Question about Pioneer Televison & Video
Pioneer PDP- R05G media receiver error code "This signal is not supported" on HDMI from Nintendo Wii U.
I purchased a Nintendo Wii U box for Christmas. (The U is the latest high definition 1080p version of the Wii). I connected it into the Pioneer PDPR05G media receiver via the HDMI input which is input 3. I activated the input via the settings for input 3 on the remote. I checked the input is operational with a DVD player via HDMI and it is. Using the same cable which we used to test the HDMI input via the DVD player (so we know the cable is functional - we know the Wii U is functional as we were using it on another TV in the house), we connected the Wii U box. The television produces a message on input 3 which says "Plasma Display ! This signal is not supported". I cant understand why the box supports Bluray 1080p HDMI from a DVD yet when you provide a 1080p from Wii U it says its not supported. How do you suggest we fix this?
SOURCE: HD Cable Box; HD Plasma...........no picture or sound
Same problem, 42" lg plasma
Posted on Apr 30, 2008
Agent Aaron
  • 265 Answers
SOURCE: Panasonic 1080p Plasma TH-42PZ80U Home Theater Setup Question
Hey Gamer1827,
While I personally can't provide you with any model-specific home theater system recommendations, there are a couple of common ways that you can generally configure your home theater.
Connecting several devices directly to the HTIB system may typically allow you to minimize the number of remote controls necessary, as long as the HTIB system supports the use of a universal remote. Should you not necessarily care if you have to change back-and-forth between two remotes however, you may have a wider variety of possible configurations available.
In order to use only HDMI cable connections to set up your home theater, you most likely would need an HTIB system with three HDMI ports: one for your TV, one for your PS3 and one for your cable box. Each device would require a separate HDMI cable running between it and the receiver. This option (in theory) would allow you to use one universal remote to control each device, assuming that they are all compatible with the same remote.
Another common configuration you might wish to try requires you to connect your cable box and PS3 directly to your TV. By doing so however, you might limit yourself to using an optical digital audio cable to make the connection between your TV and many HTIB systems. In this configuration, the cable box and PS3 would again have their own separate HDMI cables, while the optical digital audio cable would need to be run from the Digital Audio-Out port on the back of your TV to the Digital Audio-In port on the receiver. This option essentially treats the HTIB system as an expansion device, instead of the center of your home theater configuration.
Should you need any additional information or suggestions, remember that you may always speak with a sales representative at your local Best Buy™ store for further assistance.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Posted on Jun 12, 2008
SOURCE: Need help hooking up TV, BluRay, Home Theatre & cable box
I found that since the Panasonic TH50PZ80U TV has only 2 HDMI ports on the back of the TV, the best solution for me was to use component (red, blue, green) cables to connect the Home Theatre to the TV. I suppose I/you could connect the home theatre to the HDMI port on the front panel, but I don't want cables hanging out the front of the TV (personal preference). Unfortunately, I am no longer able to use the VIERA Link functionality available by connecting all Panasonic components to each other using HDMI cables, but I feel it's a small price to pay for the incredible picture quality acheived by using the HDMI cable to connect the HD Cable Box to the TV. I may yet be able to control everything using the HD Cable Box remote, but I haven't gotten that far yet but I've got Comcast coming on Saturday and hopefully they can let me know if this is possible: let me know if you have a solution.
So here are the components and the cable types used to connect:
  1. HD Cable Box to TV: HDMI cable & Optical Audio cable
  2. Home Theatre to TV: Red, Blue & Green component cables
  3. BluRay Player to TV: HDMI cable
I hope this helps someone else.
Posted on Nov 20, 2008
JUGGALOTUS
  • 151 Answers
SOURCE: We're getting audio but no video from our Pioneer
where is the video feed coming from? did you try a diffrent cable? can you change the channel at all?
Posted on Oct 18, 2009
SOURCE: I have a Pioneer PDP-R05G
This is a classic "Hic-upping" switchmode power supply problem. The protection circuitry inside the SMPSU, has sensed a severe potential problem, and is attempting the shutting of the set, down to avoid a fire, explosion, or both.
This set had developed a problem, that is so severe that the set must be shut down, (This set should be removed from the Power),
What is happening is the internal "Fault" that is causing the Protection Circuitry , to detect the problem and attempt to shut down the set, keeps restarting the set, because as soon as it shuts down, the "Faulty" component(s) cool down?, and the "Fault" ostensibly "Clears" so the PSU starts up again, only for the component(s) to heat up, whatever, again and fail, so it shuts down, and if left unattended, this would continue on until the part eventually failed. As related this is called a "Hic-upping Power Supply". Any fault that involves the power supply is usually quite serious, and needs a professional, usually, unless one is familiar with servicing current day, televisions.
And in my professional recommendation, you should get a "Quote" for repair, from, an, Approved Service Center. Now, this point is very important for a good result, Always contact, their "Local" or a, "Head Office" Philips in your case. Ask them, for a referral to an authorised servicing center, where you ask for a "Quote". Now, when you get the information you want, then you can decide as to repair of replacement.
The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have parts on hand, also sometimes, there has been a service bulletin in issued and the repair may be subsided or even free. There are many, many, many reasons that display this symptom, one must work through the troubleshooting steps to isolate and identify, the Cause and repair that and any damage done.
http://www.pioneer.owner-manuals.com/PDP4360HD-service-manual-PIONEER.html
service manual link above,
as an aside here, sometimes things in storage can quickly degrade especially big low value capacitors, these increase in internal resistance, and all sorts of problems ensue, this is why, say, military things are cycled at least weekly when in "Moth balls" to prevent exactly this.
Posted on Mar 12, 2011
Do I need a digital set top box if I have a pioneer PDP-R05G media reciever
Turn the receiver on and select TV. If you can't tune X.X channels (no decimal), you need the converter.
Apr 02, 2017 | Pioneer Televison & Video
Pioneer PDP-R05G
A clear symptom of panel failure is described here. If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2350 posts now. All are related to electronic equipment repair help. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. Replacing panel will cost around 80% of the total cost of a new TV http://electronicshelponline.blogspot.com/
Apr 23, 2013 | Pioneer PDP-4360HD 43 in. Plasma...
My problem is getting a "This signal is not supported message" on an HDMI input into a Pioneer PDPR05G media receiver.
No need to understand - just read the message, It clearly states that the unit will not accept that particular signal because its electronics are not configured to deal with it. And that is it - end of story.
Basically, you cannot force a square peg into a round hole.
Mar 13, 2017 | Pioneer Televison & Video
I am looking to buy a Pioneer media receiver model PDP-R05G - can anyone help me? This suits plasma panel PDP-435PG
I am also looking for a PDP R05G receiver.
If you're upgrading your TV to digital, let's know if you'd like to part with the redundant analogue R05G
Ian +61 7 5444-5521
Apr 14, 2010 | Audio Players & Recorders
Pioneer PDP-6020 FD, Menu items grayed, no HMG after firmware upd
I have the same issue - Pioneer told me the local repair shop could reset the firmware, I paid the $90 service call and they could not fix anything. For a 18 month old $5000 TV they now want me to replace the digital board for around $500.
Sep 10, 2009 | Pioneer PDP-5020FD 50 in. Plasma HDTV
How to play PDP-434PG with PDP-R05G
I do not know how to solve your issue sorry, I need the media centre you have for a PDP435. Would you like to sell the media receiver PDP-05G ?
0212624139
Aug 27, 2009 | Pioneer PDP-4360HD 43 in. Plasma...
Upgrading media receiver on Pioneer PlasmaPDP-5030HD
You can use a PDPR06U if you can find one for sale its 2 generations later than your's. Look on Ebay. I might have one too but I got to look.
Jan 04, 2009 | Pioneer PureVision PDP-5040HD 50 in....
Pioneer PDP-436PG
Bom dia!
If you mean DVB-T signal then you will need an extra box to receive this via a normal antenna if your media receiver does not support digital free-to-air (I don't know your model because I am not familiar with non-european types). At the moment I don't think anybody transmits HD on terrestrial digital. Satellite TV can provide HD transmission.
Dec 03, 2007 | Pioneer PDP-4360HD 43 in. Plasma...
Televison & Video Logo
193 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
