Question about Samsung WA5451ANW 4.7 Cu. Ft. White Top-Load ENERGY STAR Washer
I have a Samsung top load washer #WA5451ANW. Will only fill with water. Had to turn the power off so machine would stop filling with water.
Setting was for cold water and machine was also filling up with hot water.
  • Samsung Master
  • 17,130 Answers
Possible that the cut off to the Inlet valve has failed which means that the controller unit is a suspect. Also if the inlet valve is staying ON even when the power is cut off , then it is a case of inlet valve failure.
Posted on Dec 31, 2012
hiltonjug
  • 612 Answers
SOURCE: to much water samsung sw51asp
Your problem is in your pressure switch. It's the one where you are able to set your water level or load size. It's easy to replace and cost little.
Please rate solution
Posted on Sep 10, 2009
Testimonial: "Cheers "
GodBlessU
  • 3513 Answers
SOURCE: Samsung J845 front loader washing machine. Error
Hi
An OE error presents if the washing machine has not successfully drained the water in ten minutes.
there are a few simple steps to take before calling for service.
Step 1: Check the drain pump filter.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
Step 3: Confirm that the washer is leveled properly.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a level on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
you can perform a diagonal test when leveling the washing machine to ensure that the unit does not tilt from corner to corner.
Thanks for contacting fixya.com
Posted on Sep 30, 2009
  • 410 Answers
SOURCE: washer fills up with way too much water.
I am not a repair professional. I am just a 78 year old man who has been making his own repairs for about 50 years. Therefore the washer ID doesn't mean
anything to me. It's been about 55 years since I had experience with front load washers. However I can refer you to www.applianceaid.com where they have very good and complete trouble shooting and repair information on front loaders. I think you'll find what you need there. Don't worry about the timer, they hardly ever go bad. Good luck with it. If I have helped you, please rate my advice on fixya.
Posted on Nov 25, 2009
SOURCE: I have a Samsung WA13G7Q1 washing machice The
the quection is not complete, when the cold water inlet and hot water inlet both work then what is the problem....
Posted on Apr 27, 2010
  • 8 Answers
SOURCE: Just moved my Samsung WF448AAP, hooked it up and
you might have anti flood hoses that are braided going to the machine . remove them and make sure your water supply is coming through the water hoses.
Posted on May 06, 2010
New Samsung Top Loader13kg WA13J571 Wobble Techn,used for the 1st time-water level 1(LOW)still filled the WHOLE machine with water.Bigger load on level5(FULL)never stopped filling with water.
use the features fuzzy logic, u only need to power on and start on the machine when u hve fill in the tub with cloths and soap. water will fill in according to the load filled.
Sep 08, 2017 | Samsung Washing Machines
I have may tag wash model nu mav5920eww i just hooked it up tried reg wash it filled with water then would not continue to wash went to pause mode
Maytag & Whirlpool washer diagnostic - Fills with water then ...
? 3:03
https://www.youtube.com/watch?v=71zySSScDPE
Jul 11, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your trusty Maytag Washer that has some of the ...washer diagnostic - Fills with water then cycle stops - LAT8014AAE .... Not agitating Maytag 2 belts top load washers - Duration: 26:55. by theapplianceman 23,820 views. 26:55.Washing Machine Keeps Filling With Water and Will Not Agitate ...
Maytag top loading washing machine stopped working & filled with
Dec 02, 2015 | Maytag MAV5920E Top Load Washer
There is no power samsung wa5451anw/xaa-0002
hum not good
sounds like something has fused and blown the mains
you need to look too a control board error for this ...
its a job for a tech,... for sure..
Mar 05, 2015 | Samsung WA5451ANW 4.7 Cu. Ft. White...
How do i stop machine from filling up with water till it overflows
Sounds like you need to replace the water setting switch.
Oct 13, 2014 | GE WJSR2070B Top Load Washer
Samsung WA5451ANW top will not open. Code
Have you tried to tilt the washer? When I tilted my washer 15 - 30 degrees and then I could open the lid. My problem was that I had a clogged filter I have not seen before.
Aug 30, 2017 | Samsung WA5451ANW 4.7 cu. ft. Top-Load...
Hot water stops filling too soon.
Fill setting has to be adjusted and the belt is slipping on the spin cycle and not generating enough centrifugal force to get the water out.
Aug 25, 2017 | Kenmore 22422 Top Load Washer
Water will not stop filling machine
Your fill switch is bad and needs to be replaced. To test, set the water level to it's lowest setting. Let the machine fill. If the water fills the tub 3/4 of the way, your switch is indeed bad.
Sep 11, 2011 | Frigidaire GLWS1349A Top Load Washer
Washer wont agitate or stop filling on any setting
Hello Friend, Just replace the water pressure/level switch. Replacement will make it fill correctly and agitate. Happy to help.
Nov 18, 2009 | Kenmore 24712 Top Load Washer
Roper washer
I have the same damn issue with my Samsung washing machine(Top Loader) Not quite sure why it does it.Help please really annoying.
Jun 05, 2008 | Whirlpool LSB6200KQ Top Load Washer
Samsung WA5451ANW 4.7 Cu. Ft. White Top-Load ENERGY STAR Washer Logo
506 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
