Question about Westinghouse Fans Indoor Ceiling Fans
Need scamatics for a westing house ceiling fan m52-5B 4L
Need instructions on how to install ceiling fan westinghouse m52-5B 4L
5 Suggested Answers
joshuakuan19
  • 48 Answers
SOURCE: Westinghouse ceiling fan
Try "oiling the fan" and also if that doesn't work, change the fan.
Posted on Sep 06, 2008
SOURCE: trying to install a westinghouse ceiling fan into
NO NO NO..... Blue is Neutral...
BLACK is PHASE, BROWN is PHASE, RED is PHASE
WHITE is NEUTRAL, BLUE is NEUTRAL
Green, Green/Yellow is EARTH
Posted on Feb 21, 2010
  • 4 Answers
SOURCE: Chaning a lightbulb on a Turbo Swirl Ceiling Fan
The dome just pulls off.
Posted on Mar 15, 2010
shane_barnha
  • 136 Answers
SOURCE: i installed a dimmer for
First thing I would do is check the connections inside the Unit the ones you made while installing make sure that all connections are tight and well insulated if this was not the problem return the unit for a new one hopefully it is just a faulty unit as this can sometimes happen.
Thumbs up if helpful feedback is appreciated!!!
Good Luck!!!
Posted on Jun 16, 2011
Westinghouse ceiling fan light kit
Make sure the light wire coming out of the TOP of the fan is connected to the hot wire in the ceiling.
Aug 03, 2013 | Dryers
Light switch by westinghouse 77020
Copy following link for general assistance wiring 4-wire ceiling fan switch:
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#3-speed
Jul 16, 2012 | Westinghouse Electric Ceiling Fan 3-way...
Don't have a manual - bought the floor model. Can we adapt the ceiling fan that is designed to be suspended into a flush mount? Have Westinghouse 52SGD or 72458 is also noted on the fan. Thanks for your...
Floor model of a ceiling fan ... think about that for a minute!
I have to say no, you cannot do this. It may be possible but not without a lot of pain and extra expense. I have installed hundreds of fans. You may possibly be able to shorten the pipe that holds the fan but to actually mount it to the ceiling? You will have to have the ceiling hardware to do this. There goes the price benefit even if you can find the proper adapter/ceiling hardware.
Try shortening the pipe that suspends. You may find joy there.
Thanks for your question today. And thanks for the smile ... floor model ceiling fan :-)
Mar 13, 2011 | Westinghouse Fans Indoor Ceiling Fans
I just purchased a westinghouse 3-speed fan switch 77021. How do I open the switch? Do I need a special tool?
I do not understand why you would want to open the switch. Are you asking how to get to the switch inside the fan housing? If so, you access the switch by removing either 2 screws on the bottom or 3 screws on the side. You remove the switch by unscrewing the brass finial holding the switch in place by turning counterclockwise. You need only a phillips screwdriver and no special tools. WARNING: Before you disconnect any of the wires write down how they are connected and make sure you have the right switch for your fan. They are not all the same. Click this link to read in detail all you need to know.
http://www.ceiling-fans-n-more.com/ceiling-fan-pullchain-replacement-and-repair.php
Jan 21, 2011 | Westinghouse Electric Westinghouse...
Need a cover for a westinghouse fan as we want to remove the lights
You can usually find stuff like that in the fan section at Home Depot or Lowes. A local ceiling fan/lighting specialty shop will certainly have a cover. Look in the yellow pages for shops in your area.
Jan 08, 2011 | Westinghouse Electric Ceiling Fan 3-way...
How do I change the frequency on the remote and the ceiling fan? We are on the same frequency as our neighbour.
You'll need to find the dip switches. The dip switch for the remote is inside the battery compartment. You usually have to remove the batteries to see it. The dip switch for the fan is usually on top of the motor. It can also be inside the switch housing or the ceiling canopy. You can set the switches to any combinationan as lonf as they are the same for both.
Jan 02, 2011 | Westinghouse Electric Ceiling Fan 3-way...
I need a diagram to install a Westinghouse 3-way light switch (#77052) on a lighting fixture on the bottom of a ceiling fan. I did not do the removal of the light fixture so I don't know how it was wired...
If by a 3-way switch, you mean a switch with 4 steps of brilliance: off, low, medium, and high when used with a 3-way bulb. The black wire of the switch is connected to incoming power wiring hot wire. Most often also black. The red switch wire connects to the center contact of the lamp socket. The blue wire connects to the small pin connection that is physically between the center connection and the screw shell of the lamp socket. The screw shell is connected to the incoming white wire of the house wiring.
Dec 30, 2010 | Westinghouse Electric Ceiling Fan 3-way...
Westinghouse Fans Indoor Ceiling Fans Logo
370 people viewed this question
Top Westinghouse Dryers Experts
stevensmn
Level 1 Expert
Are you a Westinghouse Dryer Expert? Answer questions, earn points and help others
