Question about Nintendo Wii Console
Wii won't read discs, spits them out, no blue light
I previously had a disc stuck in the wii and finally removed it with tweezers...now it won't read any discs and the blue light that came on when I was trying to eject it does not come on now. Help?
  • 34 Answers
If Wii gives Disc Read Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Posted on Feb 25, 2009
Blue disk light on until console unplugged now games won't work
One has nothing to do with the other. It's a coincidence.
The blue light means that there is an update available from Nintendo to be installed. It could also mean that you received a message or news from Nintendo. If you don't like the blue light, you can change it in the wiiconnect24 settings.
If your Wii isn't reading games, the first thing to do is to check the disc. If it is not scratched or no discs at all are working, your drive needs to be replaced. You can find a new Wii DVD drive replacement at the following page:
Wii Replacement DVD Drive Repair Part
Jun 22, 2013 | Nintendo Wii Console
Wii ejects discs
Well I think thast the disc drive is broken or there might be something stuck inside
of the wii console like coins keep video games consoles out of reach from little kids they will reck video games consoles then.
Apr 18, 2012 | Nintendo Wii Console
We got a game stuck in the wii consele....We tried ejecting the game as well as turning the game off...nothing is working.
You have to try out all these options first:
Turn the Wii off and on again after about 20 seconds. Press the eject button again.
Unplug the Wii's AC power supply if Step 1 doesn't work. Wait 1 to 2 minutes, and trying to eject the disc again after turning the Wii back on.
Hold down the eject button for 5 to 10 seconds.
Try ejecting the disc with the Wii at different angles. If you hold the Wii upside down, it may help the disc fall out.
Call Nintendo and send the Wii back if non of these steps work. In most cases, a disc stuck in the Wii should be covered by warranty.
Nintendo says to see if power light was coming on, AC adapter reset. unplug from both ends for 90 seconds.Hold eject button for five or 10 seconds.
If none of this works, you might wanna try this, but it is not a preferred method, if you ask me, even though it can be done.
To remove a disc you'll need three sets of tweezers. And possibly a bobby-pin.
First you need to turn the Wii upside down (and preferably unplugged from a power source)
Second, using two sets of tweezers, press the small metal "guards" down. These are located just inside the mouth of the Wii. They're there to keep the disc from free falling, and inhibit their removal. They aren't locked and shouldn't be difficult to press down.
Third, you'll need to reach "up" through the middle of the mouth with the third set of tweezers to grab hold of the disc. I'd highly recommend using flat tweezers, not sharp ones as the disc may become scratched.
NOTE: The disc itself rests on the internal carriage (through the center hole of the disc) and if upside down, should fall into your tweezer's grasp easily. If it doesn't then you need a bobby pin to dislodge. Gently press the bobby pin on top of the disc and then grip the disc with the tweezers.
Finally, gently pull and the disc and push on the bobby pin and the disc will slide out easily .
This can be done with one person, but helps if you have an extra hand.
Good luck.
Sep 23, 2011 | Nintendo Wii Console
Wii spits out disc when inserted and makes funny grinding sounds
You may check out Wii Fix Guideto fix the problem yourself. This DIY guide will show step by steppictures to fix the problems yourself without any .technical knowledge.
Jan 02, 2009 | Nintendo Wii Console
Game will not read disc. Starts and then says error
Dec 28, 2008 | Nintendo Wii Console
Takes in disc and then spits it out
Your disc is stuck in Wii Console, It needs to eject manually. You might check out Wii Fix Guide, that gives step by step information on Dis-Assembling with screenshots, even a novice can fix the disc eject problem with the help of this DIY Guide. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Dec 24, 2008 | Nintendo Wii Console
Wii can"t read disc
If Wii gives can't read disc, so first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide,that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Dec 14, 2008 | Nintendo Wii Console
Wii disc stuck
Dec 04, 2008 | Nintendo Wii Console
Two disc stuck in Wii
Thought we had 2 discs stuck in Wii, unable to take apart (no triwing screwdriver) my wife took a pair of tweezers and rotated the disc until it slipped out enough for her to grab it. After turning power back on, 2 more discs popped out on their own. Mission accomplished.
May 10, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
148 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
