Question about PylePro PEXA8000 Amplifier - 2 Channel 8000 W PMPO Pyle
I buyed a pyle pexa 8000 watts and in the first time that im using it the left side where you increase volume is not doing good contact what can i do???
The left side on the botton where you increase volume is not working because is not doing good contact ,,,and the botton feels like has some play if you push it a little for the side works and then dont works,,and works and dont work,,,,what can i do????
  • 631 Answers
SOURCE: my pyle amp keeps going into protection when i turn my music up and play it for a min
The most common cause is an unsafe load/speaker impedance. If you have the speakers wired correctly, you may have a short in the wiring. If the wiring is OK, the amp is likely defective
Let me know if you have any other questions.
Posted on Oct 14, 2008
  • 5 Answers
SOURCE: amp goes into protect mode after volume is turned up
Not enough juice, check the power and ground connections, another possibility is to have dc in the input, try to use in line filter available from radio shack to cut the dc, also test the with one speaker at the time, you could have a bad speaker (shorted) too.
Posted on Apr 10, 2009
Grubhead
  • 5056 Answers
SOURCE: Replacement parts for Pyle power amp PT-2000
VU meters are generally illuminated by small bulbs at the back of them. It's unlikely to be a powerfull bulb perhaps 12 volts perhaps around 200ma at the most. Most electrical shops should sell something that should suffice. It could be an LED though!
Posted on May 27, 2009
  • 77 Answers
SOURCE: Pyle PLMRA 400watt marine amp.
I'm assuming you mean channels 2 and 4? If you tried new cables and you know they work then you might wanna check to see if there is a 2,3,or 4 channel switch on the amp or just a switch that reads bridged. If a switch on an amp is set to bridged or 2 channels, whatever type of switch there is, then it would make the amp only run 2 channels. If there is'nt a switch and you have a signal on the cable your using then you may have some shorted transistors. Make sure you definately have a signal first before thinking some transistors are shorted. Take the rca's from the 2 channels that work and put them into the inputs cause you know those channels are working. Let me know what you find, I would like to help you more if you still have problems after this. I also do amplifire repair cheap. I have my own business and most of my customers are from this site, so if you need it repaired then I can help you out on this as well. Just send me a private message. Good luck
Posted on Aug 20, 2009
etirbynnor
  • 655 Answers
SOURCE: How do wire up a Pyle dual 4 ohm sub woofer
Hello shannon_e_ha,
Both voice coils need to be connected to the amp.
If you wire the coils parallel (both +'s and both -'s together and then to the amp), the final load will be 2 ohms. If you wire the coils in series (one + to the other - and the remaining + and - to the amp), the load will be 8 ohms. If your amp is 2 ohm stable, use the parallel wiring. If it is only stable at 4 ohms or greater, use the series wiring.
Hope this helps.
Posted on Oct 31, 2009
Pyle PPHP159WMU: Just received this used unit and the bass speaker tends to cut out the louder the volume is set. Does the battery have to be fully charged for the unit to function properly?
The speaker may have a current sensing device to avoid damage under high volume conditions. Also check the setting of your bass control. Every 3 db increase in setting doubles the power going to the driver and it is easy to over drive the unit at high volumes if your bass control is not on flat.
Feb 03, 2016 | Pyle Audio Players & Recorders
How do I increase volume on an alcatel big easy flip phone?
Hi there
You need to modify the sound settings, select Options > Customize. One of the functions available is :
Volume: Press the Left or Right Navigation key to adjust the volume using the Up or Down Navigation key or volume key on the left side of your phone.
If you have further problems, you can download and save a pdf (Acrobat Reader) version of this phone's manual from here:
Alcatel THE BIG EASY Flip Manual User Guide
Good Luck
Nov 16, 2014 | Cell Phones
My Pyle amp cut off and will not turn on
  • Ensure the device's power switch is on
  • Make sure the device has power connected.
  • Contact Pyle -->
    1-888-318-PYLE / 718-535-1800
Oct 20, 2013 | Pyle Pro PTA1000 1000 Watt DJ Amplifier
2003 Cadillac DTS w/Bose, has rear sub & adding Pyle dual 10 sub
two channel will do with the same power power rating of your speakers ex. your speaker is 500 watts per piece so you need to buy a 500 watts per channel amplifier
May 16, 2010 | Pyle PLHB10 Car Subwoofer
I've purchased a Pyle amplifier... It doesn't work!
your first mistake is buying anything pyle..... check your remote wire that should do the trick
Apr 01, 2010 | Pyle 1800-Watt 2-Channel Bridgeable MOSFET...
I got a pyle 1800w amp and a 1500w kenwood subs but as i increase the volume in the headunit it goes on protect mode why the other problem i got is as increase the volume in the headunit the bass of the...
The protection modes in these units ****. Most new units have them. What I do is turn down settings on deck and turn up amp as much as possible. Then the protection won't turn on because you won't have to turn it up as high.
Sep 30, 2009 | Pyle PLA1200 Car Audio Amplifier
Amp goes into protect mode after volume is turned up
Apr 08, 2009 | Pyle PLA4240 Car Audio Amplifier
HOW TO INSTALL
I would say look for a custom box off ebay or build one behind rear seat. Im not shure if you can fit a small truck box behind there but you may be able to. It would sound pretty good behind rear seat. Hope this helps
Jan 13, 2009 | Pyle 12" 600 Watt Amplified Subwoofer Tube...
PylePro PEXA8000 Amplifier - 2 Channel 8000 W PMPO Pyle Logo
41 people viewed this question
Top Pyle Audio Players & Recorders Experts
 Grubhead
Grubhead
Gerhardus Stroebel
Are you a Pyle Audio Player and Recorder Expert? Answer questions, earn points and help others
