Question about Dell Dimension 9200 PC Desktop
Dell dimension 9200 temperature sensor
Temperature sensor
5 Suggested Answers
  • 998 Answers
SOURCE: Dell dimension 9200 year 2005
So you don't even get the BIOS screen on star up? Here's a lik to your model's manual: http://support.dell.com/support/topics/global.aspx/support/my_systems_info/manuals?c=us&cs=19&l=en&s=dhs&~ck=anavml
I would try re-seating the memory modules.
Posted on Jan 05, 2011
Ironambre
  • 65 Answers
SOURCE: dell dimension 9200 pc put herself in power save
You just need to go into power options and disable the sleep and hibernate function
Posted on Jun 09, 2011
bronk50
  • 27725 Answers
SOURCE: Dell Dimension 9200 amber ligth on the power button
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle of restarting or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive power and data cables IDE SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your dvd\cd floppy drives have secure connections and are not faulty or just replace them they could be faulty
computers need power and data to travel through every working device to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty electrical or fan lead can cause you problems
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in
check you CPU central processing unit make sure its securely seated and has thermal paste it might be getting to hot the thermal paste will help disperse the heat
Thermal compound is a sticky paste that is placed directly onto the CPU.
Allowing for a more direct heat transfer between the CPU and HEAT SINK and preventing air gaps from forming between the CPU and heat sink.
hope this helps
Posted on Aug 01, 2012
SOURCE: Dell Dimension 9200 does not boot.
remove ram and listen beep codes from the system ......still no beeps from the system .....the problem with motherboard only
Posted on Oct 15, 2012
Dell Dimensions 9200, Desktop. Been in storage. Trying to open it, message says, 'in Save mode' tried the tips advertised to no avail
If there is space in another computer you have. just take out the hard drive from the Dell and put it in the other computer. It will have a new drive letter and you'll be able to retrieve more than just pictures from it.
May 28, 2016 | Dell Dimension 9200 PC Desktop
The Dell Dimension 9200 has up to now worked fine but now seems to freeze qand the fan starts to blow at full speed. The only solution is to switch off the system by pushing on the on/off button for a...
Your CPU may be overheating. Open the case, vacuum all the dust and
inspect all fans: Power Supply, CPU, Chipset, Graphic Card etc...
If all are operational then maybe the CPU heatsink compound (grease)
has dried up over times, and need a fresh new replacement.
Download a copy of Real Temp 3.60 and run it continously to monitor
the CPU temperature in real time.
http://www.techpowerup.com/downloads/1872/Real_Temp_3.60.html
Jul 16, 2011 | Dell Dimension 9200 PC Desktop
Dell dimension 9200 pc put herself in power save
Jun 09, 2011 | Dell Dimension 9200 PC Desktop
Dell dimension 9200 year 2005 model not displaying anything on start up ..monitor isn't the problem .....always ran very slowly
Jan 04, 2011 | Dell Dimension 9200 PC Desktop
Dell Dimension 9200 beeps on startup, with nothing...
A beep code of 3-3-4= Video Memory(RAM) Test Failure that would explain why you get nothing on your screen the first thing you would need to do is disconnect your monitor and try it on another computer. if it works fine then the problem is your video card. If that the case and the video card is intergrated with the motherboard, you will need to repalce the motherboard --- Sorry-- Please vote me a 10 when this works
May 20, 2010 | Dell Dimension 9200 PC Desktop
I have Dell dimension 9200 and have to reinstall xp but do not have raid drivers on floppy disk. Motherboard is OWG855. Can you help with this?
If you have a Dell with Dell and it uses a software RAID, then you can download them from Dell's site.
Go to support.dell.com and enter your service tag or the system type and you can access the drivers.
Oct 07, 2009 | Dell Dimension 9200 PC Desktop
How to exchange a super noisy vent inside the Dimension 9200 - where exactly is it mounted? (talking about the main/cpu vent - not GPU or powersupply)
The Dimension 9200 is similar to XPS 410. Here is the link to the service manual for the Dim 9200 http://support.dell.com/support/edocs/systems/xps410/en/index.htm
The image below shows the location of the Proc Fan, which is located at the front behind the Dell logo
Hope this helps. Please rate your feedback!
Thanks,
VJ
Mar 25, 2009 | Dell Dimension 9200 PC Desktop
Dell Dimension 9200 PC Desktop Logo
46 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
