Question about Nintendo Video Game Consoles & Games
My ds dosen`t let me enter in nintendo shop anymore. It says ,'Unable to connect to the access point. Check that the correct security key has been entered. For help, visit support.nintendo.com', along with,; error code: 051102-1', and usb conecter and pc. What can I do to fix it?
walesarumi
  • 6993 Answers
SOURCE: In trying to compleating
If you are using WEP or WPA security on your router try this:
1. Log into the router using the default IP (consult your router's manual for assistance)
2. Locate the "wireless security" section of your router settings and find the WEP or WPA key.
3. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F.
4. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F.
5. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters).
6. If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot.
7. If you are using WPA, the Wii console is compatible with the following types:
* WPA - PSK (TKIP)
* WPA - PSK (AES)
* WPA2 - PSK (AES)
But if your WEP or WPA key is correct, then the problem might be related to MAC address filtering:
1. From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model).
2. If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings).
3. If the Mac address filter was disabled, then continue troubleshooting.
Check Nintendo's router info for special notes, if available, for your router.
1. go to our Wireless Router look up page.
2. Use the drop-down box to select, if available, your router manufacturer.
3. Click on your router's model number, if available.
4. Read any "special notes" at the top of the router's page. Many issues can be solved by changing settings described in the "special notes."
Lastly, Power cycle your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response.
I hope the above solves your problem.
Good luck.
Posted on Oct 23, 2010
  • 17 Answers
SOURCE: What is a security key it says unable to connect
The security key is the password that protects your internet from other people connecting to your internet connection. To find out what your secuity key is there are three things you can do.
1. Check the back of your router, The security key is usually printed on there.
2. If it is not on the back of your router and are not very good with a pc or laptop contact your internet service provider they can usualy tell you the key.
3. If you are good on a computer and it is connected to the internet connection you want to use, turn it on then once everything is loaded a signal bar should appear in the bottom right hand corner of your screen. left click on that and a pop up box should appear. Right click on the network you use and click on status. Another pop up box should appear with your network settings, Click on the button that says wireless properties. Another pop up box will appear and at the top of the box click security. There should then be your security key but it will be hidden like a password. At the bottom there should be a check box that says show characters, tick that box and your security key should appear.
hope this helps
Posted on Jan 09, 2011
SOURCE: my internet says the access
Hi weigels,
I see you are getting an error security settigns not support by your Nintendo DS.
I beieve that you are trying to access a wireless connection using your Nintendo DS, the error that you are getting is actually an error saying that your Nintendo DS can detect the router but since your Router has a Network key you then get the error security settings not supported.
for a Nintendo DS it does not support Router settings that have a network security on it, you will have to disable the Routers Network security for you Nintendo DS to be able to access the wireless network of your Router, this will also prevent your Nintendo DS from getting the error security setting not supported.
Note: disabling your Network security will open your Routers signal to anyone who can detect the signal.
I hope this helps.
Have a nice day,
mvincentc
Posted on May 09, 2011
  • 26 Answers
SOURCE: Every time I try to connect to the internet it my
You can only connect to internet if someone is sharing their Wifi. If it is password protected, you won't have any luck. You're best off heading to Starbucks or McDonalds for free Wifi to connect to the internet.
Posted on Jun 18, 2011
  • 59 Answers
SOURCE: I can't get my son's
as i remeber, the secruity code is the one that you put before you access a locked internet connection and the passes are usally wpa styled password. you should put go to run>cmd>type ipconfig>and find you ip adress and put your ip on you internet explore. if should directly connect you to the router figuration or the log in your adminstrater and go to security tab or it might be diffrent. find your pass and put it on the dsi. hope it helped.
Posted on Jun 30, 2011
Cannot change transmission rate of Linksys WRT160N
1.With an online-capable game inserted into your Nintendo DS, turn on your system and access the game's main menu.
2.Access the Nintendo Wi-Fi Connection settings.
-These settings are typically found by selecting "Nintendo WFC" from the game's main menu. For detailed directions, consult the manual for the game.
3.At the Setup screen, tap "Nintendo Wi-Fi Connection Settings."
entryscreen3-cwz5mha2srvvin44vycqgk0s-3-2.jpg 4.Tap a connection file labeled "None."
emptyconnections4-cwz5mha2srvvin44vycqgk0s-3-5.jpg -If no empty connection files are available, select "Erase Settings" followed by "OK" to create an empty connection file.
5.Tap on "Search for an Access Point."
connection1settings-cwz5mha2srvvin44vycqgk0s-3-9.jpg 6.The Nintendo DS will search for any wireless networks within range. Once it is finished searching, it will display the names of all the wireless networks it finds.
oIf you receive the error message "No Compatible Access Points Within Range," click here.
7.Tap on the name of your wireless router or access point.
oIf there is a gray padlock next to the name of the wireless access point you wish to connect with, this indicates your router is using a security type incompatible with the Nintendo DS.
If prompted, use the keyboard on the bottom screen to enter the password for your wireless router or access point.
enter_wep1-cwz5mha2srvvin44vycqgk0s-3-14.png 8.Select "OK," "Save Settings," and then "Yes." The Nintendo DS will run a connection test.
9.The connection test was successful - Your Nintendo DS is now connected online.
Situation Not Resolved:
If the connection test was not successful, you will receive an error code:
ยทError Code 51300: This means the security code or network name entered into the Nintendo DS is not the same one the router is set to. To reach your connection settings, click "back" on the error code screen. Make sure to pay extra attention to the security key you find in your router's settings and enter it exactly as it appears (the key is case sensitive).
Apr 21, 2017 | Linksys WRT160N Wireless Router
How to work Nintendo ds wifi
  1. Turn on the Nintendo DSi
  2. Click on the wrench icon to access "System Settings."
  3. Select "Internet" on the third page of System Settings.
  4. Select "Connection Settings" and tap the "None" bar in "Connection 1."
  5. You have the option of setting up a connection manually, or searching for available connections in the area. You may also access your Nintendo Wi-Fi USB connector, if you have one (the product has been discontinued). The easiest thing to do is select "Search for an Access Point."
  6. Your Nintendo DSi will list the names of any wireless access points in range. A gold, unlocked icon next to the connection's name signifies an unlocked WEP (Wired Equivalent Privacy) connection that can be accessed immediately. A locked gold icon signifies an encrypted WEP connection that requires a WEP key (password).
  7. If you are accessing a locked/encrypted connection, enter your WEP key. You may also click "Change Security Settings" to enter a WPA (Wi-Fi Protected Access) key.
  8. If your WEP key is correct, your Nintendo DSi should connect. You can test your connection to verify.
  9. You're set! Now you can surf the Internet, purchase games and add-ons in the Nintendo DSi Shop, and play games that allow wireless access and competition (with WEP connections, only).
Aug 21, 2011 | Nintendo DS Lite
I dont know how to set up the nintendo wi-fi connection
  1. At the Setup screen, tap "Nintendo Wi-Fi Connection Settings."
  2. Tap "Connection 1 None."
    emptyconnections.jpg (Don't see "None" for Connection 1? To ensure any existing settings don't interfere with getting connected, tap the button, then choose "Clear Settings.")
  3. Click on "Search for an Access Point."
  4. The Nintendo DS will search for any wireless networks within range. Once it is finished searching, it will display the names of all the wireless networks it finds.
Once you have done this you may find next to your wi-fi, a lock this is what they mean:
unlocked_g.png No security - Your wireless network is unlocked.
  1. Tap on your network name to select it.
  1. Select "OK," "Save Settings," and then "Yes." The Nintendo DS will run a connection test with your wireless router.
  • The connection test was successful - Your Nintendo DS is now connected online and you can enjoy the Nintendo Wi-Fi Connection features of the game!
  • The connection test was not successful - If the test was not successful, you will receive an error code.
    • Error Code 51300: This means the security code or network name entered into the Nintendo DS is not the same one the router is set to. To reach your connection settings, click "back" on the error code screen. Make sure to pay extra attention to the security key you find in your router's settings and enter it exactly as it appears (the key is case sensitive).
    • All other error codes: Try our error code lookup where we have detailed information on many common error codes.
wep_g.png WEP security - Your wireless network is secured with WEP and requires a security key.
  1. Enter your router's WEP key into the Nintendo DS Don't know your router's security key? Let us help you find your router's security key. Select the brand of your router below and we'll provide you with the default information for that brand! Linksys Netgear DLink Belkin Apple 2Wire All other brands Enter your WEP keyOn the upper screen you will be informed that "A security key is needed to connect to this access point." Enter your security key by tapping the empty field, and select "OK" when finished.
wpa_g.png WPA security - Your wireless network is secured with WPA and requires a security key.
The Nintendo DS and Nintendo DS Lite are not compatible with WPA security. If you would still like to connect your Nintendo DS online, you will need to either change your router's security to WEP, or disable security entirely. Please note that any changes you make will affect other devices that connect wirelessly to your router.
Jul 05, 2011 | Nintendo Video Game Consoles & Games
Im not able to use Nintendo Wi-Fi Conection because of a communication error.My error code is:51099
Turn on the Nintendo DSi then Click on the wrench icon to access "System Settings." Select "Internet" on the third page of System Settings. Select "Connection Settings" and tap the "None" bar in "Connection 1." You have the option of setting up a connection manually, or searching for available connections in the area. The easiest thing to do is select "Search for an Access Point." Your Nintendo DSi will list the names of any wireless access points in range. A gold, unlocked icon next to the connection's name signifies an unlocked WEP (Wired Equivalent Privacy) connection that can be accessed immediately. A locked gold icon signifies an encrypted WEP connection that requires a WEP key (password).
If you are accessing a locked/encrypted connection, enter your WEP key. You may also click "Change Security Settings" to enter a WPA (Wi-Fi Protected Access) key. If your WEP key is correct, your Nintendo DSi should connect. You can test your connection to verify. You're set! Now you can surf the Internet, purchase games and add-ons in the Nintendo DSi Shop, and play games that allow wireless access and competition (with WEP connections, only).
Note Most Nintendo DS and DSi owners can get online by searching for an access point, but some might have to resort to manual setup.The Nintendo DSi can go online with a WPA connection, but actually playing DSi games online requires a WEP connection.
Jun 26, 2011 | Nintendo DS Lite
Internet
Jun 25, 2011 | Nintendo DSi Black Console
I can not get connection
Jun 25, 2011 | Nintendo DS Lite Console
How to put internet on it?
Jun 24, 2011 | Nintendo 3ds Handheld Game Console- Cosmo...
Dear nintendo, I'm trying to connect to the DSi shop,but I can't connect to my internet.Can you helpmeet? From...
Jun 23, 2011 | Nintendo DSi Black Console
Nintendo ds screen says unable to connect to a access point. error code: 051310-1
How to fix: Make sure the security key and security type are entered into the Nintendo DS exactly as they appear in your router's settings.
Feb 28, 2011 | Nintendo DS Console
Web setup
With a Wi-Fi compatible game inserted into your Nintendo DS, access the Nintendo Wi-Fi Connection Settings screen. Your game manual provides information on how to do this for the game you are playing.
  1. Tap Nintendo Wi-Fi Connection Settings
  2. Tap one of the Connection slots
  3. Tap "Search For An Access Point"
The Nintendo DS will then display the name of your wireless access point.
If your Access Point has a blue, unlocked icon, tap the Access Point name, and then 'OK.' The Nintendo DS will then establish a connection with your router. Back out to the main screen of your game and your ready to play online.
If your Access Point has a red, locked icon, the Nintendo DS has detected WEP key security on your router. Tap the Access Point name on the Nintendo DS and then enter the WEP key for your router on the following screen and tap 'OK' to save the settings.
Tap 'OK' again and the Nintendo DS will then establish a connection with your router. Back out to the main screen of your game and your ready to play online.
If your Access Point has a gray, locked icon, the Nintendo DS has determined your router's security settings are not supported by the Nintendo DS. In order to connect to the Nintendo Wi-Fi Connection, you will need to either switch to WEP security, or remove the security setting of your router when connecting with the Nintendo DS.
NOTE: All information taken from http://www.nintendo.com/consumer/wfc/en_na/ds/connect.jsp
Oct 09, 2010 | Nintendo DS Lite
Video Game Consoles & Games Logo
27 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
