soft rubber from plastic.
If you go to your cellular providers retail location, they have a customer service desk for repairs, etc. they will have parts. Hope this helps
Jun 26, 2009 | Motorola Mobility H700 Wireless Headset
H700 Motorola Bluetooth works fine except when I talk
I used this solution and it worked...good luck with yours: http://www.geocities.com/jconkwright/H700fix.html
Apr 02, 2009 | Motorola Mobility H700 Wireless Headset
Hearing from Motorola H700
good morning!! ive been thru this before, try tapping your phone volume while your talking to your party, it shold be seen on your phone screen as earpiece volume than turn it up and when you have the volume where you want it dont forget to tap the set on your phone, another prob i had was some times there is a small protective plastic film on the ear holes on the tooth and one on the mike sometimes, i could hear my party but they couldnt hear me until i discovered that lil peice of plastic. remember your key codes are either 0000 or 1234. good luck m.m.
Jan 26, 2009 | Motorola Mobility H700 Wireless Headset
Motorola earpiece H700 how to setrup earpiece .
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.
2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select H700 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Jan 21, 2009 | Motorola Mobility H700 Wireless Headset
I evidently dropped my Motorola H700 Earpiece and lost Mic Cover
as far as I know yu have to buy a new one but if you do find out that you can just buy the mic. please let me know
Dec 08, 2008 | Motorola Mobility H700 Wireless Headset
H700 bluetooth ear piece - Pairing with new phone
Press and hold the call button while the boom is in the off position for 4 to 5 seconds. The blue indicator light should come on and stay on. The unit is now in pairing mode. Initiate you phones feature of searching for bluetooth devices and pair the two together. The default passcode for the H700 is "0000" four zeros.
Good Luck
Jun 22, 2008 | Motorola Mobility H700 Wireless Headset
Motorola Mobility H700 Wireless Headset Logo
4,570 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
