Question about PfaFF Sewing Machines
Tiptronic 2020 stitches not working.
Cant get it to zigzag or do any other stitches. Nothing happens when the numbered buttons are pressed. I just got it out of the shop and was told it worked greatl. This wasn't the reason I had it serviced. The stitches worked fine before.
  • PfaFF Master
  • 7,365 Answers
I would call the repair shop and tell them what the machine is
doing and tell them the machine was making the stitches before
and now it's not, and ask them why is the machine messing up?
it's possible that the machine motherboard is going out or the panel
where the buttons are has gone out.
Posted on Dec 31, 2012
Trifect7
  • 57 Answers
SOURCE: How do I change the stiches?
You can do all of these stitches by using different combinations of your stitch selector, stitch width and stitch feed knobs, for instance, on the panel I can see on your machine:
http://www.jo-ann.com/joann/product/images/52659.jsp?CATID=cat3122&PRODID=prd11333
Stitches 1, 2 & 3 are straight stitches, centered, left and right. Really basic stuff, not different stitches at all. 4,5,6,7 & 8 are zig-zag stitches of different widths. 9 is the widest zig-zag (no. 8) on a finer stitch length, etc...
I think you should try and get an instruction manual for your machine. After a lengthy search of my usual manual sources, I've determined that that this may not be so easy. I think you should contact White on their 800 number and let them try and help you... 1-800-331-3164.
If you found this helpful, please vote generously as I receive nothing other than acknowledgement for my time.
Posted on Mar 08, 2008
SOURCE: Will not zigzag
Have the hook timing checked on your machine.
Posted on Oct 10, 2008
RickE1
  • 202 Answers
SOURCE: how do i use the zigzag stitch on my bernina 830
Hi, open the top cover and if you watch what goes on inside from the top when you move the top change lever you will see part of it goes through a fork or U-shape part. This part is probably stuck and needs some oil. After oiling and working it back and forth a bunch eventually it will start snapping into the notches its supposed to. I beleive then you will have your zigzag back.
Either that or you have the stitch width set on zero.
Posted on Feb 07, 2009
  • 980 Answers
SOURCE: Kenmore 2142 sewing machine won't zigzag.
Before you put the cam in did you make sure the machine was set on straight stitch and then select zig zag?
Posted on Nov 06, 2009
  • 1891 Answers
SOURCE: Pfaff Tiptronic model 2030 LCD display panel went
very common prob . with pfath . panel failure . display failure . no easy sol . but to repl pc control panel .. / how ever after repair ( and they never tell us .. use a surge power controler on the line . to your machine .. .. **** .. hope this ansewered your Q " mm feed back pls .. mm
Posted on Jan 16, 2010
Testimonial: "Thanks, I use surge controllers elsewhere but hadn't thought to add one to the sewing machine."
Singer quantum will not turn on
Have you looked at your manual? I think that you would have to pick a stitch pattern, ie. straight, zigzag. Then width and length for the machine stitch. Now, press on the foot pedal.
Dec 18, 2017 | Singer Sewing Machines
Does the Pfaff tiptronic 2020 have a needle lock?
Please explain what you are trying to achieve. The term "needle lock" is not common in sewing. There are functions that cause the needle to always stop at the top or at the bottom of the stitch--this is called needle up or needle down. There is also a lockstitch which is a chain stitch.
Feb 23, 2017 | PfaFF Sewing Machines
Singer 6510 3 dial machine - no "S" on stitch length dial selector
Lower numbers moves the fabric further for each time the needle penetrates the fabric. . If you raise the number you will get more stitches per inch which means your fabric is moving more slowly. Try moving the number to different locations for examples. If you are attempting to make something so it will stretch you are probably wanting to use a zigzag stitch. A wide zigzag stitch will allow a longer stretch than a less wide zigzag stitch.
Dec 23, 2014 | Singer 6510 Sewing Machine
Tiptronic 2020 wont do any of the stitches. Nothing happens when I press a stitch or press the arrow. I am using a extention cord. Could that cause the stitches not to work.
as long as the extension cord is plugged into the outlet correctly
there should be no problem, it sounds like some part of the
electronics is messing up
Dec 31, 2012 | PfaFF Tiptronic 2040
Why straight stitch will not work but zigzag and herringbone stitches work on my machine.
it sounds like the machine needs to be checked at a sewing
machine shop to see what's wrong with the cam's or gear
that makes the stitches
Aug 01, 2012 | Sewing Machines
2020 rotary hook continuous one direction pfaff tiptronic 2020
You are absolutely correct - your machine doesn't come apart much because it is an electronic machine. There really are very few moving parts in modern sewing machines - and the electronics are better left to a technician who's been specifically trained.
It sounds as if your machine is no longer in time (needle rubbing the plate as it goes around if I'm understanding correctly). While not really a "major" repair, unfortunately with computerized/electronic machines, retiming your machine is something better left to an authorized Pfaff technician.
If the needle struck metal as you were stitching/basting, there may also be a rough spot/burr on the hook that your technician will be able to smooth off as well.
Hope this helps get you back up and running soon.
Happy stitching,
Kim & Linnette
www.sewingexpressions.com
Nov 23, 2008 | PfaFF Tiptronic 2030
Mar 07, 2008 | White Sewing 1418 Mechanical Sewing...
Changing stitches on a White 1418 sewing machine...
I have a White 1418. Here's how you do it:
1. Attach the buttonhole presser foot (should have come with your machine) and place the fabric underneath.
2. Set the stitch length knob to 0, the zigzag width knob to 5, and set the needle position to center. Sew 3-5 stitches.
3.Change the stitch length to 0.5, the zigzag width to 2, and the needle position to left. Sew to the entire length of your buttonhole.
4.Set stitch length knob to 0, zigzag width knob to 5, and needle position to center and sew about 3-5 stitches
5. Set the stitch length knob to 0.5, zigzag width to 2, and set needle position to the right. Pressing the R button (reverse button), sew up to the top stitches.
6. Remove the fabric and open the button hole with a button hole cutter.
Sounds complicated, but it's really easy. I love this machine, you just have to know how to use it!
Sep 18, 2007 | White Sewing 1418 Mechanical Sewing...
Sewing Machines Logo
56 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
