Question about Fasco Heating & Cooling
51-21964-11 rheem-rudd induer wire digiram
Its a fan motor i need to hook up the wires
farfield
  • 462 Answers
SOURCE: RV AC, how to wire fan (blower) motor to capacitor.
You almost have it Look closer at the run capacitor. It has Herm, this is for the compressor, Com or C and F or Fan.
1 of your power wires is the fan speed so connect them accordingly usually black is hi, blue med, & red is low. You are "feeding" voltage to the selector switch on 1 side and coming out to the fan motor speeds.
Next you have a "Common" wire on your fan motor (this means its Common to all the other connections inside the fan motor to me. It is usually white. Connect this to the other line of power usually the Com on the capacitor unless it connects to a strip on the selector switch. But 1 of these 2 places will be the other side of your Power when plugged in. Lastly the brown it is usually the fan capicator only wire and it will connect to the fan "F" terminal on the capicator this terminal will not have any other wires connected to it.
This should make you a happy camper. Please rate me accordingly and good luck.
Posted on Mar 08, 2009
  • 659 Answers
SOURCE: I need a wiring diagram for the fan motor
http://www.nordyne.com/literature/710235a.pdf
This is to your unit. Good luck!
Posted on Apr 09, 2009
Sea Breeze
  • 4654 Answers
SOURCE: replacing old 3 wire condensor fan motor with new 4 wire
The extra wire is a additional speed wire and the existing model that you are installing is possibly not set up for that additional speed. It depends on the exact model of air conditioner that your post says you have, but we can never be sure until you confirm the model number of your Goodman, if its a split unit, a package unit or condenser fan or evaporator fan. Let me know all of those answers and I will help you determine the answer, Thanks, Sea Breeze
Posted on May 08, 2009
meBNme
  • 334 Answers
SOURCE: I have a Trane XE1200
OK, locate the terminals on the capacitor marked "HERM"(Compressor lead), "FAN", and "COM".(common)
HERM and COM remian as they are.
The wire going to "FAN" (usually brown) will be placed on either terminal of the new capacitor. (This is the ((usually brown)) wire comming off of the fan motor.) An additional wire needs to be run from the other terminal of the new capacitor to the "COM" on the old capacior.
What you are doing is bypassing the fan side of the old capacitor but still using the compressor side of the old Cap.
The fan should have a wiring diagram on it to help identify the wires if there is no brown wire. The other two wires will be identified on the wiring diagram as well, but one typically goes to the contactor and the other to the board.
Posted on Sep 07, 2009
  • 4 Answers
SOURCE: schematic diagram Rudd silouette II a/c gas furnace needed
There should be a small set of screw lugs on the electronic board in the furnace. Look for a red wire that comes out of the transformer and follow it to find where the 24V connections are.
Posted on Sep 26, 2009
Rudd Rheem 1068-311 62-23599-04 board how do I change blower speeds?
psc motors have 4 speeds each colored black blue yellow red and white. there are speed taps on the board labeled heat, cool, even heat/cool and usually Park or M1 male spade fittings for the unused speeds. on the door will tell you speed chart by wire color ie black is high and red is low speed. newer models ask you not to use red for heat. to change speeds is by changing wires and their system mode taps. (beware the push release female end locks into the board) If using black for both and there is a heat/cool tap make sure that the separate taps cool or heat are empty, or motor will receive 120 volts twice. 1 thing to remember a 3.5 ton blower with a 2 ton air cond. wouldn't want to use black too much air flow.
If you have a variable speed its all in the bible for a manual and which dip switch position for cfm air flow.
Jul 01, 2014 | Ruud Rheem 1068-311 Furnace Control Board...
Hello all My Rudd AC unit will start and run find maybe for 10 minutes and cool air then the fan outside will stop and unit hums or hisses and blows hot air inside vents. I changed out Thermostat and Run...
Welcome to the world of Ruud! Ok James heres the deal. It sounds like the condenser fan motor has failed. Its not a repairable item but the motor is not too expensive. Disconnect the main power at the fuse block on the side of your house next to your a/c. Remove the screws that hold the top fan section and carefully turn the fan/panel assembly over taking care not to stress the wires. Determine how the fan is mounted (probably 4 screws) and go find your new motor. Both Rheem and Ruud use the same motor mounting. Most a/c supply houses have a motor that will fit or go to graingers. Make sure you get a matching run capacitor for that motor. It will have separate wires and not share any wiring with the old capacitor. The old capacitor will have to stay in place since it is also connected to the compressor. The old motor will have 3 wires and the new one 4 (2 brown for the capacitor and 2 others to put on the contactor that the compressor wires go to). If its a heat pump it could be a board and youll need help. good luck
Aug 15, 2013 | Ruud UBHC Air Conditioner
Replacing the Contactor on my Rudd AC model uaka-037jaz. I got a Dayton 2utl4 contator for a replacement. I need to know which wires connect to what location. I hooked it up with the 2 thermostat wires...
On this unit wiring is very basic, line in wires to the two lugs on the bottom, common as refered to is always black wire which goes to the compressor and the fan motor, red to adjacent lug of the contactor which then one goes to the capacitor and one to the compressor and one to the outdoor fan motor. One wire usually yellow from capacitor to start winding of compressor marked on the capacitor as herm, and a brown wire to the fan motor from the capacitor. The side connectors as you know go to the 24v control coil. The reason as to the fuse going out could be due to loose connections in the disconnect box or a short in the wiring at the compressor, fan motor or capacitor, and worst case a shorted compressor internally. Recommend having the system checked with the proper equipment to include an ohm meter with uf reading ability.
Aug 24, 2011 | Heating & Cooling
I have a rheem ac. the fan motor quit. the replacement has 2 xtra wires. howm do i hook it up
Without knowing what was there and what you are trying to install exactly it is impossible to give a definite answer...
My feeling that you are replacing a single speed motor with a multispeed motor and that the wires are just extra speeds... if so hook up the black wire, white, and browns,and tape of the other colored wires...
heatman101
Sep 20, 2010 | Heating & Cooling
I need to replace my switch for speed an i dont how my wires go
mcdevito75 here, The wires in the instuctions should show what color they hook up to, now just match those wires with the switch, a small tip, hook up a dark wire from the fan motor to a dark wire on the switch, a lite color wire from the fan motor to a lite color wire on the switch as you hook up each pair or wires, cover the bare wires remaining on the fan motor and switch with tape and try the fan to check spped.
Jul 20, 2010 | Aloha Housewares (93645) Ceiling Fan
Schematic diagram Rudd silouette II a/c gas furnace needed
Sep 21, 2009 | Ruud UBHC Air Conditioner
Rudd achiever serie. where do the 24 volt wires go to on the air handler.
The two wires from condensing unit go yellow or y from Tstat and theother wire goes brown if it is a Rudd or Rheem. Red from Air HAndler goes to Tstat R Green to Tstat G white to w. If it is digital tstat brown goes to C.
Jun 04, 2009 | Ruud UAMB Air Conditioner
Wiring match-up
If this is a standard heat cool unit. You have a tstat with rygwcob. Just color code the wire to the unit. Some air handlers such as Rheem and carrier use different collors for there common Carrier black Rheem or Rudd Brown. Two wires that go outside use yellow blue. Yellow to Y fron Tsta and blue to common or blue,blavk or brown.or C
May 30, 2009 | Heating & Cooling
No heat from unit. Hear ignitors start but no airflow in house
well i need to know if the fan comes on at all if not then it could be a bad motor or board which is not uncommon but if the fan does come on and then flames go out and fan stays running could be high limit check to make sure in the bower compartment there are no wires disconnected from the blower sometimes when changing the filter it is possible to knock the wire off the board
May 19, 2009 | Heating & Cooling
Heating & Cooling Logo
32 people viewed this question
Top Fasco Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you a Fasco Heating and Cooling Expert? Answer questions, earn points and help others
