I have 5.1 surround sound and when watching a movie, random crackling noises come out of the front left channel. This does not happen on a consistent basis - it is totally random. I thought it might have been the speaker wire, so I replaced the wire and that didn't work. Then I switched both the left and the right front speaker and the right front speaker that was performing fine started to make the noise when hooked into the left front channel through the receiver. So, I think I have it narrowed down to the receiver. I have a Marantz SR7200 AV Receiver if that helps. Do you have any ideas or solutions?
  • nowicrob Jan 18, 2009
    Since it is only the front left channel doing it, is there a way to clean the input jacks into the receiver. Maybe it just needs to be cleaned out??
  • 19,396 Answers
Crackling noises on an audio channel means that there is a short. I do not know what you mean by cleaning jack (it should be RCA or similar, not jack), but since the problem is clearly the receiver, the unit must be taken apart and the contact originating the short fixed.
The contact is usually on the small input board that is hosting the audio input sockets.
The repair is not expensive, but by calling your TV company you can get a replacement receiver.
Posted on Jan 20, 2009
    President:
  • 1,990 Answers
Welcome to Fixya! This is a Reciever Problem. You have a Faulty Amplifier that is not Reading the 5.1 Correctly and Switching Indetween. This is Common on Marantz units. I would locate an Authorized Service Center and have them Replace the Amplifier in the Reciever.
Posted on Jan 18, 2009
    Genius:
  • 1,011 Answers
Sir,
I guess the broken driver is one of kef's top end uni-q dual concentric tweeter/mid range units so I guess it would have to be replaced as an item, rather than just replacing a broken tweeter or midrange.
If it is then the prob lies with the speaker, if the crackling comes from the right channel then its the amp at fault.
If the fault lies with the speaker an easy way to check is to remove the grille, then with two thumbs either side of the bass cone (near the centre), press GENTLY inwards then release (repeat as neccessary) and listen/feel for any roughness or grating. If it does this indicates the voice coil has "burnt out" as they say. The cone of the speaker should move in and out under finger pressure with no noise/grating if it is OK.
The tweeter cost is 15 $ - 20$
thanks
goodluck
    Sergeant:
    Scholar:
  • 199 Answers
May be some other magnetic field or device close to it is causing interference.check and move it away to get rid of this diturbance.
  • 153 Answers
Check the output jack in the 5.1 device
see if anything wrong in it
speakers wil be allright only the 5.1 seperator hav the fault
    Brigadier General:
  • 5,158 Answers
Insure you have the speaker wires connect with the proper polarity (plus minus). and that nothing is near the reciever that may be causing interference.... computers are the worst offenders for causing interference with devices
Robert
How too hook surround system to regular tv. Example : a football game. Thanks
Well, since the "regularTV" has no make or model number I will have to guess what outputs it has to suit your surround sound system which also has no make or model number! Using outputs that show left and right speaker channels wire each to the left and right speaker channels of the surround sound amplifier. How many, I don't know!
Jan 23, 2013 | Audio Players & Recorders
Every once in a while the sound goes out and comes back if i watch a movie or regular tv how do i fixit
Most recievers had setting for TV/Stereo/CD/ DVD
Also the various sound settings, such as Concert / Hall / Dolby etc...
Assuming your wires are all hooked up correctly and reverse polarity (popping noise heard) is not the problem. I doubt that you need to resolder any connections inside the reciever or speakers. (That may be a problem, but not likely in this situation)
What may be happening here is that some things are simply not recorded in surround... Then it will sound just like you've described. sound going in and out. Sometimes the engineer skipped a track, you know, left for lunch and when he came back, didnt start back where he finished before he left...
However, lets say for example your watching a TV movie of the week, and those speakers may appear to be working while the movie is on but not during a commercial, since most commercials are not recorded in Full Surround Sound... this is normal.
However, if happening during the Movie, from scene to scene, also possibly a normal thing if the sound engineer had nothing to add for background noise, ie; rustling leaves, creaking floorboard etc...
Sometimes you may hear background sound out of a left speaker and not the right, (or vis'a-vers'a) this is of course due to placement of object or subject of background noise... if Any
9 times out of 10, it may not be your system at all. If your watching a DVD and this is happening, you could make a note of when and where and try another copy to see if this system can be replicated at this same location. You may be able to use a CD and find out also.
Hopefully you'll find some help in this.
Respectfully
Jun 09, 2011 | RCA RTD317W Theater System
When watching a DVD in surround sound movie mode
FIRST- double check that the center channel is hooked up in the center channel connection. we have all made this mistake. second if you are watching a movie through a dvd or bluray player be sure that both your audio L/R rca's or hdmi cable's are plugged in. I do not know if your are on cable or satellite? Double check the connections. Be sure that the that if your can select your sound preference turn it to 5.1 surround or matrix. hope this helps
Jan 11, 2010 | LG LH-T754 Theater System
Can't get Surround Sound with Movie
hiya
do you get full 5.1 when watching a movie from the dvd player...........??
as when u watch tv the reciever must be set to pro logic to enable 5.1 upmix as its only a stereo feed....
Dec 15, 2008 | Technics SA-DX1050 Receiver
PS3 hdmi Audio problem Crackling Sounds
I CHANGED THE AUDIO SETTING UNDER HDMI FROM AUTO TO MANUAL AND I REMOVED DOLBY 5.1 FROM SELECTIONS.LEFT THE OTHER 2 SELECTIONS THAT WERE ALREADY SELECTED FROM AUTO SET FOR HDMI I HAVE NOT HAD AUDIO PROBLEMS SINCE.
Nov 05, 2008 | Sony Playstation 3 (PS3) Console
Sudden crackles in the right surround speaker!
Your speaker is busted. You will need to get another one. It really can not be repaired and if it can, it will cost more than a new speaker.
Sep 12, 2008 | Logitech X-540 Computer Speakers
Yamaha rx-v2200 sound problem
Hi Zanthena - my Yamaha rx v 2200 is doing exactly the same thing - did you manage to track the problem down? I have had my unit in for repair and the fault occurred again 6 hours after I re-installed it.
Any help would really be appreciated!
Jason.
Sep 07, 2008 | Yamaha RX-V2200 Receiver
Center speaker still not working :(
all your speaker channels are working so your problem lies with a setup fault. when you watch tv you are only feeding a stereo signal into the amp. you need to select the internal surround sound generator. you need to select either the movie or surround function. the unit will convert the stereo signal to 5.1 channel surround.
May 26, 2008 | Yamaha RX-V595A Receiver
 Grubhead
Grubhead
