Kelvinator aqua error 1
The machine keeps showing error 1 - it wont work - please advise if you know what the problem is. thank you
  • Washing Mach... Master
  • 17,129 Answers
Possible that the main program controller unit has failed or is having faults within the system.
Posted on Dec 31, 2012
4 Suggested Answers
  • 26 Answers
SOURCE: Washing Machine does not work and shows error code E40
E40 is a door related problem. Possible causes are faulty door interlock or door circuit triac on the main PCB.
Most likely cause is the door interlock.
Posted on Nov 19, 2008
heatman101
  • 43501 Answers
SOURCE: My LG front loading washing machine wont drain or
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on May 22, 2010
jan mczeal
  • 632 Answers
SOURCE: my washing machine kelvinator aqua
Unplug the machine then drain the water manually by gravity. Place the drain hose into a bucket or shallow basin on the floor to drain the water. Water should gush down the drain hose if the drain system including the drain hose is clear. This signifies that the drain pump is not working. Check to make sure that the drain hose is not clogged or kinked and the drain pump filter, if there's any, is clear if water does not flow down the drain hose. Also check the drain pump for any sign of degradation or damage.
Posted on Sep 13, 2010
I have Kelvinator AQUA EXTREME KL600FL lost manual and now dont know how to do the various settings for washing programmes
I am including a link to the kelvinator support center. It seems that KL600FL may not be the complete model number because the site does not answer anything for that number. . Open the lid or door and look around the frame for a model number label.
Support centre
Oct 03, 2014 | Washing Machines
Minolta di450 how i can solve this code c-0540
To reset Error codes C0500 and C0501, perform the following steps.
1-Turn the machine "OFF".
2-Press the "STOP" button on the basic panel.
3-Keep the button pressed and turn the machine "ON".
4-Do not release the button, until the machine warm up.
5-After few seconds Error code will remove and machine will reset.Basic menu will show no error on LCD screen.This means error code has been removed and photocopier machine is ready to use.
May 18, 2014 | Minolta Office Equipment & Supplies
E4 error showing on a kelvinator kd14ss
good day
my dishwasher give e3 and e4. what is the problem and how can we solve the problem.
Nov 04, 2012 | Kelvinator Dishwashers
My galaxy aqua 2000 shower has started to cut out the last 2 after 10 mins. I'll turn it off n leave it for 10 mins ten turn it back on then it will happen again. I've taken the head off n
my Galaxy Aqua 2000 Electric Shower keeps running (cold water) even after swithing power OFF it used to completely shut down b4..what should I do 2 rectify the problem ...Please advise.... Thanks a bunch
Oct 18, 2012 | Galaxy Aqua 2000
Washing machine doesnt work kelvinator smartdrive 085 0.5kg
you have to check 1- water pressure switch (wps) , 2- the hose which fixed between wps and drum may disconnected or broken.
Jun 12, 2017 | Kelvinator Washing Machines
I've got a Kelvinator dishwasher KD12MM bought second hand, the machine goes on but does not pump water. Please help
Possible that the pump has clogged or is jammed with dirt. you will need to remove the pump and clean the pump assembly for a good spray pressure. If this wont work then the pump is faulty and needs to be replaced.Check this link for tips:
http://www.espares.co.uk/advice/dishwashers/a/3
Mar 12, 2012 | Kelvinator Dishwashers
I have installed a new LCD screen on my acquasmart WL80T65CW1 and teh csreen now shows fault code 9. Please advise how to get rid of it and resize machine. Thanks.
Hi
If ever you replace the display PCB or the main controller PCB then you must set the size of the machine in to the memory of the controller. This should of been in the instruction sheet that came with the display.
This Is Fault Code 9 ,which indicates Size setting or
size error . When you changed the display did you size your machine to the new display module? Did you get the re-size set of instructions with the new display board? Ring up where you brought the display from and i"m sure they can help.
If this appears in your screen it will be necessary to set the size of the Aqua smart....
1. Press and hold the SPIN button, then press the POWER button until three beeps are heard.
2. Press the FABRIC SOFTENER button once to size the machine.
3. Press the POWER button.
If nothing works you need to reset your machine, please check the bellow link to get the manual and check page 18 and 23 for the reset instructions.
http://www.fisherpaykel.com//admin/pdfs/pdf_usecares/3731_LCDLED_Aquasmart_FINAL.pdf
Please get back to us if you have further query else please accept the suggestion.
Mar 20, 2011 | Washing Machines
Error code E007
Canon photocopier IR2016J show error code E007. Please advised me on how to resolve
May 05, 2009 | Office Equipment & Supplies
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
